KX500 BOTTOM END REBUILD FOR SCOT By JT Engine Works & OEM-CYCLE
We received a bottom end from Scot for a rebuild.
The bike was purchased, not running a while back for a real steal of a price..
When we got it, I looked it over.
The cases were good, the crank looked pretty good so I thought this will finally be an easy one...
WRONG!!!
But before I get into that, I already had a KX500 crank on hand and ready to go... Balanced and polished with a Wossner rod...
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 102.JPG (105.59 KiB) Viewed 9409 times
And, I had our basic parts list on order with our local Kawasaki dealer..
kx500 basic parts list 101.JPG (164.42 KiB) Viewed 9409 times
kx500 basic parts list 102.JPG (97.98 KiB) Viewed 9409 times
Further, the Cometic gaskets and a few other parts came in quick...
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 101.JPG (168.72 KiB) Viewed 9409 times
Re: KX500 BOTTOM END REBUILD FOR SCOT By JT Engine Works & OEM-CYCLE
When I opened the engine I saw that it was the best packaging job I had ever seen.
We do a pretty good job but this was awesome..
Unfortunately my cel phone broke and I couldn't take any pics...
Next I washed up the engine, don't want any extra debris getting into the engine..
Then I started on disassembly..
The flywheel had some unexpected damage..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 103.JPG (156.25 KiB) Viewed 9408 times
I have never seen one quite like that before..
Next I noticed that the clutch washer was really worn..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 104.JPG (133.45 KiB) Viewed 9408 times
Something was definitely up on this engine..
Needless to say, we will be checking the ohm specs on this before it ever goes back into the engine...
There will also be a bit of clean up involved :lol:
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 105.JPG (78.25 KiB) Viewed 9395 times
Man, even the shift shaft spring is worn out :?:
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 106.JPG (90.58 KiB) Viewed 9395 times
All but three gears are junk... Both shafts are also done for :x
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 107.JPG (55.32 KiB) Viewed 9395 times
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 108.JPG (72.89 KiB) Viewed 9395 times
Now you might be saying... Wait a minute, can't you get the gear dogs undercut?
Normally yes, however, the splines that the gears attach to the shafts on are worn out.
And the snap rings that hold the gears in their relative positions are completely wallered out....
Definitely something bad happened here..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 109.JPG (59.55 KiB) Viewed 9393 times
Then we discovered the problem...
Here is another case out of my top secret stash..
See the steel insert where the output trans shaft goes?
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 110.JPG (137.24 KiB) Viewed 9393 times
This engine had no insert..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 111.JPG (126.15 KiB) Viewed 9393 times
That means that the output shaft was just flopping around in there...
It's a wonder the engine did not grenade... :o
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 112.JPG (63.92 KiB) Viewed 9393 times
The cases and clutch cover were warped pretty bad.
We had to spend some time on the granite surface plate before we could even lap..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 113.JPG (125.42 KiB) Viewed 9392 times
In all fairness, someone had welded the clutch cover fairly extensively..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 114.JPG (116.52 KiB) Viewed 9392 times
Once that was done Jason mixed up some Timesaver, 100 grit (Very fine) and started lapping the cases to insure a positive fit with no air leaks..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 115.JPG (132.47 KiB) Viewed 9392 times
Timesaver is so amazing... I thank Motorrad every time I use this stuff..
Bolt one case to the table so it doesn't walk around on you and go to town
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 116.JPG (122.39 KiB) Viewed 9392 times
Back and forth, side to side, swirl and swirly.. Repeat..Repeat..Repeat..Repeat..Repeat..Repeat..Repeat..Repeat..Repeat..Repeat.. ect...
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 116.JPG (122.39 KiB) Viewed 9391 times
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 117.JPG (113.51 KiB) Viewed 9391 times
Jason even lapped the clutch cover 8-)
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 118.JPG (135.79 KiB) Viewed 9391 times
Jason on the Vapor Blaster..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 119.JPG (149.11 KiB) Viewed 9390 times
Then into the Ultrasonic cleaner
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 120.JPG (106.32 KiB) Viewed 9390 times
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 121.JPG (121.01 KiB) Viewed 9390 times
The results are amazing..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 122.JPG (95.87 KiB) Viewed 9389 times
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 123.JPG (105.15 KiB) Viewed 9389 times
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 124.JPG (99.42 KiB) Viewed 9389 times
New parts..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 125.JPG (90.59 KiB) Viewed 9387 times
More new parts..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 126.JPG (110.36 KiB) Viewed 9387 times
Waiting... waiting...
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 127.JPG (108.92 KiB) Viewed 9387 times
Ready for bearings and seals..
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 128.JPG (120.64 KiB) Viewed 9386 times
Hot!!!
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 129.JPG (104.71 KiB) Viewed 9386 times
