Gotta get the Timesaver on the entire surface
- 20160215_170332.jpg (363.75 KiB) Viewed 9241 times
This is the typical trouble area for KX500's... Note where the dark grey is around the edges of the cases.
Then look at the yellow area.
The yellow area means that the cases have a gap there.
- 20160215_170500.jpg (379.77 KiB) Viewed 9241 times
So rub rub rub... swirl swirl swirl... rub rub rub... swirl swirl swirl... rub rub rub... swirl swirl swirl... rub rub rub... swirl swirl swirl...
- 20160215_171724.jpg (332.98 KiB) Viewed 9241 times
Now they are dark grey all around which means they are ready for clean up, porting, and repair,,
