A few people have asked me about how well the Kawasaki engine fits in the CR250 frame.
So, here is a few more pics.
A few notes, the swing arm pivot pin is the same diameter 17mm.
The bottom engine mounts line up perfectly with the Kawasaki mounts.
The exhaust port clears the frame and the pipe is a nice fit.
So, you would need head stay mounts and some adapter mounts for the front engine mounts.
More KX to CR pics
- OEM-CYCLE.COM 2007 KX250AF BUILD 109.JPG (102.77 KiB) Viewed 11384 times
- OEM-CYCLE.COM 2007 KX250AF BUILD 110.JPG (87.54 KiB) Viewed 11384 times
- OEM-CYCLE.COM 2007 KX250AF BUILD 111.JPG (93 KiB) Viewed 11384 times
