My initial thoughts is the engine is in really good shape.
The only negative is the crank to bearing fit was a little looser then I would like but I have not measured it yet.
No biggie... I'm going to use that crank anyway...
I'll try to get it torn all the way down later today so I can really check it thoroughly...
Any KX500 build should keep one thing in mind... Build that bottom end like you want it to last forever... cause it won't
But, there are several things you can do to ensure that it last's a good long time...
Number one.... INSPECT EVERYTHING!!!!
Every gear should be carefully measured and inspected..
KX GURU RACING SEAN COLLIER KX500 108.JPG (216.49 KiB) Viewed 10731 times
KX GURU RACING SEAN COLLIER KX500 109.JPG (209.14 KiB) Viewed 10731 times
KX GURU RACING SEAN COLLIER KX500 116.JPG (175.91 KiB) Viewed 10726 times
Even if you think you know the manual forwards and backwards... keep it handy... You never know when it can save you from a glitch in the matrix
KX GURU RACING SEAN COLLIER KX500 117.JPG (137.69 KiB) Viewed 10726 times
This is probably the nicest used trans from a KX500 that I have seen in the recent past but leave it to Jason to find some gears that just aren't up to his standards.
Today Jason tested the Stator for resistance...
And when it comes to Ohms specs... Always believe the book
The last thing we need is to have electrical problems on this bike...
KX GURU RACING SEAN COLLIER KX500 118.JPG (109 KiB) Viewed 10685 times
KX GURU RACING SEAN COLLIER KX500 119.JPG (101.14 KiB) Viewed 10685 times
