MY 1991 KX250 HAS NO SPARK!
Feel free to ask.
Rookestar
Re: MY 1991 KX250 HAS NO SPARK!
Post by Rookestar »
Kx
Rookestar
Post by Rookestar »
Kx
From what I can tell it looks correct.
So your next step is to check the OHM specs for the coil and the stator.
Just because it worked two years ago does not mean that it is still good today.
Run the Ohm specs and go from there.
Rookestar
Post by Rookestar »
Hi i've just bought a multimeter and everything seems to be checking out fine Except from I'm getting No readings from red to red and black?
You will only test a few wires.
If your system was a 91 KX250 STATOR SPECS
Red to Black/Red 359-539 ohms
White/Red to White/Green 188-283 ohms
If your system was a 91 KX125 STATOR SPECS
Red to Black/Red 417-627 ohms
White to Ground 14.3-21.5 ohms
The biggest issue is not really knowing what you have...
Rookestar
Post by Rookestar »
All seems to be in range Butt still no readings with red to black/red will it halp if I take the flywheel off and see what colour wires are going to were ?
Nope, don't need to see the wires.
Your stator is dead my friend.
No reading, no bueno :(
Rookestar
Post by Rookestar »
:cry: ok thanks for all the halp I'm gonna ty get a new 1 if I can find 1 that is I will keep you posted thanks again
Rookestar
Post by Rookestar »
Hi I was just wondering if I haft to replace the whole lot
Rookestar
Post by Rookestar »
Or can I just replace these ??
