Sean Colliers KX500 build
Re: Sean Colliers KX500 build
KX GURU RACING SEAN COLLIER KX500 353.JPG (138.66 KiB) Viewed 9617 times
KX GURU RACING SEAN COLLIER KX500 354.JPG (132.25 KiB) Viewed 9617 times
Soon to be in action like this..
So much happened in such a short time.
I'll be posting details of our trip to Glen Helen and finishing the build details as soon as I have time.
For now, join Sean Collier as he breaks in his new KX Guru Racing built KX500 at Day in the Dirt
https://www.youtube.com/watch?v=XZ036K4Sx5U
Ok... Back to the build...
Can you say piston mods?
KX GURU RACING SEAN COLLIER KX500 354.JPG (42.97 KiB) Viewed 9504 times
Oh yeah... I knew you could :lol:
KX GURU RACING SEAN COLLIER KX500 355.JPG (75.09 KiB) Viewed 9504 times
Just gotta be very careful that you don't expose any ports that aren't suppose to be exposed at their proper time 8-)
Another awesome Motorrad mod.
Bringing some additional jetting, some needles, as well as a back up carb.
Since we are using a different carb then we normally use it's a good idea to bring the kitchen sink.
KX GURU RACING SEAN COLLIER KX500 356.JPG (67.26 KiB) Viewed 9503 times
Jason is fitting the modified Wossner piston that has been WPC treated..
KX GURU RACING SEAN COLLIER KX500 357.JPG (87.95 KiB) Viewed 9503 times
Things are looking good...
KX GURU RACING SEAN COLLIER KX500 358.JPG (78.63 KiB) Viewed 9502 times
Nothing fancy to see here unless you really know what you are looking for... And I'm not tellin :ugeek:
KX GURU RACING SEAN COLLIER KX500 359.JPG (56.31 KiB) Viewed 9502 times
Is it really a KX Guru cylinder?
KX GURU RACING SEAN COLLIER KX500 360.JPG (125.73 KiB) Viewed 9501 times
You know it..
As it turns out our custom cut head didn't make it in time so we switched shipping addresses to LA, loaded up and hit the road.
KX GURU RACING SEAN COLLIER KX500 361.JPG (166.88 KiB) Viewed 9501 times
Yes, we brought a few toys just in case.... And for a couple of reasons it was a good thing we did but more on that later..
I won't bore you with the 15 hour drive... You know the drill... traffic jams, slow drivers in the passing lane, and just general rude behavior :x :x :x
So we roll into Oscars home and start unloading our toys.. It was a KX500 dream...
KX GURU RACING SEAN COLLIER KX500 362.JPG (143.95 KiB) Viewed 9500 times
Then it was time to hit the sac.. Good thing I brought my air mattress and sleeping bags :o
KX GURU RACING SEAN COLLIER KX500 363.JPG (127.81 KiB) Viewed 9500 times
Oscar's wife Becky keeps the floor very shiney 8-)
So the next morning after a awesome breakfast... We headed out to the garage to get started..
KX GURU RACING SEAN COLLIER KX500 364.JPG (169.75 KiB) Viewed 9497 times
So Jason and I looked around for a rolling chassis to install the engine into..
There was a Chassis but it was no roller...
KX GURU RACING SEAN COLLIER KX500 365.JPG (182.6 KiB) Viewed 9497 times
The cool thing is Jason and I received the pleasure of seeing Sean's new bike from the earliest beginnings...
Here is some of the chassis mods..
The upper sub frame mount was all new..
KX GURU RACING SEAN COLLIER KX500 366.JPG (79.47 KiB) Viewed 9496 times
The lower linkage mounts were reinforced..
KX GURU RACING SEAN COLLIER KX500 367.JPG (110.31 KiB) Viewed 9496 times
