Vapor Vapour or Aqua Blasting, Is it worth the expense?
General discussion.
What's on your mind?
I don't know but I am going to find out.
I have seen the youtube vids and read all the hype.
They have been using them in Europe for many decades but you never hear of them over here..
Here's some pics
vapor blasting 2.jpg (166.88 KiB) Viewed 17821 times
vapor blasting 3.jpg (111.17 KiB) Viewed 17821 times
vapor blasting 4.jpg (98.84 KiB) Viewed 17821 times
vapor blasting 5.jpg (157.35 KiB) Viewed 17821 times
What is Vapor or Aqua blasting?
Instead of using just sand or glass beads it also uses water.
So instead of cleaning by impacting media onto the surface to be cleaned, it cleans by flow.
So it does not embed itself onto softer surfaces.
It actually peens the surface :shock:
Because of this cleaning by flow, you get a much smoother surface and also a shinier surface.
I purchased a Small Vixen Vapor Blaster that has been reconditioned.
Today I drove to Portland and picked up a compressor to run it.
At 600lb it made my Yoda a bit top heavy.
After I get everything installed and running I will do some experimenting and post the results.
If it works as hoped I will start offering vapor blasting services.
foxx4Beaver
Re: Vapor or Aqua Blasting, Is it worth the expense?
Post by foxx4Beaver »
judging by the looks of those pics of the engine pieces, it looks more than "worth the expense" to me...hell, if you find that your set-up works well, I might send you some parts to blast! :D
Yeah I'm sure there is a learning curve figuring out the correct media, which detergent, and also what corrosion inhibitor to use.
But I'm sure getting excited about it :D
Got the compressor out of the truck and on to the floor.... But that's all I did :x
Here's my spoiled 15 year old kid standing next to it.
Re: Vapor Vapour or Aqua Blasting, Is it worth the expense?
Vapor blasting process is suitable for aluminum, Bronze, Magnesium, Titanium, Brass, Copper etc... It will gently clean the surface without damage and leave a nice satin finish which is very easy to keep clean.
However, any item that rusts can not be done with this process as the item oxidizes instantly.
vapor blasting 6.jpg (25.18 KiB) Viewed 17811 times
vapor blasting 7.jpg (61.4 KiB) Viewed 17811 times
vapor blasting 8.jpg (70.3 KiB) Viewed 17811 times
The company that I purchased the vapor blaster from says that they should be shipping it to me on or around the 10th of this month.
I guess we'll see.
Just anxious to get this puppy in action :lol:
Here's a article from Vixen a manufacture of quality Vapor Blasters
http://www.vaporblastingequipment.com/w ... ng-process
Getting closer to being done..
VAPOR BLASTER 1.JPG (88.18 KiB) Viewed 17738 times
VAPOR BLASTER 2.JPG (86.16 KiB) Viewed 17738 times
VAPOR BLASTER 3.JPG (102.16 KiB) Viewed 17736 times
The vapor blaster came in today ... Whoopie!!!!
Opened the back of the truck and found this.
Pic as seen from in the truck.JPG (76.57 KiB) Viewed 17649 times
Damage as noted so far...
Bent leg
bent leg.JPG (37.06 KiB) Viewed 17649 times
Glass pulled loose from the seal that covers the lights on the lid.
glass has pulled loose from the seal.JPG (29.07 KiB) Viewed 17649 times
The top is bent
top is bent.JPG (23.03 KiB) Viewed 17649 times
top is bent 2.JPG (27.5 KiB) Viewed 17649 times
Wires were pulled loose from the electrical box
wires pulled from the box.JPG (38.09 KiB) Viewed 17649 times
Nice!!!
