Here is a view from the side to show just how much further the reed valve has to go into the cylinder and it is already touching on the top and bottom.
- V FORCE 3 KX500 4.PNG (895.96 KiB) Viewed 18431 times
By the time you install the reed all the way in look how far it is pinching shut
- V FORCE 3 KX500 5.PNG (1.13 MiB) Viewed 18431 times
Here is the side view of the same thing.
- V FORCE 3 KX500 6.PNG (1.12 MiB) Viewed 18431 times
- V FORCE 3 KX500 7.PNG (770.6 KiB) Viewed 18431 times
This view shows how much material would have to be removed in order for the reed to be able to fully open.
While the cylinder could be opened up enough on top to make that happen, the bottom is too thin.
It's hard to see from the picture but the 3 "X"'s are part of the excess casting.
If I removed it you would see that the bottom would be extremely thin, and I suspect it would probably break all the way through
Even if it did open up that much you would probably loose velocity.....
- V FORCE 3 KX500 8.PNG (828.91 KiB) Viewed 18430 times
As you can see, this is not really the best of designs..
