We should make Millennium happy with this order..
Remove sleeve, weld, install new sleeve, port match and grind the deck to clean up.
Rebuild the crank using a IMS Pro rod...
We even Vapor blasted the parts so that they would be nice and clean for them to work on
- 1988 RM250 ENGINE REBUILD WWW.OEM-CYCLE.COM 122.JPG (69.64 KiB) Viewed 8758 times
