Ok, enough monkey business.
The following pics are of a 89 kx250 clutch cover sitting on top of my cut down kx500 inner clutch cover.
As you can see, you can make an adapter for it but then you are stuck buying a used clutch cover any time you break yours...
- 89 kx250 clutch cover on a kx500 inner clutch cover 1.jpg (282.07 KiB) Viewed 27533 times
- 89 kx250 clutch cover on a kx500 inner clutch cover 2.jpg (246.44 KiB) Viewed 27533 times
