CRF250R Honda engine rebuild by JT Engine Works..
We have been so busy that I finally got around to taking some pics of this build...
Most of the work has already been done.... So you'll have to make due with the left overs
Replaced all the bearings, seals, bushings, springs, gaskets, you know the drill
It got so hot the bearing journals turned blue.
- CRF250R Honda engine rebuild by JT Engine Works 101.JPG (126.62 KiB) Viewed 4003 times
Totally locked up!
- CRF250R Honda engine rebuild by JT Engine Works 102.JPG (104.38 KiB) Viewed 4003 times
- CRF250R Honda engine rebuild by JT Engine Works 103.JPG (166.23 KiB) Viewed 4003 times
