2006 CRF250R Honda engine rebuild by JT Engine Works
CRF250R Honda engine rebuild by JT Engine Works..
We have been so busy that I finally got around to taking some pics of this build...
Most of the work has already been done.... So you'll have to make due with the left overs :o
Replaced all the bearings, seals, bushings, springs, gaskets, you know the drill :-)
It got so hot the bearing journals turned blue.
CRF250R Honda engine rebuild by JT Engine Works 101.JPG (126.62 KiB) Viewed 4004 times
Totally locked up!
CRF250R Honda engine rebuild by JT Engine Works 102.JPG (104.38 KiB) Viewed 4004 times
CRF250R Honda engine rebuild by JT Engine Works 103.JPG (166.23 KiB) Viewed 4004 times
Re: 2006 CRF250R Honda engine rebuild by JT Engine Works
CRF250R Honda engine rebuild by JT Engine Works 104.JPG (150.74 KiB) Viewed 4002 times
CRF250R Honda engine rebuild by JT Engine Works 105.JPG (115.36 KiB) Viewed 4002 times
CRF250R Honda engine rebuild by JT Engine Works 106.JPG (157.01 KiB) Viewed 4002 times
CRF250R Honda engine rebuild by JT Engine Works 107.JPG (121.47 KiB) Viewed 4001 times
CRF250R Honda engine rebuild by JT Engine Works 108.JPG (179.26 KiB) Viewed 4001 times
CRF250R Honda engine rebuild by JT Engine Works 109.JPG (181.02 KiB) Viewed 4001 times
CRF250R Honda engine rebuild by JT Engine Works 110.jPG (141.91 KiB) Viewed 4001 times
Well... I really have been slacking...
This baby is done!!!
Second heat cycle has been ran..
CRF250R Honda engine rebuild by JT Engine Works 111.jPG (225.14 KiB) Viewed 3994 times
