CR500 Kart engine rebuilds
Yup... We received a pair of CR500 engines to rebuild last night.
One, the customer needs back by the 5th so we are using his parts.
Also, it will not be a total rebuild.... Not ideal but I'm sure we can still put a smile on his face :D
Pics to follow...
This is what we are starting with..
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 10.JPG (388.85 KiB) Viewed 19075 times
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 11.JPG (360.21 KiB) Viewed 19075 times
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 12.JPG (385.6 KiB) Viewed 19075 times
So, the first thing we did was get out the Hot water pressure washer and get all the dirt and grease off this engine.
I hate cracking open a engine with dirt and grease on it... :)
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 13.JPG (374.07 KiB) Viewed 19074 times
Cracked open the stator cover and found a nice little surprise! :lol:
Light weight fly wheel... Yes!! and other goodies...
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 14.JPG (382.92 KiB) Viewed 19074 times
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 15.JPG (386.99 KiB) Viewed 19074 times
Cool head!
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 16.JPG (106.36 KiB) Viewed 19073 times
Ugh! Not so cool..
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 17.JPG (209.77 KiB) Viewed 19073 times
Oh no... A crack...
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 101.JPG (338.63 KiB) Viewed 19073 times
I see some improvement to be had..
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 102.JPG (327.75 KiB) Viewed 19071 times
Looks good..
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 103.JPG (166.51 KiB) Viewed 19071 times
Not so fast...
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 104.JPG (336.88 KiB) Viewed 19071 times
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 105.JPG (160 KiB) Viewed 19069 times
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 106.JPG (156.73 KiB) Viewed 19069 times
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 107.JPG (87.86 KiB) Viewed 19069 times
So after tear down we know that we have out work cut out for us to get this engine done by the 5th... But we can do it and... Make it a bit faster :ugeek:
Friar-Tuck
Post by Friar-Tuck »
Hey Blaster,
I work with a guy who builds cart engines for the guys who race around the Redding Ca. area.
One of the "tricks" they use on their CR5 kart engines is to remove all but third gear from the tranny. I guess that's all they need, and it frees
up recip. weight/drag. Hope you guys get swamped with work :mrgreen:
Take Care,
Tuck\o/
Yes, this guy runs a Mini Outlaw CR500.
He uses fourth only... So, I'm looking into what that will take...
Of course I have some cool ideas :lol:
I'm always busy... I just have to learn to pace myself and make money doing it 8-)
Cases are back from weld...
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 108.JPG (198.5 KiB) Viewed 19049 times
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 109.JPG (166.65 KiB) Viewed 19049 times
JT ENGINE WORKS 89 CR500 CART ENGINE BUILD 110.JPG (174.47 KiB) Viewed 19049 times
Return to “Outlaw Kart information Tech N talk”
