I don't know but I am going to find out.
I have seen the youtube vids and read all the hype.
They have been using them in Europe for many decades but you never hear of them over here..
Here's some pics
What is Vapor or Aqua blasting?
Instead of using just sand or glass beads it also uses water.
So instead of cleaning by impacting media onto the surface to be cleaned, it cleans by flow.
So it does not embed itself onto softer surfaces.
It actually peens the surface
Because of this cleaning by flow, you get a much smoother surface and also a shinier surface.
I purchased a Small Vixen Vapor Blaster that has been reconditioned.
Today I drove to Portland and picked up a compressor to run it.
At 600lb it made my Yoda a bit top heavy.
After I get everything installed and running I will do some experimenting and post the results.
If it works as hoped I will start offering vapor blasting services.
