Building a 91 KX500 engine
Re: Building a 91 KX500 engine
Clutch basket repair...
Before
91 KX500 CLUTCH BASKET REPAIR OEM-CYCLE.COM 120.JPG (72.41 KiB) Viewed 10805 times
After
91 KX500 CLUTCH BASKET REPAIR OEM-CYCLE.COM 121.JPG (51.36 KiB) Viewed 10805 times
Jason is a master with a hand file and Scotch Brite :D
Drain plug repair is complete.
I like to make them a little deeper then stock so that you have more thread engagement and less chance of stripping in the future.
I also put WD40 in the case and let it sit over night to make sure it is not leaking before assembly.
91 KX500 DRAIN PLUG REPAIR OEM-CYCLE.COM 123.JPG (28.19 KiB) Viewed 10805 times
91 KX500 DRAIN PLUG REPAIR OEM-CYCLE.COM 124.JPG (10.38 KiB) Viewed 10805 times
Not quite factory but still functional.. :shock:
Clutch hub before
91 KX500 CLUTCH HUB REPAIR OEM-CYCLE.COM 125.JPG (40.56 KiB) Viewed 10803 times
After
91 KX500 CLUTCH HUB REPAIR OEM-CYCLE.COM 126.JPG (23.34 KiB) Viewed 10803 times
Not perfect but a whole lot better then before.
This should provide a little easier clutch pull.
Getting the clutch plates pre oiled..
91 KX500 CLUTCH PRE OILING OEM-CYCLE.COM 127.JPG (66.51 KiB) Viewed 10802 times
Crofter985
Post by Crofter985 »
Nice work mike. Good to see that timesaver stuff in action, I did not lap my cases, perhaps I should have. I guess if they don't leak oil they are ok?
Anyway it's going to be one clean and pretty engine when it's done.
If you have no leaks most likely you are ok.
Four strokes don't have as many issues with air leaks that the two strokes do.
If you have a hard time getting the timesaver let me know and I will pick you up a can.
Crofter985
Do you know how much it would be to ship a couple of cranks, a set of cases and a head of you have one? Like if they were all in a box. FedEx or a company like that would probably be best, Eh? And how much for the parts?
I'll see what I can do for you...
As if it weren't clean enough already...
91 KX500 OEM-CYCLE.COM MORE CASE CLEANING 106.JPG (94.98 KiB) Viewed 10788 times
