But they still won't fit...
- KX GURU RACING SEAN COLLIER KX500 318.JPG (99.08 KiB) Viewed 10283 times
The web is just too thick...
So into the vice for a little hand work..
- KX GURU RACING SEAN COLLIER KX500 319.JPG (131.11 KiB) Viewed 10283 times
Grind, grind, grind, file, file, file...
Check it often... Unless you have a mill, then just mill it to the correct thickness..
- KX GURU RACING SEAN COLLIER KX500 320.JPG (368.89 KiB) Viewed 10283 times
Make sure it rotates freely with no obstructions..
