1999 Kawasaki KX250 engine build for Rusty
Customer came in with most of his own parts for this build so I won't print out a list but rest assured there is plenty being replaced :lol:
We just got the crank back from Millennium Tech with a Wossner rod kit installed.
Cases have been lapped, modded, and cleaned, and we are ready to start the build.
1999 kx250 engine build oem-cycle.com 102.jpg (182.01 KiB) Viewed 7273 times
1999 kx250 engine build oem-cycle.com 101.jpg (147.16 KiB) Viewed 7273 times
Re: 1999 Kawasaki KX250 engine build for Rusty
Dropped in some bearings, seals, and a Wossner rodded crank :-)
1999 kx250 kawasaki engine build oem-cycle.com 101.JPG (85.2 KiB) Viewed 7265 times
Getting things lined up...
1999 kx250 engine build oem-cycle.com 103.jpg (258.76 KiB) Viewed 7263 times
1999 kx250 kawasaki engine build oem-cycle.com 104.JPG (53.04 KiB) Viewed 7259 times
1999 kx250 kawasaki engine build oem-cycle.com 103.JPG (92.33 KiB) Viewed 7259 times
1999 kx250 kawasaki engine build oem-cycle.com 102.JPG (71.57 KiB) Viewed 7259 times
1999 kx250 kawasaki engine build oem-cycle.com 105.JPG (76.71 KiB) Viewed 7259 times
1999 kx250 kawasaki engine build oem-cycle.com 106.JPG (76.3 KiB) Viewed 7259 times
1999 kx250 kawasaki engine build oem-cycle.com 107.JPG (87.4 KiB) Viewed 7259 times
1999 kx250 kawasaki engine build oem-cycle.com 108.JPG (69.4 KiB) Viewed 7259 times
More cleaning and assembly.
Cometic gaskets, Wossner, piston, Wossner rod..
1999 kx250 kawasaki engine build oem-cycle.com 110.JPG (72.8 KiB) Viewed 7257 times
1999 kx250 kawasaki engine build oem-cycle.com 109.JPG (95.73 KiB) Viewed 7257 times
1999 kx250 kawasaki engine build oem-cycle.com 111.JPG (68.01 KiB) Viewed 7257 times
One last pic of this side before it's buttoned up
1999 kx250 engine build oem-cycle.com 114.jpg (159.86 KiB) Viewed 7256 times
A bit more progress
1999 kx250 engine build oem-cycle.com 119.jpg (263.82 KiB) Viewed 7183 times
1999 kx250 engine build oem-cycle.com 120.jpg (328.43 KiB) Viewed 7183 times
1999 kx250 engine build oem-cycle.com 121.jpg (295.74 KiB) Viewed 7183 times
