A little trimming of the pin...
A little grease in the tower...
A few bolts and it's done..
KX500 SCOTTS STEERING STABILIZER 2.JPG (52.64 KiB) Viewed 13094 times
KX500 SCOTTS STEERING STABILIZER 3.JPG (51.25 KiB) Viewed 13094 times
KX500 SCOTTS STEERING STABILIZER 4.JPG (41.67 KiB) Viewed 13094 times
Ok, enough of that noise.
I took my engine cases out, pressed out the bearings and seals, did a degreasing wash on them and started checking them for imperfections.
Wouldn't you know it, drain hole damage :x
DRAIN HOLE DAMAGE.JPG (30.64 KiB) Viewed 13089 times
And I already knew about this damage.
More damage.JPG (6.58 KiB) Viewed 13089 times
So off to tig weld they go...
Back from tig and sandblasting..
It helps when your buddy runs the weld shop right next door :D
after weld and sandblast.JPG (97.9 KiB) Viewed 13087 times
The drain hole fix turned out better then I expected.
after weld and sandblast 2.JPG (21.28 KiB) Viewed 13087 times
Now I need to make a decision.
Should I semi polish the cases, Paint them, or leave them raw?
I did some quick semi polish just to get an idea of what it would look like as you can see in the right side of the pic above as well as the drain hole.
What do you guys think?
Post by Motorrad »
I leave mine blasted finish.
from time to time I go over them with a scotchbrite pad (gray) and some WD40. keeps em looking nice. with... MINIMAL EFFORT.
it is a race bike........ yours being a street queen. you may get away with more than I do.
I didnt bust the case... I swear....
notice anything else done to those cases when you got them back ?? :roll:
Kx550 Power By
I know you didn't break it. :lol:
It was one of those things that is hard to see unless you start cleaning things up.
There was some grey sealant around the drain plug which is always a bad sign...
I didn't see anything that caught my attention that you might have done.
But then again I didn't really inspect them before I sent them for the trans experiment or when I got them back.
For inspections I need my nerd glasses on :geek:
What did I miss?
Post by Motorrad »
Sandblaster wrote:I know you didn't break it. :lol:
What did I miss?
I figured you would catch it too. as it was nice shiny fresh cut alum. against all the ugly alum backing.
Kx550 Power By
If I don't hold something far away I can't see anything but BLUR...
If I hold it far enough away to get rid of the blur, it's too far away to see...
It's probably too late now but I'll inspect them tomorrow with my nerd glasses on :geek:
I think I know where to look but wouldn't you know it, I don't have any pics of that view....
That means I have to wait all night to check it out...... :o
Post by Motorrad »
Sandblaster wrote:I think I know where to look but wouldn't you know it, I don't have any pics of that view....
Guess so. :lol:
or you can go look HARD at oscars motor thread ;)
Kx550 Power By
I had an emergency order to make but didn't have enough of an order to qualify for free shipping...
So.....
Stator cover.JPG (57.41 KiB) Viewed 13029 times
