MY 1991 KX250 HAS NO SPARK!
Feel free to ask.
Re: MY 1991 KX250 HAS NO SPARK!
I'll see if I can locate the original wiring diagram for this...
Here you go :D
1991 KAWASAKI KX250 WIRING DIAGRAM.JPG (152.68 KiB) Viewed 16485 times
A 91 has no pure white wire... Hmmm..... More research is required...
A 91 KX125 has a pure white wire...
Rookestar
Post by Rookestar »
Hi that is very strange It's definitely a 250 engine number is kx250he003063
Rookestar
Post by Rookestar »
Also the White wire is the only wire that sparks when I touch it to earth ?
Rookestar
Post by Rookestar »
The bike was working perfect before I stripped it :cry:
That is a 91 engine number.
But here is the thing.
Somewhere along the line your CDI or stator was swapped out.
Because it's non standard it will be tough figuring out what is what.
Let me see if I have the wiring diagram for the 91 KX125.
Here is the 1991 KX125 Wiring diagram
Rookestar
Post by Rookestar »
Thanks for the diagram still couldn't figure out were that White wire goes can you please tell me if I have wired it up correctly
