2007 KAWASAKI KX250AF BUILD
A buddy of mine has a 03 KX250 engine complete, fully rebuilt and looking for something to stick it in to.
It just so happens that I have a 2007 KX450F frame.
So we stuck the engine in it to see what would happen.
And of course the frame yoke is too low to let the exhaust pipe out :o But then we knew that. :D
Next thing I know my buddy pulled a 01 cr250 frame from storage and drops the engine in...
PS... This engine is a 95 KX250 that was handy for fitment purposes.
OEM-CYCLE.COM 2007 KX250AF BUILD 100.JPG (66.94 KiB) Viewed 11392 times
OEM-CYCLE.COM 2007 KX250AF BUILD 101.JPG (85.11 KiB) Viewed 11392 times
OEM-CYCLE.COM 2007 KX250AF BUILD 102.JPG (68.09 KiB) Viewed 11392 times
Re: 2007 KAWASAKI KX250AF BUILD
OEM-CYCLE.COM 2007 KX250AF BUILD 103.JPG (98.11 KiB) Viewed 11391 times
OEM-CYCLE.COM 2007 KX250AF BUILD 104.JPG (94.04 KiB) Viewed 11391 times
OEM-CYCLE.COM 2007 KX250AF BUILD 105.JPG (87.62 KiB) Viewed 11391 times
OEM-CYCLE.COM 2007 KX250AF BUILD 106.JPG (98.73 KiB) Viewed 11391 times
OEM-CYCLE.COM 2007 KX250AF BUILD 107.JPG (80.87 KiB) Viewed 11391 times
OEM-CYCLE.COM 2007 KX250AF BUILD 108.JPG (102.28 KiB) Viewed 11391 times
The amazing thing is how well the engine fit..
But then I don't want to end up with a Kawaonda or a Honasaki...
After just a few minutes of looking at it my buddy has a brilliant plan...
More later :shock:
A few people have asked me about how well the Kawasaki engine fits in the CR250 frame.
So, here is a few more pics.
A few notes, the swing arm pivot pin is the same diameter 17mm.
The bottom engine mounts line up perfectly with the Kawasaki mounts.
The exhaust port clears the frame and the pipe is a nice fit.
So, you would need head stay mounts and some adapter mounts for the front engine mounts.
More KX to CR pics
OEM-CYCLE.COM 2007 KX250AF BUILD 109.JPG (102.77 KiB) Viewed 11387 times
OEM-CYCLE.COM 2007 KX250AF BUILD 110.JPG (87.54 KiB) Viewed 11387 times
OEM-CYCLE.COM 2007 KX250AF BUILD 111.JPG (93 KiB) Viewed 11387 times
OEM-CYCLE.COM 2007 KX250AF BUILD 113.JPG (70.21 KiB) Viewed 11387 times
OEM-CYCLE.COM 2007 KX250AF BUILD 112.JPG (66.99 KiB) Viewed 11387 times
Here's how if fits in the KX450F Frame..
OEM-CYCLE.COM 2007 KX250AF BUILD 114.JPG (110.16 KiB) Viewed 11387 times
OEM-CYCLE.COM 2007 KX250AF BUILD 115.JPG (85.25 KiB) Viewed 11387 times
OEM-CYCLE.COM 2007 KX250AF BUILD 116.JPG (83.29 KiB) Viewed 11387 times
OEM-CYCLE.COM 2007 KX250AF BUILD 117.JPG (95.99 KiB) Viewed 11387 times
OEM-CYCLE.COM 2007 KX250AF BUILD 118.JPG (75.9 KiB) Viewed 11387 times
Ok.... Everything else was just talk till now.
Too late to back out now :lol:
OEM-CYCLE.COM 2007 KX250AF BUILD 119.JPG (95.77 KiB) Viewed 11369 times
OEM-CYCLE.COM 2007 KX250AF BUILD 120.JPG (65.32 KiB) Viewed 11369 times
Ok, now it is really to late....
OEM-CYCLE.COM 2007 KX250AF BUILD 121.JPG (223.87 KiB) Viewed 11367 times
