Sean Colliers KX500 build
Re: Sean Colliers KX500 build
Hopefully these will never be a issue for Sean again.
KX GURU RACING SEAN COLLIER KX500 368.JPG (106.77 KiB) Viewed 9720 times
KX GURU RACING SEAN COLLIER KX500 369.JPG (127.58 KiB) Viewed 9720 times
KX GURU RACING SEAN COLLIER KX500 370.JPG (82.27 KiB) Viewed 9719 times
Steering dampener post
KX GURU RACING SEAN COLLIER KX500 371.JPG (87.6 KiB) Viewed 9719 times
Lower engine mounts...
KX GURU RACING SEAN COLLIER KX500 372.JPG (118.82 KiB) Viewed 9717 times
KX GURU RACING SEAN COLLIER KX500 373.JPG (110.94 KiB) Viewed 9717 times
Received the head but it needed a bit of work...
I sure could have used my Vapor Blaster but I used what I had...
KX GURU RACING SEAN COLLIER KX500 374.JPG (109.95 KiB) Viewed 9715 times
No lapping compound or surface plate.... So, a little sand paper and a piece of glass worked in a pinch..
KX GURU RACING SEAN COLLIER KX500 375.JPG (147 KiB) Viewed 9715 times
We had some nice triple clamps but no steering stem..
So into the press this one went..
KX GURU RACING SEAN COLLIER KX500 377.JPG (131.87 KiB) Viewed 9714 times
Beautiful
KX GURU RACING SEAN COLLIER KX500 378.JPG (207.27 KiB) Viewed 9714 times
Oh, these are nice..
KX GURU RACING SEAN COLLIER KX500 379.JPG (114.01 KiB) Viewed 9713 times
Finally... Some progress..
KX GURU RACING SEAN COLLIER KX500 380.JPG (147.64 KiB) Viewed 9713 times
Suspension linkage... Everything was cleaned in the bucket and every bearing and seal was replaced.
KX GURU RACING SEAN COLLIER KX500 381.JPG (215.6 KiB) Viewed 9704 times
Emig dog bones were used to help change the KX500 handling characteristics..
KX GURU RACING SEAN COLLIER KX500 382.JPG (173.85 KiB) Viewed 9704 times
With about an hours worth of scrubbing these sure came out clean ;)
A little more progress...
KX GURU RACING SEAN COLLIER KX500 383.JPG (198.38 KiB) Viewed 9703 times
And a little more..
KX GURU RACING SEAN COLLIER KX500 384.JPG (238.67 KiB) Viewed 9703 times
Hey... there is a little something different about that swingarm... 8-)
Check out that Pro Action suspension... Nice!
KX GURU RACING SEAN COLLIER KX500 385.JPG (208.89 KiB) Viewed 9701 times
It glows....
KX GURU RACING SEAN COLLIER KX500 386.JPG (259.23 KiB) Viewed 9701 times
Jason is hooking up the boot to the inlet side of the carb.. Always a pain when dealing with a 20 year old piece of rubber and using a 10mm reed spacer... But, a lot easier to do it now then after the bike is built :lol:
KX GURU RACING SEAN COLLIER KX500 387.JPG (257.33 KiB) Viewed 9700 times
Oscar taking Brutes old KX500 Super Moto out for a spin before we start robbing parts off her..
KX GURU RACING SEAN COLLIER KX500 388.JPG (266.19 KiB) Viewed 9700 times
