Nuvite New Shine II Review
This is a Motorrad recommended and approved product.
I just ordered some and can't wait to try it out :-)
NUVITE NUSHINE II.PNG (318.18 KiB) Viewed 14098 times
Photo courtesy of our in house hand model Motorrad.
Re: Nuvite New Shine II Review
Post by Motorrad »
You must be rich. hiring hand modles of that caliber just for this thread
Kx550 Power By
Yeah, he was very expensive.
But worth every penny. :D
My Nuvite arrived yesterday.
Sorry, no fancy hand models with these pics.. :)
Here is pics of the can:
NUVITE NUSHINE II - 1.PNG (336.15 KiB) Viewed 14078 times
NUVITE NUSHINE II - 2.PNG (226.27 KiB) Viewed 14078 times
NUVITE NUSHINE II - 3.PNG (176.26 KiB) Viewed 14078 times
Pretty simple instructions so lets get this test going...
What I have here is a rough cut piece of aluminum bar stock.
It's not something that I would normally try to polish without a little sanding or lapping first but for the sake of this test it's a go..
As you can see, this bar stock is very rough so this will show the cutting qualities of the polish.
NUVITE NUSHINE II - test piece 1.PNG (307.1 KiB) Viewed 14078 times
This wouldn't be a good test without some competition so I am using some Mothers Mag and Aluminum polish to compare it against :)
In this pic I have used a simple shop rag (Not the best for either product) and applied it sparingly and rubbed each side 100 times and then cleaned it.
As you can see the Nuvite jumps out to an early lead in how it shines.
I'm guessing that since the Nuvite feels grittier then the Mothers that it is cutting better.
NUVITE NUSHINE II - test piece 2.PNG (585.77 KiB) Viewed 14078 times
Again using the same rag and buffing pattern (Round and round) I have 300 total rubs on each side.
It's kind of hard to tell from the pics but the Nuvite continues to hold a lead.
NUVITE NUSHINE II - test piece 3.PNG (488.95 KiB) Viewed 14078 times
Again using the same rag and buffing pattern (Round and round) I have 500 total rubs on each side.
Yes, my arm is getting very tired by now ;)
Again the Nuvite looks better.
NUVITE NUSHINE II - test piece 4.PNG (843.35 KiB) Viewed 14078 times
So the last pic is with 1000 rubs on both sides.
Both products did a fair job but it is clear that the Nuvite is superior in how fast it cuts raw rough aluminum.
NUVITE NUSHINE II - test piece 5.PNG (1.05 MiB) Viewed 14078 times
Since most of us won't be using either of these products I will continue testing on other parts as the need arrives so stay tuned.
Post by Motorrad »
Your using it wrong
Kx550 Power By
No doubt.
You mean I should follow the directions?
Apply Sparingly and polish with a terry towel or wool "compounding" pad on circular buffer (1600-2000 rpm) until polish and oxidation residue disappears (About 60 seconds).
That takes all the fun out of it.
I'm saving that for the hi gloss stuff to be done later but I may go back and re-do the rough aluminum just to see what difference it makes.
Post by Motorrad »
Sandblaster wrote:No doubt.
nope.. dont follow the instructions either..
Ever notice how the alum on the british motorcycles around here GLOWS...
Kx550 Power By
Yep I have seen your beautiful bikes before.
Never in person.... Yet.....
So what is your secret to getting the surfaces so nice?
Post by Motorrad »
Do you have a harbor freight near you? or any welders supplys
Kx550 Power By
Return to “Product Review”
