KX500 with aluminum tank and 98 kx250 plastics
This bike was found on Craigslist:
LOOKING FOR A 2 STROKE 500 ? YOU CAN'T DO BETTER THAN THIS ONE !" 94 " GREEN STICKERED TILL JUNE 2015 . CUSTOM ALUMINUM GAS TANK . "98"KX-250 SUBFRAME , AIRBOX , SEAT , MUFFLER AND PLASTIC . LIGHTER THAN STOCK WITH BETTER ERGONOMICS , THIS MOD MADE THE BIKE HANDLE MUCH BETTER IN TIGHT CORNERS . NEW CROME BORE WITH 1 HR ON NEW PISTON . MOTO TASINARI V-FORCE REEDS , MILD PORT WORK ( CLEANED AND SMOOTHED OUT , HELPED MID RANGE POWER ) FMF GNARLY PIPE WITH SHORTY KX 250 MUFFLER WITH CORE INCREASED TO 500 SIZE . ANSWER PRO TAPER BARS . PRO CIRCUIT BILLET FOOTPEGS AND LEFT SIDE MOUNT . BOYESON ALUMINUM IGNITION COVER . TALON WHEELSET ($1,100 WHEN NEW ) .OVERSIZE FRONT BRAKE ROTOR . SOLID REAR ROTOR ( DOESN'T CHATTER LIKE STOCK ) 15 HRS ON NEW kx 500 FRAME (NOT SQUIRLEY LIKE A LOT OF "Aluminum Frame"500's -PURCHASED NEW IN 2000 , 15 HR.s ). TIRES , O-RING CHAIN AND SPROCKETS 80% LEFT . COMES WITH SPARE CASES , SOME PARTS AND A SPARKY SPARK ARRESTOR BIKE IS EXTREMELY FAST ( faster than my 2010 yz 450 ! ) AND READY TO RIDE . if add is up , bike is still for sale .
kx500 modded with 98 kx250 parts 1.png (447.37 KiB) Viewed 4023 times
kx500 modded with 98 kx250 parts 2.png (451.04 KiB) Viewed 4023 times
kx500 modded with 98 kx250 parts 3.png (442.64 KiB) Viewed 4023 times
kx500 modded with 98 kx250 parts 4.png (464.92 KiB) Viewed 4023 times
