01 kx500 kawasaki parts for sale
If the parts are still here then they are still available...
Carburetor 100.00 the float pin mount, on one side is broken but still functional
Rear shock with spring for 220lb rider
Shock arm linkage 100. All the bearings are good
Re: 01 kx500 kawasaki parts for sale
Front wheel hub and brake rotor, Good bearings. 100.00
Shock mounts 25.00
Swing arm pivot pin 15.00
Swing arm 100.00 All the bearings and adjustment bolts are good.
Radiator screens 25.00
Clutch basket. Has some moderate to heavy wear but still works. 40.00
Clutch Inner clutch hub 40.00
Clutch pressure plate 25.00
