What is my bike worth? 2006 Kawasaki klx 110
Feel free to ask.
I have a 2006 Kawasaki klx 110 that was barely ridden and has sat in my garage for about 2 years without being started. I wanted to finally sale because I have no use for it. I could really use the money to fix up my car. Based off the info I provide let me know how much I should let it go for and of you're interested let me know. Thanks in advance.
Pros: barely ridden, good condition, not abused.
Mods: pro taper handle bars, grips, fmf power core 4 exhaust system, upgraded seat, extended race pegs, and extended blue shifter.
Cons: the throttle is locked up from sitting so long, so the carb just needs to be cleaned. And it won't start but I believe it's because the carb is gunked up and that gas has been sitting.
My answer:
Hello.
If your bike is running you can go to http://www.kbb.com and look up the trade in value vs. full retail.
Generally you will get somewhere in between.
Bike does not run?
You can only get what someone will offer.
My suggestion?
Clean the carb, make it run good and then advertise it at full retail but be prepared to negotiate.
