KX500 water pump modification
Motorrad wrote:
Sandblaster wrote:
Somthing I have been wanting to do.
is install a temp probe. instead of my Under the plug one that Digatron supplys.
Was thinking of welding a bung on the head, right at the output elbow...
just need to find a sensor etc that will talk to the digitron.
That would be cool... literally and figuratively. :D
I'm also wondering if we shouldn't clean up the casting imperfections on the impeller..
cleaning up the slag...png (711.96 KiB) Viewed 12624 times
I know it's a small thing but I bet they all add up..
Besides the kx500 I'm sure a lot of other bikes could benefit from these mods.
Post by Motorrad »
what is the drive ratio of the waterpump on the KX?
quick. I have an idea.
Kx550 Power By
Impeller speed vs crank speed?
Post by Motorrad »
Sandblaster wrote:Impeller speed vs crank speed?
Yup..
kinda like my KTM is driven off the cam.. direct.
Kx550 Power By
Off the top of my head.... I'm going to bed.
I'll let you know tomorrow... If you don't already know... :D
Qsixteen
Post by Qsixteen »
crank 13
impeller shaft 11
10-4 on the impeller gear... I had that number last night :)
Haven't made it to the shop yet for the crank :cry:
Yep, 13T on the crank. :D
0.84615384615384615384615384615385 :1 Or something like that :)
Post by Motorrad »
Sandblaster wrote:10-4 on the impeller gear... I had that number last night :)
hmm so they spin significantly faster than most 4 stroke impellers .5:1
Kx550 Power By
Didn't know this till a few minutes ago but regarding the water pump cover, the area just past the impeller is smaller then the outlet side.
WATER PUMP.JPG (56.67 KiB) Viewed 12597 times
I know I'm throwing more pennies at a million dollar problem but sooner or later the pennies should equal a buck or so :D
Qsixteen
Post by Qsixteen »
Or soon you will have the one million dollar issue fixed and it will be in your hand. :mrgreen:
