Arik Swans KX500AF
Arik Swans KX500AF
Post by Sandblaster » Thu Nov 11, 2021 8:11 am
Arik brought us his AF bike last year for a electrical problem.
As it turns out the crank and case bearing bosses were bad so it turned into a full rebuild..
I pulled the engine and took it apart.
Then I sent it Jason at JT Engine Works for a full rebuild.
Re: Arik Swans KX500AF
Post by Sandblaster » Fri Nov 12, 2021 6:59 pm
As you can see, Jason did his usual super clean engine build.
Jason did his super MX port work, balanced the crank, adjusted the compression and she will be a MX destruction machine... 8-)
Users browsing this forum: No registered users and 14 guests
