KX100 KAWASAKI SERVICE SPECIFICATIONS
KX100 MEASUREMENTS SPECS PICS
Need some measurements for that special project?
We can help
Oil Level: .69 US Qt or 65L
Radiator Coolant: .71 US Qt or .67L
Crank shaft and connecting rod specs
Connecting Rod Big End Radial Clearance (Sometimes called vertical play)
Standard: 0.029 - 0.041 mm (0.0011 - 0.0016 in.)
Service Limit: 0.09 mm (0.0035 in.)
Connecting Rod Big End Side Clearance
Standard: 0.40 - 0.50 mm (0.016 - 0.20 in.)
Service Limit: 0.7 mm (0.028 in.)
Crankshaft Runout
Standard: TIR 0.03 mm (0.0012 in.) or less
Service Limit: TIR 0.08 mm (0.0031 in.)
Re: KX100 KAWASAKI SERVICE SPECIFICATIONS
7-29-13 added:
Crankshaft Runout
Return to “KX100 MEASUREMENTS SPECS PICS”
