KX500 water pump modification
Yeah, I think it's time to mash up the homies and huck my modded xr80 fo some syck air, now that I have that behind me :lol:
I know, you were all hoping this would go away but..... There is some restrictions that can be reduced.
Not as much as the cover but every little bit can help... Maybe...
Elbow 1.JPG (28.46 KiB) Viewed 14711 times
Elbow 2.JPG (28.28 KiB) Viewed 14711 times
Elbow 3.JPG (36.08 KiB) Viewed 14711 times
Elbow 4.JPG (15.74 KiB) Viewed 14711 times
Believe it or not, the round end has the most restriction :shock:
Without making your own elbows I'm not sure there is much else you can do to make the flow better in these pieces...
Post by Motorrad »
I have a sick idea
Kx550 Power By
You know I'm all about that :D
Post by Motorrad »
Sandblaster wrote:You know I'm all about that :D
:twisted:
2 things sparked the idea.
the bike you just dismantled.. (only idea came from it.. dont need the part) http://www.ebay.com/itm/YZ400F-YAMAHA-1 ... 460e5fca8a
and one of the kx450 rad hoses.
Tig Torch requred :lol:
I need to dig out one of my extra CYL heads.. and cut it up to see some stuff first.
Kx550 Power By
No problem.
I have the part on hold, so if you need it for decontruction your welcome to it :D
Post by Motorrad »
Sandblaster wrote:No problem.
no.. wont need it.
was only an idea (the way it is designed) would have to fabricate parts....
god its so tempting to just make an adaptor plate and bolt up a GSXR1000, BUSA, R1, etc....... waterpump................. of course.. then it may pump too much and cause cavitation in the radiators.
Kx550 Power By
Here's a quote from Larry Wiechman who does some really cool mods.
"I went through this same crap 23 years ago. Has it occurred to you that the coolant is flowing the wrong direction?
Maximum heat transfer at maximum delta T.
It's hard to cool the hottest component, the head, with a fluid that has already been heated by the cylinder.
A higher pressure radiator cap, minimal antifreeze concentration and lots of coolant flow is a good start.
Be cool man...
Larry"
Thanks Larry.
Looking into it :D
Friar-Tuck
Post by Friar-Tuck »
The Cyl head does operate at a higher temp than the cyl, but if you reversed the flow, the higher temp of the cyl head would heat the cyl. no?
The cyl doesn't see the temp of the head,(Hopefully) so although the coolant is absorbing heat from the cyl, it will still be lower than the cyl head temp.
So I'm thinking the (now heated) coolant is still able to absorb heat from cyl head (because of the higher temp differential).
I agree the theory of cooling the hottest part of the system with the lowest temperature of the return coolant would give you the lowest cyl head temp.
For me this raises two more questions,how much more will this raise the operating temp of the cyl?
And would this raise the whole system temp?
Does this make any sense?
Tuck\o/
