Drain plug repair is complete.
I like to make them a little deeper then stock so that you have more thread engagement and less chance of stripping in the future.
I also put WD40 in the case and let it sit over night to make sure it is not leaking before assembly.
- 91 KX500 DRAIN PLUG REPAIR OEM-CYCLE.COM 123.JPG (28.19 KiB) Viewed 10767 times
- 91 KX500 DRAIN PLUG REPAIR OEM-CYCLE.COM 124.JPG (10.38 KiB) Viewed 10767 times
