How to fix your drain plug without splitting your cases
So, your sick and tired of your drain plug leaking but you don't want to split your cases?
I would much rather do this with a bare case but it can be done without splitting the cases.
Here is the way we typically do it.
Number one... WASH YOUR BIKE!!!!!
Don't do it dirty as you will risk getting dirt in your engine...
Geese!!!!
Next lay your bike on it's side... No... Don't drain the oil first..
You will be using your old oil to help flush the engine...
OEM-CYCLE.COM KX500 DRAIN PLUG REPAIR 101.JPG (160.64 KiB) Viewed 30356 times
Now remove the drain plug but be prepared for a little more oil to come out depending on how far the bike is laid over.
Did I mention you need one of these? Oops!
OEM-CYCLE.COM KX500 DRAIN PLUG REPAIR 102.JPG (58.4 KiB) Viewed 30355 times
This is for a KX500 and most of Kawasaki's Dirt bikes use the same thread size which is a M10 x 1.5
You will also need some grease, and a 13/32" drill bit or .406" or about a 10MM, and some thread locker.
OEM-CYCLE.COM KX500 DRAIN PLUG REPAIR 103.JPG (58 KiB) Viewed 30355 times
Re: How to fix your drain plug without splitting your cases
You may want to double check your drill bit size to be sure it is accurate.
This one is close enough:
OEM-CYCLE.COM KX500 DRAIN PLUG REPAIR 104.JPG (78.36 KiB) Viewed 30355 times
So now all the oil is drained out that is going to come out.
Wipe it off and get your drill ready.
Take the drill bit and apply a liberal amount of grease to the end of it.
This will help prevent or greatly reduce any aluminum chips from getting into your engine case.
OEM-CYCLE.COM KX500 DRAIN PLUG REPAIR 106.JPG (41.23 KiB) Viewed 30355 times
What I do is drill almost all the way through then I clean off my drill bit and reapply a liberal amount of grease to it.
Once you break through, try not to rev the drill motor up... low RPM's at this point is better then high rpm's.
Pull the drill out and prep your tap by greasing it just like you did with the drill.
OEM-CYCLE.COM KX500 DRAIN PLUG REPAIR 107.JPG (40.31 KiB) Viewed 30355 times
Once again, stop when you are almost all the way through, clean the tap off, and reapply the grease.
Continue tapping until the tap goes at least a half inch into the motor to get full thread engagement.
When your done, back the tap out and clean any debris.
This is what your tap will look like...
OEM-CYCLE.COM KX500 DRAIN PLUG REPAIR 108.JPG (51.76 KiB) Viewed 30355 times
Next, holding one finger over the drain hole, have a buddy lift the bike back straight up.
Have the oil pan under the bike and release your finger.
Your old oil will now come out helping to clear out any debris that may have been left inside.
I actually had some partial bottles of ATF that I dumped into the cases and let that drain through as well.
OEM-CYCLE.COM KX500 DRAIN PLUG REPAIR 109.JPG (53.45 KiB) Viewed 30355 times
Pre test the length of your Helicoil.
They are a bit longer then required on the KX500..
OEM-CYCLE.COM KX500 DRAIN PLUG REPAIR 110.JPG (33.11 KiB) Viewed 30355 times
I like to pre cut mine to size but you can screw the Helicoil in and then gring it to size or use a pair of dikes to cut it.
I happen to have a diamond cutting tool for my porting tool so it works very nicely.. 8-)
OEM-CYCLE.COM KX500 DRAIN PLUG REPAIR 111.JPG (63.11 KiB) Viewed 30355 times
Put your plug in and test fit...
Pour in some new oil, warm it up, and go flog it :lol:
60something
Post by 60something »
I know this is an old thread, but dude, your hand!! :o
That looks like stitches were in order...(I was looking for a "passing out" emoji :lol:
2006 Kawasaki KDX200 qty-2
1987 Kawasaki KX500
1991 Honda CB750 Nighthawk
Lol...
Yeah, stitches should have been done but... I was busy so, tape it up and call it good.... :lol:
60something
:lol:
I have to say, I've done that before too. That was sure a bad one though.
1987 Kawasaki KX500
Hows that 87 running?
60something
Well, I'm about 2 years late in responding to "how's that '87 running", but here's the answer:
1. I got old before it was finished. Arthritis, tendonitis, backache-itis, and fatigue-itis set in big time. :lol: ...well that may be a tiny bit of hyperbole.
2. Winter came and it got too cold in the garage.
3. Summer came and it got too hot in the garage.
4. Like any project, after being away from it for a couple years, I lost interest.
5. Suddenly, I got fired-up after watching Derek Bieri of Vice Grip Garage fame encouraging us guys with unfinished projects to get busy on them.
6. I got started a few weeks ago, and I'm moving along right smartly now...
1987 KX500b.JPG (875.11 KiB) Viewed 5294 times
1987 Kawasaki KX500
