Bringing some additional jetting, some needles, as well as a back up carb.
Since we are using a different carb then we normally use it's a good idea to bring the kitchen sink.
KX GURU RACING SEAN COLLIER KX500 356.JPG (67.26 KiB) Viewed 9481 times
Jason is fitting the modified Wossner piston that has been WPC treated..
KX GURU RACING SEAN COLLIER KX500 357.JPG (87.95 KiB) Viewed 9481 times
The cool thing is Jason and I received the pleasure of seeing Sean's new bike from the earliest beginnings...
Here is some of the chassis mods..
The upper sub frame mount was all new..
KX GURU RACING SEAN COLLIER KX500 366.JPG (79.47 KiB) Viewed 9474 times
The lower linkage mounts were reinforced..
KX GURU RACING SEAN COLLIER KX500 367.JPG (110.31 KiB) Viewed 9474 times
