Tires won't be here till next week... :(
Oh well, I can still ride I just hate knobbie slides :D
I need to figure out how to carry some premix oil.
I like this idea:
kx500sm oil mount.png (95.68 KiB) Viewed 12714 times
Well.... I was way off.
How about some Pirelli Diablo Supercorsa's.
Front 120/70 ZR17
Rear 160/60 ZR17
I know... The rear will rub...
I didn't want a 160 in the rear, I wanted a 150.
My tire guy said he couldn't get what I wanted in a 150... (Cheap but awesome, actually trade)
I measured it at 155mm.
I measured what is on my bike right now and it is very close.
I guess we'll see when I get it mounted.
Unfortunately it won't be till next week as too much is happening right now..
These were mounted on a bike that took a couple of laps.
Still tons of life left :-)
KX500 SUPERMOTO WARP 9 WHEEL AND TIRES 1.JPG (101.99 KiB) Viewed 12211 times
KX500 SUPERMOTO WARP 9 WHEEL AND TIRES 2.JPG (96.43 KiB) Viewed 12211 times
KX500 SUPERMOTO WARP 9 WHEEL AND TIRES 3.JPG (34.64 KiB) Viewed 12211 times
Back from a Family riding emergency wink
Took the SM down and rode trails and gravel roads with a bald knobbie and ridiculous high gearing.
Can you say "Constant wheel spin?"
It was 75F and beautiful.
Max head temp 202F.
Max coolant temp 185F.
That was after riding for about 30 minutes and then sitting at idle for about 5 minutes.
Average head temp 160-170F
Average coolant temp 145-155F
I'll be pulling the clutch cover off and inspecting everything to see if I can find something unusual.
Been waiting for over a month for my clutch cover gaskets to come in.
It's time to light a fire as I have already called once....
Started playing with the rear wheel fitment...
It's tight..... I'm going to switch to a non O-ring chain...
KX500 SUPERMOTO WARP 9 WHEEL AND TIRES 5.JPG (95.18 KiB) Viewed 12183 times
KX500 SUPERMOTO WARP 9 WHEEL AND TIRES 6.JPG (52.77 KiB) Viewed 12183 times
Friar-Tuck
Post by Friar-Tuck »
NICE! :mrgreen:
When I get it done you'll need to come up for a ride :D
Friar-Tuck
SB it would be an Honor to hang out with you guys. It will take me some time to get caught up, however
a trip up your way is first up on my list after current obligations have been met.
Tuck\o/
So I picked up a set of Works Connection Frame guards.
The right side was a breeze and took all of about 2 minutes to install.
The left side wouldn't be bad except that I am using the Pro Motion Side stand and of course the two interfere with one another.. :o
SIDE STAND AND FRAME GUARD INTERFERENCE.JPG (72.75 KiB) Viewed 11968 times
I'm thinking about cutting the frame guard around the side stand as I have indicated in yellow.
It will still bolt up and work just fine but I was hoping for a better solution...
SIDE STAND AND FRAME GUARD INTERFERENCE 2.JPG (32.69 KiB) Viewed 11968 times
Ok, After getting the wheels on the bike I measured the highest part of the seat at 38.5".
The lowest part of the seat is at 35.5".
Taking it for my first ride with the new tires on it... :-o
Simply Ridiculous 8-)
KX500 SM 2001 KAWASAKI WARP 9 WHEELS 1.JPG (56.1 KiB) Viewed 11962 times
KX500 SM 2001 KAWASAKI WARP 9 WHEELS 2.JPG (102.33 KiB) Viewed 11962 times
