- motorrads impeller mods 9-2.png (412.29 KiB) Viewed 28465 times
- motorrads impeller mods 9-3.png (643.99 KiB) Viewed 28465 times
- motorrads impeller mods 9-4.png (699.69 KiB) Viewed 28465 times
That is already in the works... I'm sending my head to Motorrad for a little work... Then install the new modded gasket.Qsixteen wrote:All those holes will flow 3x more water then most MX cooling system could flow. You could make the holes larger then go out and test it on the street with your SM bike.
