Sean Colliers KX500 build
Re: Sean Colliers KX500 build
Into the oven it goes... Sorta
KX GURU RACING SEAN COLLIER KX500 328.JPG (100.67 KiB) Viewed 9425 times
The head had the Decomp mod done by Larry Wiechman...
And, it showed up at Motorrads place for a little flying M work ...
KX GURU RACING SEAN COLLIER KX500 329.JPG (63.25 KiB) Viewed 9425 times
The guys at Millennium Technologies really stepped up on this build and did the custom machine work on this cylinder after Jason ported it, then plated it.
They really helped us out by expediting the job and doing two day return shipping.
I could not ask for more...
1404 Pilgrim Rd, Plymouth, WI 53073
(920) 893-5595
We have used Millennium Tech for many years and their work is exceptional.
In fact, I won't send my cylinders elsewhere.
I'll post pics of the cylinder when I get it back.
WPC Treatment really came through for us on this build.
This engine should shift smoother and have less gear drag resulting in longer life parts and less HP being wasted in the gear box.
http://www.wpctreatment.com/
2909 Oregon Court, Unit C2
Torrance, CA 90503
Tel 1.310.782.8647
KX GURU RACING SEAN COLLIER KX500 330.JPG (145.75 KiB) Viewed 9397 times
KX GURU RACING SEAN COLLIER KX500 331.JPG (126.27 KiB) Viewed 9397 times
KX GURU RACING SEAN COLLIER KX500 332.JPG (136.9 KiB) Viewed 9397 times
Pro Action hooked us up with parts to rebuild the KX450F forks 8-)
http://pro-action.com/
3611 8TH AVENUE
BEAVER FALLS, PA 15010
PHONE: (724) 846-9055
KX GURU RACING SEAN COLLIER KX500 333.JPG (158.39 KiB) Viewed 9395 times
These are parts for the forks, Alex has the parts for the shock.
These valves and the springs were set for Sean's riding style... Incredible... :lol:
Installed some new seals and a piston into the rear brake caliper..
KX GURU RACING SEAN COLLIER KX500 334.JPG (158.66 KiB) Viewed 9351 times
Just about have the rear brake caliper done..
KX GURU RACING SEAN COLLIER KX500 335.JPG (145.13 KiB) Viewed 9351 times
KX GURU RACING SEAN COLLIER KX500 336.JPG (123.79 KiB) Viewed 9351 times
Engine assembly..
KX GURU RACING SEAN COLLIER KX500 337.JPG (131.81 KiB) Viewed 9350 times
KX GURU RACING SEAN COLLIER KX500 338.JPG (119.72 KiB) Viewed 9350 times
KX GURU RACING SEAN COLLIER KX500 339.JPG (139.98 KiB) Viewed 9350 times
KX GURU RACING SEAN COLLIER KX500 340.JPG (142.13 KiB) Viewed 9349 times
KX GURU RACING SEAN COLLIER KX500 341.JPG (137 KiB) Viewed 9349 times
KX GURU RACING SEAN COLLIER KX500 342.JPG (111.97 KiB) Viewed 9349 times
That's one proud piston... :ugeek:
KX GURU RACING SEAN COLLIER KX500 343.JPG (81.27 KiB) Viewed 9348 times
KX GURU RACING SEAN COLLIER KX500 344.JPG (165.95 KiB) Viewed 9348 times
KX GURU RACING SEAN COLLIER KX500 345.JPG (169.24 KiB) Viewed 9348 times
KX GURU RACING SEAN COLLIER KX500 346.JPG (145.06 KiB) Viewed 9347 times
KX GURU RACING SEAN COLLIER KX500 347.JPG (148.45 KiB) Viewed 9347 times
KX GURU RACING SEAN COLLIER KX500 348.JPG (141.03 KiB) Viewed 9347 times
KX GURU RACING SEAN COLLIER KX500 350.JPG (140.28 KiB) Viewed 9346 times
KX GURU RACING SEAN COLLIER KX500 351.JPG (138.52 KiB) Viewed 9346 times
KX GURU RACING SEAN COLLIER KX500 352.JPG (163.93 KiB) Viewed 9346 times
