KX125 SERVICE SPECIFICATIONS
KX125 Kawasaki Measurements, Specs, pics
KX125 STATOR SPECS
84-87 KX125 STATOR SPECS
BLACK TO BLUE 122-182
BLUE TO WHITE/RED 63-95
BLACK TO WHITE/RED 178-266
89 KX125 STATOR SPECS
BLACK/WHITE TO BLACK/YELLOW 376-564
WHITE/RED TO WHITE/GREEN 176-264
91 KX125 STATOR SPECS
Red to Black/Red 417-627 ohms
White/Red to White/Green 188-283 ohms
White to Ground 14.3-21.5 ohms
92-93 KX125 STATOR SPECS
White/Red to White Green 396-594 Ohms
Red to Black/Red 288-432 Ohms
White to Red 14-21 Ohms
94-98 KX125 KX250 Stator Specs
White/Red - White/Green 396-594 Ohms
Red - Black/Red 288-432 Ohms
White - Red 14-21 Ohms
00-01 KX250, 00 KX125 STATOR SPECS
While to Red 7-15 Ohms
Yellow/While to Yellow 1-5 Ohms
KX125 STATOR OHM SPECS.JPG (152.55 KiB) Viewed 15048 times
Jetting
1997 Kawasaki KX125 Jetting
Here is some common jetting numbers based on sea level riding, after market pipe, and 32:1 premix.
Check your jetting against these numbers.
Main 158
Pilot 38
Needle NIAK
Needle position 3RD
Air screw turns 1 1/4
Re: KX125 SERVICE SPECIFICATIONS
Added stator specs for 84-87 KX125
8-1-13 added
Jetting
Main 158
Pilot 38
Needle NIAK
Needle position 3RD
7-30-16 ADDED
8-16-16 ADDED
11-16-16 ADDED STATOR SPECS FOR A 89 KX125
Return to “KX125 Kawasaki Measurements, Specs, pics”
