CR125 SERVICE SPECIFICATIONS
HONDA CR125 Measurements, Specs, pics
ELECTRICAL
1992-1997
STATOR COIL ASSEMBLY
EXCITER COIL RESISTANCE BLUE to WHITE: 20-140 ohms
Pulse coil resistance Blue/Yellow to White/Green: 180-280 ohms
Ignition coil
Primary resistance (Small wire) .4-.6 ohms
Secondary resistance with spark plug cap (Big Wire) 14-23K ohms
Secondary resistance with NO spark plug cap (Big Wire) 10-16K ohms
89-91 CR125
If the electrical does not work then you need to test the OHM specs of your coil, stator, check your kill switch, and all your connections.
On the stator test Blue to White 40-140 ohm.
On the pulse generator test Green/White to Blue/yellow 180-280 ohm.
On the Coil test the Primary lead Black/Yellow to Green .4-.6 ohm.
On the Coil test the Secondary lead (Sparkplug wire with the cap on it) to Black/Yellow 14k-23k ohm
ENGINE 1992-1997
Crank shaft big end side clearance 81-88 cr125
.15-.60mm or .006-.024"
Service limit .70mm or .028"
Re: CR125 SERVICE SPECIFICATIONS
Return to “HONDA CR125 Measurements, Specs, pics”
