KX500 2 piece clutch cover adapter
Re: KX500 2 piece clutch cover adapter
Another tip.
While you still have the clutch cover in the mill, you might want to consider removing about .030 off the water pump face.
As you can see in the pic below, there is a lot of clearance between the water pump and the impeller.
This will cause cavitation and potential air bubbles..
Note that there is no gasket between the water pump cover and the clutch cover.
And after milling the face down there is no clearance for the water pump cover... PERFECT!
When you install your gasket you should have perfect clearance :D
Or, if you want to cheat, don't mill the face down at all and add 1 washer to the back side of the impeller.
There is a washer there already, simply add another 8-)
Is that a OEM-CYCLE 2 piece clutch cover on Destry Abbott's bike? 8-)
destry abbott.jpg (164.72 KiB) Viewed 18975 times
destry abbott2.jpg (159.84 KiB) Viewed 18972 times
destry abbott3.jpg (77.46 KiB) Viewed 18968 times
destry abbott4.jpg (151.85 KiB) Viewed 18968 times
destry abbott5.jpg (232.92 KiB) Viewed 18968 times
destry abbott6.jpg (338.65 KiB) Viewed 18968 times
destry abbott 101.jpg (51.23 KiB) Viewed 18966 times
Destry's new KX500 in action
https://youtu.be/dv8FY0h0x64
Return to “Clutch”
