KX500 water pump modification
That will be sweet!
But until I do, the saga continues... :o
Post by Motorrad »
have you considered what this big ass hole does to the flow?
If I were on this mission of counting my pennys. Id tig it up, and smooth it out to match .. then if you want to drain the system, either pull the cover, or pull the lower hose...
Kx550 Power By
Awesome!
4 more cent's into the morass of my life :D
Here is where I am currently...
kx500 water pump cover modification 1.JPG (56.72 KiB) Viewed 12641 times
KX500 WATER PUMP IMPELLER CLEAnup.JPG (17.89 KiB) Viewed 12641 times
I took the high edges off the impeller... No biggie.
Now that Motorrad gave me another idea I'll be working on that tomorrow :D Or not :shock:
Post by Motorrad »
For those of us with 100Watt of power on board.. we could always take the cheater way out.
Kx550 Power By
Yeah but what's the fun in that? :D
Mr, MZB :ugeek:
That is quite the flow.
I wonder how that compares with the clearanced cover and the motor at 6K?
Post by Motorrad »
Halfway down the page... Guy running system as total loss to see just that
http://www.cafehusky.com/threads/hi-flo ... 575/page-2
Kx550 Power By
Yeah, looks weak in comparison...
First trip to MR. Tig didn't work out so good :(
That's ok, he works right next door... :D
In all fairness he told me that he had trouble with it and this might be the result after I cleaned it up.
tig 1.JPG (62.28 KiB) Viewed 12622 times
tig 2.JPG (74.62 KiB) Viewed 12622 times
Frank The Tank
Post by Frank The Tank »
Looks like a nice drinkin fountain :D
