Removing the KX500 Auxiliary exhaust port walls
All about your top end :-)
I always wanted to try this but never had the correct tools to try it.
Now that I dumped a wad of cash at CC Specialties I'm ready to give it a go.
While this is a practice cylinder I don't want to ruin it as there is some interesting plans for it... :shock:
Test subject
KX500 AUXILLARY EXHAUST PORT WALL REMOVAL WWW.OEM-CYCLE.COM 101.JPG (29.17 KiB) Viewed 7049 times
Here's goes nothing...
KX500 AUXILLARY EXHAUST PORT WALL REMOVAL WWW.OEM-CYCLE.COM 102.JPG (26.35 KiB) Viewed 7049 times
Making progress
KX500 AUXILLARY EXHAUST PORT WALL REMOVAL WWW.OEM-CYCLE.COM 103.JPG (13.57 KiB) Viewed 7049 times
Re: Removing the KX500 Auxiliary exhaust port walls
Since I run a decompression head I don't need the little decompression reliefs so on my person version I will weld them in and blend them in.
That way I will be able to have a greater trapped volume :geek:
KX500 AUXILLARY EXHAUST PORT WALL REMOVAL WWW.OEM-CYCLE.COM 104.JPG (14.23 KiB) Viewed 7048 times
When I'm done they should look like this only smoother ;)
KX500 AUXILLARY EXHAUST PORT WALL REMOVAL WWW.OEM-CYCLE.COM 105.JPG (22.65 KiB) Viewed 7048 times
This is all for now.
Still gotta weld up the compression reliefs so no sense getting carried away.
KX500 AUXILLARY EXHAUST PORT WALL REMOVAL WWW.OEM-CYCLE.COM 106.JPG (164.58 KiB) Viewed 7043 times
When welded, bored, and plated, the exhaust port will look like this
Looking from the main exhaust port, this is what the stock sub ports look like
When we are done, they look like this
Although this is looking at the opposite side from the last pic...
Return to “Top End”
