UPDATING KX500 SUSPENSION.
KX500 WITH A KX450F REAR SHOCK 104.JPG (39.17 KiB) Viewed 80105 times
KX500 WITH A KX450F REAR SHOCK 105.JPG (37.14 KiB) Viewed 80105 times
Here is the issue with the clevis..
KX500 WITH A KX450F REAR SHOCK 106.JPG (71.83 KiB) Viewed 80104 times
OK... Sometimes you feel like a dummy...
I unscrewed the clevis off a 92 kx250 shock (Same as the KX500 clevis) and screwed it right on the KX450F shock.. 8-)
KX500 WITH A KX450F REAR SHOCK 107.JPG (99.24 KiB) Viewed 80102 times
Before I go any further, I need a mock up.
Turns out I just happen to have a few spares laying around...
Except for the stupid swingarm that I had to buy on eBay :?
WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 101.jpg (284.55 KiB) Viewed 79970 times
Why not bolt the KX450F shock to the 88 chassis and be done with it?
It is simply too long.
Here is a pic using the kx450f shock with it's stock clevis and bolted to the Uni Trak linkage
WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 103.jpg (414.73 KiB) Viewed 79941 times
Again, note the difference in the clevis length
WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 104.jpg (229.42 KiB) Viewed 79941 times
After swapping the clevis everything lines up perfectly
WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 105.jpg (208.76 KiB) Viewed 79941 times
WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 106.jpg (263.3 KiB) Viewed 79941 times
WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 107.jpg (282.35 KiB) Viewed 79941 times
Looks great!
But it does not work :shock: :o :shock:
Note the location of the shock reservoir.
Note that the reservoir goes right through the middle of where the pipe is suppose to go.
So the two choices I see is to reroute the pipe or move the reservoir...
More to come 8-)
Here is a quick vid to help you better understand what I'm running into:
https://youtu.be/IKh9uMr2l8Y
Ralow998
Post by Ralow998 »
Can I do this on my 91 KX 500 frame? Why does it look like the top bearing isn't pressed in? Can I use a shock from a KX 250F of the same year?
