KX125 ENGINE, PARTS, AND FRAME Identification page
In an effort to help fellow bikers properly ID their bike I
have provided the following information on VIN ( Vehicle Identification Number )
, Engine ID and part identification.
If you find something that is not accurate, please let us know and we will fix
it.
This information is not intended for use outside of this web site or for
publication.
Remember, scroll to the right as there is a lot of data :-)
| YEAR | TYPE | ENGINE ID | ENGINE CASES | VIN FRAME USA | YEAR | AIR BOX CAGE ELEMENT HOLDER | AIR BOX - NO BOOT | YEAR | AIR BOX TO CARBURETOR BOOT | CABLE CLUTCH | CABLE FRONT BRAKE | CABLE THROTTLE | CARBURETOR | YEAR | CARBURETOR BOOT | CDI | CDI HOLDER DAMPENER | YEAR | CHAIN ADJUSTER BLOCKS | CHAIN GUIDE (ALUMINUM HOUSING) | YEAR | CHAIN GUIDE (PLASTIC BLOCK) | CHAIN SLIDE | CLUTCH ARM | CLUTCH BASKET | CLUTCH BASKET HINSON | YEAR | CLUTCH BASKET MITAKA | CLUTCH BASKET TALON | CLUTCH BASKET WISECO | CLUTCH COVER | YEAR | CLUTCH COVER INNER | CLUTCH HUB (INNER) | CLUTCH PRESSURE PLATE (OUTER) | YEAR | COIL | CONDENSOR | COUNTER SPROCKET GUARD (ALUMINUM) | COUNTER SPROCKET GUARD (PLASTIC) | CRANK SHAFT | CRANK SHAFT HOT RODS | CYLINDER | YEAR | ENGINE MOUNTS UPPER | EXHAUST FLANGE | EXHAUST PIPE | EXHAUST PIPE (FMF FATTY) | EXHAUST MUFFLER | EXHAUST VALVE SET | EXHAUST VALVE MAIN | EXHAUST VALVE LEFT | EXHAUST VALVE RIGHT | YEAR | EXHAUST VALVE COVER FRONT | EXHAUST VALVE COVER LEFT (RESONATOR) | EXHAUST VALVE COVER RIGHT | FLY WHEEL ROTOR | FOOT PEGS | YEAR | FOOT PEG SPRINGS | YEAR | FORK INFO | FORK SEAL SIZE | YEAR | FORK AXLE CLAMP | FORK GUARDS | FORK GUARD MOUNTS | YEAR | FORK UNDER HOLDER (STEERING STEM) | FORK UNDER HOLDER BEARING (STEERING STEM) | YEAR | FORK UNDER HOLDER BEARING MEASUREMENTS (STEERING STEM) | FORK UPPER HOLDER (TOP CLAMP) | YEAR | FORK UPPER HOLDER BEARING(TOP CLAMP) | YEAR | FORK UPPER HOLDER BEARING MEASUREMENTS(TOP CLAMP) | FRONT AXLE | FRONT AXLE HOLDER | YEAR | FRONT BRAKE CALIPER | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE HOSE | FRONT BRAKE LEVER | FRONT BRAKE MASTER CYLINDER | YEAR | FRONT BRAKE ROTOR | FRONT FENDER | YEAR | FRONT HUB | GAS TANK | YEAR | GAS TANK CAP | GOVERNOR SPUR GEAR | YEAR | GOVERNOR GUIDE | GOVERNOR ROD | GOVERNOR SHAFT | GOVERNOR WEIGHT HOLDER | YEAR | HEAD | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | MUD FLAP | YEAR | NUMBER PLATE | OIL CAPACITY | OIL DRAIN PLUG | YEAR | PETCOCK FUEL VALVE TAP | PISTON (STOCK) | PRIMARY CRANK GEAR | RADIATOR LEFT | RADIATOR RIGHT | YEAR | RADIATOR SCREENS | RADIATOR SHROUD LEFT | RADIATOR SHROUD RIGHT | YEAR | REAR AXLE | REAR BRAKE BACKING PLATE | YEAR | REAR BRAKE CALIPER | REAR BRAKE CALIPER GUARD | REAR BRAKE CALIPER MOUNT | YEAR | REAR BRAKE HOSE | REAR BRAKE LEVER | REAR BRAKE MASTER CYLINDER | REAR BRAKE MASTER CYLINDER GUARD | YEAR | REAR BRAKE ROD | REAR BRAKE ROTOR | REAR FENDER | YEAR | REAR HUB | YEAR | REAR WHEEL SPACERS | REED BOLT PATTERN | YEAR | SEAT | SHIFT DRUM | YEAR | SHIFT FORKS | SHIFT FORK ALIGNMENT RODS PINS SHAFTS | YEAR | SHIFT LEVER | SHIFT SHAFT | YEAR | SHOCK - SOME OF THESE MEASUREMENTS CAN VARY DEPENDING IF THE SPRING HAS BEEN REPLACED OR ADJUSTED | YEAR | SHOCK ARM (UNI-TRAK ARM) | SHOCK ARM LINKAGE (SUSPENSION RODS) | SIDE COVER LEFT | YEAR | SIDE COVER RIGHT | STATOR | STATOR COVER | YEAR | SUB FRAME | SWING ARM | SWING ARM PIVOT PIN / AXLE | YEAR | THROTTLE HOUSING | TRANSMISSION | TRANSMISSION INPUT SHAFT | TRANSMISSION INPUT 2ND GEAR | YEAR | TRANSMISSION INPUT 3RD GEAR | TRANSMISSION INPUT 4TH GEAR | TRANSMISSION INPUT 5TH GEAR | YEAR | TRANSMISSION OUTPUT SHAFT | TRANSMISSION OUTPUT SHAFT 1ST GEAR | TRANSMISSION OUTPUT SHAFT 2ND GEAR | YEAR | TRANSMISSION OUTPUT SHAFT 3RD GEAR | TRANSMISSION OUTPUT SHAFT 4TH GEAR | TRANSMISSION OUTPUT SHAFT 5TH GEAR | VOLTAGE REGULATOR | WATER PUMP COVER | WATER PUMP ELBOW | WATER PUMP IMPELLER | WATER PUMP SHAFT | YEAR | WIRE HARNESS |
| 1974 | KX125 | 1974 | FITS 74-76 78-79 KX125 KX250 11011-1008 | 1974 | 1021 - FITS 74-79 KX125 - 14073-1021 | FITS 74-79 KX125 KX250 - 54011-1006 | FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 | 1974 | FITS 74-76 78-79 KX125 KX250 - 21119-018 | 1974 | FITS 74-76 78-79 KX125 KX250 | 1974 | FITS 74-76 78-79 KX125 KX250 12053-1017 | N/A | 1974 | N/A | 1974 | 1974 | FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 | 1974 | 1974 | MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026 | 1974 | 1974 | CONVENTIONAL – CHROME OD 31MM | 31MM X 43MM X 10 | 1974 | CONVENTIONAL | 1974 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1974 | 1974 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 74-81 KX125 - 13066-1005 | 1974 | 1974 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | AIR COOLED | AIR COOLED | 1974 | AIR COOLED | AIR COOLED | AIR COOLED | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | PART OF MAIN FRAME | FITS 74-79 KX125 KX250 - 33001-1030 | 1974 | 1974 | 1974 | 1974 | AIR COOLED | 1974 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1975 | KX125 | 1975 | FITS 74-76 78-79 KX125 KX250 11011-1008 | 1975 | 1021 - FITS 74-79 KX125 - 14073-1021 | FITS 74-79 KX125 KX250 - 54011-1006 | FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 | 1975 | FITS 74-76 78-79 KX125 KX250 - 21119-018 | 1975 | FITS 74-76 78-79 KX125 KX250 | 1975 | FITS 74-76 78-79 KX125 KX250 12053-1017 | N/A | 1975 | N/A | 1975 | 1975 | 1975 | 1975 | MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026 | 1975 | 1975 | CONVENTIONAL – CHROME OD 31MM | 31MM X 43MM X 10 | 1975 | CONVENTIONAL | 1975 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1975 | 1975 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 74-81 KX125 - 13066-1005 | 1975 | 1975 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | AIR COOLED | AIR COOLED | 1975 | AIR COOLED | AIR COOLED | AIR COOLED | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | PART OF MAIN FRAME | FITS 74-79 KX125 KX250 - 33001-1030 | 1975 | 1975 | 1975 | 1975 | AIR COOLED | 1975 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1976 | KX125 | 1976 | FITS 74-76 78-79 KX125 KX250 11011-1008 | 1976 | 1021 - FITS 74-79 KX125 - 14073-1021 | FITS 74-79 KX125 KX250 - 54011-1006 | FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 | 1976 | FITS 74-76 78-79 KX125 KX250 - 21119-018 | 1976 | FITS 74-76 78-79 KX125 KX250 | 1976 | FITS 74-76 78-79 KX125 KX250 12053-1017 | N/A | 1976 | N/A | 1976 | 1976 | FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 | 1976 | 1976 | MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026 | 1976 | 1976 | CONVENTIONAL – CHROME OD 31MM | 31MM X 43MM X 10 | 1976 | CONVENTIONAL | 1976 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1976 | 1976 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 74-81 KX125 - 13066-1005 | 1976 | 1976 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | AIR COOLED | AIR COOLED | 1976 | AIR COOLED | AIR COOLED | AIR COOLED | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | PART OF MAIN FRAME | FITS 74-79 KX125 KX250 - 33001-1030 | 1976 | 1976 | 1976 | 1976 | AIR COOLED | 1976 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1977 | KX125 | 1977 | 1977 | 1021 - FITS 74-79 KX125 - 14073-1021 | FITS 74-79 KX125 KX250 - 54011-1006 | FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 | 1977 | 1977 | 1977 | N/A | 1977 | N/A | 1977 | 1977 | 1977 | 1977 | MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 74-81 KX125 - 13066-1005 | 1977 | FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE | 1977 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | AIR COOLED | 1977 | AIR COOLED | AIR COOLED | AIR COOLED | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | PART OF MAIN FRAME | FITS 74-79 KX125 KX250 - 33001-1030 | 1977 | 1977 | 1977 | 1977 | AIR COOLED | 1977 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1978 | KX125 | 1978 | FITS 74-76 78-79 KX125 KX250 11011-1008 | 1978 | 1021 - FITS 74-79 KX125 - 14073-1021 | FITS 74-79 KX125 KX250 - 54011-1006 | FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 | 1978 | FITS 74-76 78-79 KX125 KX250 - 21119-018 | 1978 | FITS 74-76 78-79 KX125 KX250 | 1978 | FITS 74-76 78-79 KX125 KX250 12053-1017 | N/A | 1978 | N/A | 1978 | 1978 | FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 | 1978 | 1978 | MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026 | 1978 | 1978 | CONVENTIONAL – CHROME OD 36MM | 36MM X 48MM X 10.5/11 | 1978 | CONVENTIONAL | 1978 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1978 | 1978 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 74-81 KX125 - 13066-1005 | 1978 | 1978 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | AIR COOLED | AIR COOLED | 1978 | AIR COOLED | AIR COOLED | AIR COOLED | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | PART OF MAIN FRAME | FITS 74-79 KX125 KX250 - 33001-1030 | 1978 | 1978 | 1978 | 1978 | AIR COOLED | 1978 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1979 | KX125 | 1979 | FITS 74-76 78-79 KX125 KX250 11011-1008 | 1979 | 1021 - FITS 74-79 KX125 - 14073-1021 | FITS 74-79 KX125 KX250 - 54011-1006 | FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 | 1979 | FITS 74-76 78-79 KX125 KX250 - 21119-018 | 1979 | FITS 74-76 78-79 KX125 KX250 | 1979 | FITS 74-76 78-79 KX125 KX250 12053-1017 | N/A | 1979 | N/A | 1979 | 1979 | FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 | 8102 ROD ONLY - FITS 79-93 KX125 | 1979 | 1979 | MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026 | 1979 | 1979 | CONVENTIONAL – CHROME OD 36MM | 36MM X 48MM X 10.5/11 | 1979 | CONVENTIONAL | 1979 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1979 | 1979 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 74-81 KX125 - 13066-1005 | 1979 | 1979 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | AIR COOLED | AIR COOLED | 1979 | AIR COOLED | AIR COOLED | AIR COOLED | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | PART OF MAIN FRAME | FITS 74-79 KX125 KX250 - 33001-1030 | 1979 | 1979 | 1979 | 1979 | AIR COOLED | 1979 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1980 | KX125 | FITS 80-81 KX125, 80-82 KDX175 | 1980 | FITS 80-81 KX125 KX250 KDX420, 80-82 KDX175 11011-1047 | 1980 | 1066 - FITS 80-81 KX125, 80-82 KDX175 - 14073-1066 | FITS 80-81 KX125, 80-82 KDX175 - 54011-1068 | FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 | FITS 80-81 KX125 - 54012-1096 | 1980 | 1980 | FITS 80-81 KX125 KX250 KX420, 80-82 KDX175 | 1980 | FITS 80-81 KX125 KX250 KX420 12053-1046 | N/A | 1980 | N/A | 1980 | 1980 | FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 | 8102 ROD ONLY - FITS 79-93 KX125 | 1980 | 1980 | 1980 | 1980 | CONVENTIONAL – CHROME OD 38MM | 38MM X 50MM X 10.5 | 1980 | CONVENTIONAL | 1980 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1980 | 1980 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1980 | 1980 | 1980 | 1980 | GREEN - FITS 80-81 KX125 - 51001-5108-6W | 1980 | 1980 | 1980 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 74-81 KX125 - 13066-1005 | 1980 | 1980 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | AIR COOLED | AIR COOLED | 1980 | AIR COOLED | AIR COOLED | AIR COOLED | 1980 | 1980 | 1980 | 1980 | GREEN - FITS 80-81 KX125 KX250 KX420 - 35022-1043-6W | 1980 | 1980 | 1980 | 1980 | 1980 | 1980 | 1980 | 1980 | 1980 | PART OF MAIN FRAME | 1980 | 1980 | 1980 | 1980 | AIR COOLED | 1980 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1981 | KX125 | FITS 80-81 KX125, 80-82 KDX175 | 1981 | FITS 80-81 KX125 KX250 KDX420, 80-82 KDX175 11011-1047 | 1981 | 1066 - FITS 80-81 KX125, 80-82 KDX175 - 14073-1066 | FITS 80-81 KX125, 80-82 KDX175 - 54011-1068 | FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 | FITS 80-81 KX125 - 54012-1096 | 1981 | 1981 | FITS 80-81 KX125 KX250 KX420, 80-82 KDX175 | 1981 | FITS 80-81 KX125 KX250 KX420 12053-1046 | N/A | 1981 | N/A | 1981 | 1981 | FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 | 8102 ROD ONLY - FITS 79-93 KX125 | 1981 | 1981 | 1981 | 1981 | CONVENTIONAL – CHROME OD 38MM | 38MM X 50MM X 10.5 | 1981 | CONVENTIONAL | 1981 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1981 | 1981 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1981 | 1981 | 1981 | 1981 | GREEN - FITS 80-81 KX125 - 51001-5108-6W | 1981 | 1981 | 1981 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 74-81 KX125 - 13066-1005 | 1981 | 1981 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | AIR COOLED | AIR COOLED | 1981 | AIR COOLED | AIR COOLED | AIR COOLED | 1981 | 1981 | 1981 | 1981 | GREEN - FITS 80-81 KX125 KX250 KX420 - 35022-1043-6W | 1981 | 1981 | 1981 | 1981 | 1981 | 1981 | 1981 | 1981 | 1981 | PART OF MAIN FRAME | 1981 | 1981 | 1981 | 1981 | AIR COOLED | 1981 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1982 | KX125 | KHI KX125BE000001-004200 | FITS 82-83 KX125 - 14001-5109 | 1982 | FITS 82-83 KX125 - 11012-1205 | 1982 | 1072 - FITS 82-83 KX125 - 14073-1072 | FITS 82-84 KX125 - 54011-1157 | HYDRAULIC | FITS 82-84 KX125, 83-85 KDX200 - 54012-1119 | 1982 | 1982 | FITS 82-83 KX125, 82 KX250, 81-82 KDX250 | 1982 | FITS 82-83 KX125, 82 KX250, 81-82 KDX250 12053-1062 | N/A | 1982 | N/A | FITS 82-83 KX125 - 14032-5020 | 1982 | 1982 | CM61-29 FITS 82-85 KX125, 83-85 KX250, 85-86 KDX200 - .8-1.2 ohms | FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 | 50.6MM STROKE | 8102 ROD ONLY - FITS 79-93 KX125 | FITS 82-83 KX125 - 11005-1156 | 1982 | 1982 | 1982 | 1982 | CONVENTIONAL – CHROME OD 41MM | 41MM X 53MM X 10.5 | 1982 | CONVENTIONAL | 1982 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1982 | 1982 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1982 | FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 | 1982 | FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 | FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084 | FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 | FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 | 1982 | OD 250MM - ID 129.5MM - BC 8 ON 146MM - FITS 82-84 KX125 & KX250, 83-84 KX500 | 1982 | PAT 585875 - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR 8 ON A 145MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36 SPOKES | GREEN - FITS 82-83 KX125 - 51001-5272-6W | 1982 | 1982 | 1982 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 82-05 KX125 - 13066-1101 | 1982 | 550CC 18.6OZ | 1982 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | FITS 82-83 KX125 39061-1004 | NO RIGHT SIDE | 1982 | GREEN - FITS 82-83 KX125 - 49089-1001-6W | N/A | 1982 | 41035-1107 FOR 130MM DRUM – IT SHOULD FIT 82-83 KX125, 82-84 KX250, 83-84 KX500 | 1982 | 1982 | FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 | 1982 | GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 35022-1204-AE | 1982 | PAT 585873 - 17MM AXLE DIA - BRG TO BRG 131-132MM - DRUM 130MM ID - SPROCKET 6 ON A 150MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 KDX250 - 41034-5005 | 1982 | 1982 | 1982 | 8MM OD X 58MM LONG - FITS 82-91 KX125, 83-94 KDX200 - 49047-1017 - 8MM OD X 79.5MM LONG - FITS 82-91 KX125, 83-85 KDX200 - 49047-1018 | 1982 | 1982 | 1982 | GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36001-1146-6W | 1982 | GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36001-1147-6W | FITS 82-86 KX125 - 14031-1074 | 1982 | PART OF MAIN FRAME | FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 | 1982 | 1982 | 1982 | 1982 | FITS 82-84 KX125 - 13227-1004 | FITS 82-87 KX125, 83-87 KX250, 84-87 KXT250 - 59256-1002 | 1982 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1983 | KX125 | KHI KX125BE004201-008750 | FITS 82-83 KX125 - 14001-5109 | 1983 | FITS 82-83 KX125 - 11012-1205 | 1983 | 1072 - FITS 82-83 KX125 - 14073-1072 | FITS 82-84 KX125 - 54011-1157 | HYDRAULIC | FITS 82-84 KX125, 83-85 KDX200 - 54012-1119 | MIKUNI | 1983 | 1983 | FITS 82-83 KX125, 82 KX250, 81-82 KDX250 | 1983 | FITS 82-83 KX125, 82 KX250, 81-82 KDX250 12053-1062 | N/A | 1983 | N/A | FITS 82-83 KX125 - 14032-5020 | 1983 | 1983 | CM61-29 FITS 82-85 KX125, 83-85 KX250, 85-86 KDX200 - .8-1.2 ohms | FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 | 50.6MM STROKE | 8102 ROD ONLY - FITS 79-93 KX125 | FITS 82-83 KX125 - 11005-1156 | 1983 | 1983 | MR2386 | 1983 | 1983 | CONVENTIONAL – 43MM CHROME OD - C/L 37 1/4" | 43MM X 55MM X 9.5/10.5/11 | 1983 | CONVENTIONAL | 1983 | FITS 83-84 KX250, KX500, 84 KX125 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1983 | 1983 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1983 | FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 | 1983 | FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 | FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084 | FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 | FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 | 1983 | OD 250MM - ID 129.5MM - BC 8 ON 146MM - FITS 82-84 KX125 & KX250, 83-84 KX500 | 1983 | PAT 585875 - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR 8 ON A 145MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36 SPOKES | GREEN - FITS 82-83 KX125 - 51001-5272-6W | 1983 | 1983 | 1983 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 82-05 KX125 - 13066-1101 | 1983 | 550CC 18.6OZ | 1983 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | FITS 82-83 KX125 39061-1004 | NO RIGHT SIDE | 1983 | GREEN - FITS 82-83 KX125 - 49089-1001-6W | N/A | 1983 | 41035-1107 FOR 130MM DRUM – IT SHOULD FIT 82-83 KX125, 82-84 KX250, 83-84 KX500 | 1983 | 1983 | FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 | 1983 | GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 35022-1204-AE | 1983 | PAT 585873 - 17MM AXLE DIA - BRG TO BRG 131-132MM - DRUM 130MM ID - SPROCKET 6 ON A 150MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 KDX250 - 41034-5005 | 1983 | 1983 | 1983 | 8MM OD X 58MM LONG - FITS 82-91 KX125, 83-94 KDX200 - 49047-1017 - 8MM OD X 79.5MM LONG - FITS 82-91 KX125, 83-85 KDX200 - 49047-1018 | 1983 | 1983 | 1983 | GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36001-1146-6W | 1983 | GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36001-1147-6W | FITS 82-86 KX125 - 14031-1074 | 1983 | PART OF MAIN FRAME | FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 | 1983 | 1983 | 1983 | 1983 | FITS 82-84 KX125 - 13227-1004 | FITS 82-87 KX125, 83-87 KX250, 84-87 KXT250 - 59256-1002 | 1983 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1984 | KX125 | KHI KX125BE008751-014600 | FITS 84 KX125 | 1984 | FITS 84-85 KX125, 85-86 KX250 KX500, 86-88 KDX200 - 13091-1267 | FITS 84 KX125 - 11011-1161 | 1984 | 1166 - FITS 84-85 KX125 - 14073-1166 | FITS 82-84 KX125 - 54011-1157 | HYDRAULIC | FITS 82-84 KX125, 83-85 KDX200 - 54012-1119 | MIKUNI - OVAL - 6FL52 needle - main 280a - pilot 40 | 1984 | FITS 84-85 KX125 83-85 KDX200 - 16065-1070 | KOKUSAN DENKI 21119 1195 CU1558 FITS 84-86 KX125 - 21119-1195 - 13DEG BTDC @ 11,000 RPM | 1984 | 1984 | FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 | N/A | 1984 | N/A | FITS 84 KX125 - 14032-1168 | 1984 | 1984 | CM61-29 FITS 82-85 KX125, 83-85 KX250, 85-86 KDX200 - .8-1.2 ohms | FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 | FITS 84 KX125 - 13031-1160 - 50.6mm STROKE | 8102 ROD ONLY - FITS 79-93 KX125 | 1984 | 1984 | MR2392 FITS 84-85 KX125 | 1984 | 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 | 1984 | CONVENTIONAL – 43MM CHROME OD - C/L 37 1/4" | 43MM X 55MM X 9.5/10.5/11 | 1984 | CONVENTIONAL | 1984 | FITS 85 KX125, KX250, KX500 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1984 | 1984 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1984 | 1984 | FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 | FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084 | FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 | FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 | 1984 | OD 250MM - ID 129.5MM - BC 8 ON 146MM - FITS 82-84 KX125 & KX250, 83-84 KX500 | 1984 | F-1123 GRAY - 17MM AXLE DIA - BRG TO BRG 102MM - FITS 83-84 KX125 & KX250 | GREEN - FITS 84 KX125 - 51001-5415-6W | 1984 | 1984 | 1984 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 84-89 KX125 - 13064-1142 | FITS 82-05 KX125 - 13066-1101 | 1984 | 550CC 18.6OZ | 1984 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | FITS 84-85 KX125 39061-1056 | NO RIGHT SIDE | 1984 | GREEN - FITS 84 KX125 - 49089-1055-6W | N/A | 1984 | 1984 | 1984 | FITS 84-85 KX125, 85 KX250 KX500 43001-1173 | FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 | 1984 | GREEN – FITS 84-85 KX125, 85 KX250 KX500 - 35022-1203-6W | 1984 | PAT 585873 - 17MM AXLE DIA - BRG TO BRG 131-132MM - DRUM 130MM ID - SPROCKET 6 ON A 150MM BC - FITS 84 KX125, 83-85 KDX200 - 41034-1108 | 1984 | 1984 | 1984 | 8MM OD X 58MM LONG - FITS 82-91 KX125, 83-94 KDX200 - 49047-1017 - 8MM OD X 79.5MM LONG - FITS 82-91 KX125, 83-85 KDX200 - 49047-1018 | 1984 | 1984 | 1984 | GREEN - FITS 84-85 KX125, 85 KX250 KX500 - 36001-1279-AE | 1984 | GREEN - FITS 84-85 KX125, 85 KX250 KX500 - 36001-1280-AE | FITS 84-86 KX125 - 21003-1115 | FITS 82-86 KX125 - 14031-1074 | 1984 | PART OF MAIN FRAME | FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 | 1984 | 1984 | 1984 | 1984 | FITS 82-84 KX125 - 13227-1004 | FITS 82-87 KX125, 83-87 KX250, 84-87 KXT250 - 59256-1002 | 1984 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1985 | KX125 | KHI KX125DE000001-008400 | FITS 85-87 KX125 - 14001-5184 | 1985 | FITS 84-85 KX125, 85-86 KX250 KX500, 86-88 KDX200 - 13091-1267 | FITS 85 KX125 - 11011-1179 | 1985 | 1166 - FITS 84-85 KX125 - 14073-1166 | FITS 85 KX125 - 54011-1224 | HYDRAULIC | FITS 85 KX125 - 54012-1254 | 1985 | FITS 84-85 KX125 83-85 KDX200 - 16065-1070 | KOKUSAN DENKI 21119 1195 CU1558 FITS 84-86 KX125 - 21119-1195 - 13DEG BTDC @ 11,000 RPM | 1985 | 1985 | FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 | FITS 85-87 KX125 - 13236-1121 | FITS 85-87 KX125 - 13095-1117 | N/A | 1985 | N/A | 1 PIECE - FITS 85-87 KX125 - 14032-1177 | 1985 | 1 PIECE - FITS 85-87 KX125 - 14032-1177 | FITS 85-87 KX125 - 13087-1060 | FITS 85-87 KX125, 86-88 KDX200, 94-96 KLX250R - 13086-1056 | 1985 | CM61-29 FITS 82-85 KX125, 83-85 KX250, 85-86 KDX200 - .8-1.2 ohms | FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 | FITS 85-86 KX125 - 13031-1180 - 50.6MM STROKE | 8102 ROD ONLY - FITS 79-93 KX125 | FITS 85 KX125 | 1985 | FITS 85 KX125 | N/A | 1985 | KIPS - FITS 85-86 KX125 - 14025-1984 | FITS 85-87 KX125 - 14024-1650 | MR2392 FITS 84-85 KX125 | FITS 85 KX125 KX250 KX500 | 1985 | 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 | 1985 | CONVENTIONAL - 43MM CHROME OD - C/L 37 1/4" - BRAKE MOUNT C/L 62MM - AXLE CLAMPS 20MM | 43MM X 55MM X 9.5/10.5/11 | 1985 | CONVENTIONAL | 1985 | FITS 86 KX125, KX250, KX500 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1985 | 1985 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1985 | FITS 85-88 KX125 KX250 KX500 - 41068-1241 | 1985 | FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 | FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084 | FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 | FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 | 1985 | OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 | 1985 | F-1123 - BLACK - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR OD 250MM - 8 ON A 146MM BC - FITS 85-87 KX125 KX250 KX500 - 41034-1115 | GREEN - FITS 85 KX125 - 51002-5006-6W | 1985 | 1985 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 85-86 KX125 - 49046-1052 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1985 | FITS 85-86 KX125 - 11001-1190 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 84-89 KX125 - 13064-1142 | FITS 82-05 KX125 - 13066-1101 | 1985 | 600CC 20.3OZ | 1985 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | FITS 85-87 KX125 - 13097-1127 | FITS 84-85 KX125 39061-1056 | NO RIGHT SIDE | 1985 | GREEN - FITS 85 KX125 - 49089-5003-6W | N/A | 1985 | FITS 85-87 KX125 KX250 KX500 - 41068-1180 | 1985 | 1985 | FITS 84-85 KX125, 85 KX250 KX500 43001-1173 | FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 | 1985 | FITS 85 KX125 - 43011-1119 | GREEN – FITS 84-85 KX125, 85 KX250 KX500 - 35022-1203-6W | 1985 | R-1122-1 - 20MM - BRG TO BRG 131-132MM - SPROCKET BOLT CIRCLE 6 ON 150MM - SPROCKET ID 134MM DRUM STYLE BRAKE - FITS 85 KX125 - 41034-1114 | 1985 | 1985 | FITS 85 KX125, 250 & 500 | FITS 85-87 KX125 - 13239-1120 | 1985 | SET FITS 85-91 KX125 - 13140-1070 - 13140-1123 - 13140-1124 - PIN .235-.236 SL .231, FINGER .154-.157 SL .150 | 8MM OD X 58MM LONG - FITS 82-91 KX125, 83-94 KDX200 - 49047-1017 - 8MM OD X 79.5MM LONG - FITS 82-91 KX125, 83-85 KDX200 - 49047-1018 | 1985 | FITS 85-87 KX125, 83-85 KDX200 - 13161-1101 | 1985 | 1985 | GREEN - FITS 84-85 KX125, 85 KX250 KX500 - 36001-1279-AE | 1985 | GREEN - FITS 84-85 KX125, 85 KX250 KX500 - 36001-1280-AE | FITS 84-86 KX125 - 21003-1115 | FITS 82-86 KX125 - 14031-1074 | 1985 | PART OF MAIN FRAME | FITS 85 KX125 KX250 33001-1230 | FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 | 1985 | FITS 85-87 KX125 - 13127-1116 | 1985 | 1985 | FITS 85-87 KX125 - 13128-1115 | 1985 | FITS 85-87 KX125 - 16142-1058 | FITS 82-87 KX125, 83-87 KX250, 84-87 KXT250 - 59256-1002 | 36T - FITS 85-87 KX125 - 13234-1053 | 1985 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1986 | KX125 | KHI KX125DE008401-017200 | FITS 85-87 KX125 - 14001-5184 | 1986 | FITS 86 KX125 - 11011-1206 | 1986 | 1235 - FITS 86 KX125 - 14073-1235 | FITS 86-87 KX125 - 54011-1234 | HYDRAULIC | FITS 86-87 KX125 KDX200 - 54012-1305 | 1986 | KOKUSAN DENKI 21119 1195 CU1558 FITS 84-86 KX125 - 21119-1195 - 13DEG BTDC @ 11,000 RPM | 1986 | FITS 86-87 KX125 & KX250 & KX500 | 1986 | FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 | FITS 85-87 KX125 - 13236-1121 | FITS 85-87 KX125 - 13095-1117 | N/A | 1986 | N/A | 1 PIECE - FITS 85-87 KX125 - 14032-1177 | 1986 | 1 PIECE - FITS 85-87 KX125 - 14032-1177 | FITS 85-87 KX125 - 13087-1060 | FITS 85-87 KX125, 86-88 KDX200, 94-96 KLX250R - 13086-1056 | 1986 | FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms | FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 | FITS 85-86 KX125 - 13031-1180 - 50.6MM STROKE | 8102 ROD ONLY - FITS 79-93 KX125 | 1476 FITS 86 KX125 11005-1476 | 1986 | FITS 86 KX125 LEFT 12005-1072, RIGHT 12005-1073 | N/A | 1986 | KIPS - FITS 85-86 KX125 - 14025-1984 | FITS 85-87 KX125 - 14024-1650 | MR2394 FITS 86 KX125 - 21007-1146 | FITS 86-87 KDX200 KX125 KX250 KX500 - 34028-1173 - 34028-1174 | 1986 | 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 | 1986 | CONVENTIONAL - 43MM CHROME OD - C/L 37 1/4" | 43MM X 55MM X 9.5/10.5/11 | 1986 | CONVENTIONAL | 1986 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1986 | FITS 86 KX125 KX250 KX500 44039-1142 | 1986 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1986 | FITS 85-88 KX125 KX250 KX500 - 41068-1241 | 1986 | FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 | FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084 | FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 | FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 | 1986 | OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 | 1986 | F-1123 - BLACK - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR OD 250MM - 8 ON A 146MM BC - FITS 85-87 KX125 KX250 KX500 - 41034-1115 | GREEN - FITS 86 KX125 - 51003-5397-6W | 1986 | 1986 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 85-86 KX125 - 49046-1052 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1986 | FITS 85-86 KX125 - 11001-1190 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 84-89 KX125 - 13064-1142 | FITS 82-05 KX125 - 13066-1101 | FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 | 1986 | FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN | 600CC 20.3OZ | 1986 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | FITS 85-87 KX125 - 13097-1127 | FITS 86 KX125 39061-1078 | NO RIGHT SIDE | 1986 | GREEN - FITS 86-87 KX125 - 49089-5017-6W | N/A | 1986 | FITS 85-87 KX125 KX250 KX500 - 41068-1180 | HYDRAULIC BRAKE | 1986 | FITS 86 KX125, KX250, KX500 | 1986 | FITS 86-87 KX125 KX250 KX500 - 43059-1364 | FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 | 1986 | OD: 8 11/16" - ID: 4 5/16" - 8 BOLT HOLES ON A 4 15/16" BOLT CIRCLE | GREEN – FITS 86-87 KX125 KX250 KX500 - 35022-1217-6W | 1986 | R-1158 – BLACK - 20MM – BRG TO BRG 144-145MM – ROTOR OD 220MM – ROTOR BC 8 ON 126MM – SPROCKET 6 ON 150MM BC – 36 SPOKES – FITS 86-87 KX125 KX250 KX500 - 41034-1139 | 1986 | LEFT FITS 86-88 KX125 KX250 KX125 - 92027-1942 RIGHT FITS 86 KX125 KX250 KX500 - 92027-1944 | 1986 | FITS 86 KX125, KX250 & KX500 - 53001-1436 | FITS 85-87 KX125 - 13239-1120 | 1986 | SET FITS 85-91 KX125 - 13140-1070 - 13140-1123 - 13140-1124 - PIN .235-.236 SL .231, FINGER .154-.157 SL .150 | 8MM OD X 58MM LONG - FITS 82-91 KX125, 83-94 KDX200 - 49047-1017 - 8MM OD X 79.5MM LONG - FITS 82-91 KX125, 83-85 KDX200 - 49047-1018 | 1986 | FITS 85-87 KX125, 83-85 KDX200 - 13161-1101 | 1986 | 1986 | 1986 | FITS 84-86 KX125 - 21003-1115 | FITS 82-86 KX125 - 14031-1074 | 1986 | PART OF MAIN FRAME | FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 | 1986 | FITS 85-87 KX125 - 13127-1116 | 1986 | 1986 | FITS 85-87 KX125 - 13128-1115 | 1986 | FITS 85-87 KX125 - 16142-1058 | FITS 82-87 KX125, 83-87 KX250, 84-87 KXT250 - 59256-1002 | 36T - FITS 85-87 KX125 - 13234-1053 | 1986 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1987 | KX125 | KHI KX125DE017201- ON | FITS 85-87 KX125 - 14001-5184 | 1987 | FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200, 97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 | FITS 87 KX125 KX250 KX500 11011-1241 | 1987 | 1285 - FITS 87 KX125 - 14073-1285 | FITS 86-87 KX125 - 54011-1234 | HYDRAULIC | FITS 86-87 KX125 KDX200 - 54012-1305 | MIKUNI V 31 2 H6 8 | 1987 | FITS 87 KX125 - 16065-1155 | 11DEG BTDC @ 11,000 RPM | 1987 | FITS 86-87 KX125 & KX250 & KX500 | 1987 | FITS 87 KX125 KX250 KX500, 87-88 KDX200, 87-88 KXF250 | FITS 85-87 KX125 - 13236-1121 | FITS 85-87 KX125 - 13095-1117 | N/A | 1987 | N/A | 1 PIECE - FITS 85-87 KX125 - 14032-1177 | 1987 | 1 PIECE - FITS 85-87 KX125 - 14032-1177 | FITS 85-87 KX125 - 13087-1060 | FITS 85-87 KX125, 86-88 KDX200, 94-96 KLX250R - 13086-1056 | 1987 | FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms | FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 | 50.6MM STROKE | 8102 ROD ONLY - FITS 79-93 KX125 | 1508 FITS 87 KX125 11005-1508 | 1987 | FITS 87 KX125, left 12005-1088, right 12005-1089 | N/A | 1987 | FITS 85-87 KX125 - 14024-1650 | FITS 86-87 KDX200 KX125 KX250 KX500 - 34028-1173 - 34028-1174 | 1987 | 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 | 1987 | CONVENTIONAL – 43MM CHROME OD - C/L 37 1/4" | 43MM X 55MM X 9.5/10.5/11 | 1987 | CONVENTIONAL | 1987 | FITS 88 KX125 - 44037-1237 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1987 | 1987 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1987 | FITS 85-88 KX125 KX250 KX500 - 41068-1241 | 1987 | FITS 87 KX125 KX250 KX500 | FITS 87 KX125 KX250 KX500 - 43059-1385 | FITS 87 KX125 KX250 KX500 46092-1141 | FITS 87 KX125 KX250 KX500 | 1987 | OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 | 1987 | F-1123 - BLACK - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR OD 250MM - 8 ON A 146MM BC - FITS 85-87 KX125 KX250 KX500 - 41034-1115 | GREEN - FITS 87 KX125 - 51002-5268-6W | 1987 | FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 | 19T - FITS 87-91 KX125 - 59051-1181 | 1987 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 87 KX125 - 49046-1059 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1987 | FITS 87 KX125 - 11001-1244 | FITS 74-87 KX125, 80-82 KDX175 - 59051-1009 | FITS 84-89 KX125 - 13064-1142 | FITS 82-05 KX125 - 13066-1101 | FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 | 1987 | FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN | 600CC 20.3OZ | 1987 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | FITS 85-87 KX125 - 13097-1127 | FITS 87-89 KX125 39061-1120 | NO RIGHT SIDE | 1987 | GREEN - FITS 86-87 KX125 - 49089-5017-6W | N/A | 1987 | FITS 85-87 KX125 KX250 KX500 - 41068-1180 | HYDRAULIC BRAKE | 1987 | FITS 87-88 KX125, KX250, KX500 - 43041-1244 | FITS 87-88 KX125 KX250 KX500 - 43044-1068 | 1987 | FITS 86-87 KX125 KX250 KX500 - 43059-1364 | FITS 87 KX125 & KX250 & KX500 | 1987 | OD: 8 11/16" - ID: 4 5/16" - 8 BOLT HOLES ON A 4 15/16" BOLT CIRCLE | GREEN – FITS 86-87 KX125 KX250 KX500 - 35022-1217-6W | 1987 | R-1158 – BLACK - 20MM – BRG TO BRG 144-145MM – ROTOR OD 220MM – ROTOR BC 8 ON 126MM – SPROCKET 6 ON 150MM BC – 36 SPOKES – FITS 86-87 KX125 KX250 KX500 - 41034-1139 | 1987 | 1987 | FITS 87 KX125 KX250 KX500 | FITS 85-87 KX125 - 13239-1120 | 1987 | SET FITS 85-91 KX125 - 13140-1070 - 13140-1123 - 13140-1124 - PIN .235-.236 SL .231, FINGER .154-.157 SL .150 | 8MM OD X 58MM LONG - FITS 82-91 KX125, 83-94 KDX200 - 49047-1017 - 8MM OD X 79.5MM LONG - FITS 82-91 KX125, 83-85 KDX200 - 49047-1018 | 1987 | FITS 85-87 KX125, 83-85 KDX200 - 13161-1101 | 1987 | SPRING THICKNESS 11.1MM - SPRING OD 87MM, LENGTH 255MM - BODY OD 51.8MM - CHROME OD 14MM - EYE TO EYE 440MM - UPPER MOUNT WIDTH 26.8MM, HOLE ID 10MM - LOWER MOUNT WIDTH 25.3MM, HOLE ID 10MM - FITS 87 KX125 - 45014-1354 | 1987 | FITS 87 KX125 KX250 KX500 - 39007-1115 | FITS 87 KX125 KX250 KX125 – LEFT 36002-5310-6W | 1987 | FITS 87 KX125 KX250 KX125 – RIGHT 36001-1345-AC | FITS 87 KX125 - 21003-1167 | 1987 | FITS 87 KX125 KX250 KX500 - 32002-1911 | FITS 87 KX125 | 1987 | FITS 85-87 KX125 - 13127-1116 | 1987 | 1987 | FITS 85-87 KX125 - 13128-1115 | 1987 | FITS 85-87 KX125 - 16142-1058 | FITS 82-87 KX125, 83-87 KX250, 84-87 KXT250 - 59256-1002 | 36T - FITS 85-87 KX125 - 13234-1053 | 1987 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1988 | KX125 | KX125FE000001-006500 | FITS 88 KX125 - 14001-5244 | JKAKXRF15JA00XXXX | 1988 | FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200, 97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 | FITS 88 KX125 - 11011-1298 | 1988 | 1327 - FITS 88 KX125 - 14073-1327 | FITS 88-93 KX125 - 54011-1262 | HYDRAULIC | KEIHIN PWK V392BJ20 | 1988 | FITS 88 KX125 - 16065-1179 | 13DEG BTDC @ 11,000 RPM - FITS 88 KX125 - 21119-1232 | 1988 | FITS 88-89 KX125 KX250 KX500 - 33040-1085 | FITS 88-89 KX125 KX250 KX500 | 1988 | FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 | FITS 88 KX125 - 13095-1190 | N/A | 1988 | N/A | 1988 | 2 PIECE - FITS 88 KX125 - 14032-1241 | FITS 88 KX125 - 13087-1097 | 1988 | FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms | FITS 88 KX125 - 13031-1259 - 50.6MM STROKE | 8102 ROD ONLY - FITS 79-93 KX125 | 1539 FITS 88 KX125 11005-1539 | 1988 | FITS 88 KX125 KX250 - 32029-1570 | FITS 88 KX125 - 49069-1087 | FITS 88 KX125 LEFT 12005-1096, RIGHT 12005-1097 | N/A | 1988 | KIPS - FITS 88-91 KX125, 89-94 KDX200 - 14024-1565 | F3T81271 FITS 88 KX125 - 21003-1175 | FITS 88-89 KX125 KX250 KX500 - 34028-1233 - 34028-1234 | 1988 | FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 | 1988 | CONVENTIONAL – 43MM CHROME OD - C/L 37 1/4" - BRAKE MOUNT C/L 89MM - AXLE CLAMPS 20MM - 44001-1673 | 43MM X 55MM X 9.5/10.5/11 | 1988 | CONVENTIONAL | 1988 | FITS 89 KX125, KX250, KX500 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1988 | FITS 88 KX125 - 44039-1177 | 1988 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1988 | FITS 85-88 KX125 KX250 KX500 - 41068-1241 | 1988 | FITS 88 KX125 KX250 KX500 | FITS 87-88 KX500, 88 KX125 KX250 43044-1069 | FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 | FITS 88 KX125 KX250 KX500 - 43015-1367 | 1988 | OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 | 1988 | F-1123 - GRAY - 17MM AXLE DIA - BRG TO BRG 102MM - FITS 88 KX 125, 250, 500 - 41034-1170 | GREEN - FITS 88 KX125 - 51002-5380-6W | 1988 | FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 | 19T - FITS 87-91 KX125 - 59051-1181 | 1988 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-89 KX125 - 49046-1062 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1988 | FITS 88 KX125 11001-1267 | 31T - FITS 88-93 KX125 -59051-1191 | FITS 84-89 KX125 - 13064-1142 | FITS 82-05 KX125 - 13066-1101 | FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 | 1988 | FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN | 650CC 22.0OZ | 1988 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | FITS 88-91 KX125 - 13097-1203 | FITS 87-89 KX125 39061-1120 | NO RIGHT SIDE | 1988 | GREEN - FITS 88 KX125 - 49089-5041-6W | N/A | 1988 | FITS 88 KX125 KX250 KX500 - 41068-1249 CLICK HERE FOR MEASUREMENTS | HYDRAULIC BRAKE | 1988 | FITS 87-88 KX125, KX250, KX500 - 43041-1244 | FITS 87-88 KX125 KX250 KX500 - 43044-1068 | 1988 | FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 | FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 | 1988 | OD: 8 11/16" - ID: 4 5/16" - 8 BOLT HOLES ON A 4 15/16" BOLT CIRCLE | GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W | 1988 | R-1158 – GRAY - 20MM – BRG TO BRG 144-145MM – ROTOR OD 220MM – ROTOR BC 8 ON 126MM – SPROCKET 6 ON 150MM BC – 36 SPOKES – FITS 88 KX 125, 250, 500 - 41034-1171 | 1988 | FITS 88 KX125 - 12021-1069 | 1988 | PAN STAMP 1531 - FITS 88 KX125 KX250 KX500 - 53001-1532 | FITS 88-91 KX125 - 13141-1145 | 1988 | SET FITS 85-91 KX125 - 13140-1070 - 13140-1123 - 13140-1124 - PIN .235-.236 SL .231, FINGER .154-.157 SL .150 | 8MM OD X 58MM LONG - FITS 82-91 KX125, 83-94 KDX200 - 49047-1017 - 8MM OD X 79.5MM LONG - FITS 82-91 KX125, 83-85 KDX200 - 49047-1018 | 1988 | FITS 88-93 KX125, KX250 & KX500 - 13156-1240 | FITS 88-93 KX125 - 13161-1149 | 1988 | FITS 88 KX125 - 45014-1385 | 1988 | FITS 88 KX125 KX250 KX500 - 39007-1145 | FITS 88 KX125 - 46102-1247 | GREEN – FITS 88 KX125 KX250 KX500 - 36002-5451-6W | 1988 | BLACK/WHITE TO BLACK/YELLOW 422-648 OHMS WHITE/RED TO WHITE GREEN 4.0-6.0 OHMS - FITS 88 KX125 - 21003-1175 | FITS 88-91 KX125 - 14031-1217 | 1988 | FITS 88 KX125 KX250 KX500 - 32002-1965 | FITS 88 KX125 KX250 KX500 - 33001-1306-X3 | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 | 1988 | 1988 | 1988 | 1988 | FITS 88-02 KX125 - 16142-1127 | FITS 88-89 KX125 KX250 - 52014-1063 | FITS 88 KX125 24T 13234-1078 | 1988 | ||||||||||||||||||||||||||||||||||||||||||||||||||
| 1989 | KX125 | KX125FE006501- ON | FITS 89 KX125 | JKAKXRG15KA | 1989 | FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200, 97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 | FITS 89 KX125 KX250, 90-04 KX500 11011-1304 | 1989 | 1368 - FITS 89 KX125 - 14073-1368 | FITS 88-93 KX125 - 54011-1262 | HYDRAULIC | KEIHIN PWK V46 | 1989 | 13.8DEG BTDC @ 11,000 RPM | 1989 | FITS 88-89 KX125 KX250 KX500 - 33040-1085 | FITS 88-89 KX125 KX250 KX500 | 1989 | FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 | FITS 89-91 KDX200, 89 KX125 - 13236-1195 | FITS 89 KX125 - 13095-1199 | N/A | 1989 | N/A | FITS 89-91 KX125, 89-94 KDX200 - 14032-1266 | 1989 | FITS 89-90 KX125 - 14032-1268 | FITS 89-94 KDX200, 89 KX125 - 13086-1060 | 1989 | FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms | FITS 89-90 KX125 - 13031-1293 - 50.6MM STROKE | 8102 ROD ONLY - FITS 79-93 KX125 | 1565 FITS 89 KX125 11005-1565 | 1989 | FITS 89 KX125 KX250 - 32029-1649 | FITS 89 KX125 - 18002-1863 | FITS 89 KX125 12005-1128 | 1989 | KIPS - FITS 88-91 KX125, 89-94 KDX200 - 14024-1565 | FITS 89 KX125, 89-94 KDX200 - 14024-1786 | F3T81371 F3T81472 - FITS 89-90 KX125 - 21007-1175 | FITS 88-89 KX125 KX250 KX500 - 34028-1233 - 34028-1234 | 1989 | FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 | 1989 | CONVENTIONAL – 46MM CHROME OD - 22MM AXLE OD - 36 1/8" C/L - BRAKE MOUNT C/L 78MM | 46MM X 58MM X 10.5 | 1989 | FITS 89-92 KX125 KX250, 89-93 KX500, 93-96 KLX650C KLX650R, 44063-1056 | CONVENTIONAL | 1989 | FITS 90 KX125, KX250, KX500 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1989 | FITS 89 KX125 KX250 KX500 44039-1192 | 1989 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1989 | FITS 89 KX125 KX250 KX500 | FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056 | 1989 | FITS 89 KX125 KX250 KX500 - 43041-1294 | FITS 89 KX125 KX250 KX500 - 14079-1071 | FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 | FITS 89-90 KX125 KX250 KX500 KX80 - 43015-1395 | 1989 | ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200 | 1989 | F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - ROTOR BC 4 ON 116MM - FITS 89 KX125 KX250 KX500 | GREEN - FITS 89 KX125 - 51003-5002-6W | 1989 | FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 | 19T - FITS 87-91 KX125 - 59051-1181 | 1989 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-89 KX125 - 49046-1062 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1989 | FITS 89 KX125 11001-1308 | 31T - FITS 88-93 KX125 -59051-1191 | FITS 84-89 KX125 - 13064-1142 | FITS 82-05 KX125 - 13066-1101 | FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 | 1989 | FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN | 700CC =.7L = 23.7 OZ | 1989 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | FITS 88-91 KX125 - 13097-1203 | FITS 87-89 KX125 39061-1120 | NO RIGHT SIDE | 1989 | GREEN - FITS 89 KX125 - 49089-5071-6W | N/A | 1989 | HYDRAULIC BRAKE | 1989 | FITS 89-93 KX125 KX250, 89-93 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 | FITS 89 KX125 KX250 KX500 - 43044-1082 | 1989 | FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 | FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 | 1989 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W | 1989 | R-1213 – GRAY – 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM – 36 SPOKES – FITS 89 KDX200, KX125, KX250, KX500 - 2 BRG - 41034-1184 | 1989 | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1989 | PAN STAMP 1531 - FITS 89 KX125 KX250 KX500 - 53001-1577-MD | FITS 88-91 KX125 - 13141-1145 | 1989 | SET FITS 85-91 KX125 - 13140-1070 - 13140-1123 - 13140-1124 - PIN .235-.236 SL .231, FINGER .154-.157 SL .150 | 8MM OD X 58MM LONG - FITS 82-91 KX125, 83-94 KDX200 - 49047-1017 - 8MM OD X 79.5MM LONG - FITS 82-91 KX125, 83-85 KDX200 - 49047-1018 | 1989 | FITS 88-93 KX125, KX250 & KX500 - 13156-1240 | FITS 88-93 KX125 - 13161-1149 | 1989 | FITS 89 KX125 - 45014-1430 | 1989 | FITS 89 KX125 KX250 KX500 - 39007-1170 | FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 | 1989 | GREEN – FITS 89 KX125 KX250 KX500 - 36010-5135-6W | FITS 88-91 KX125 - 14031-1217 | 1989 | FITS 89-90 KX500, 89 KX125 KX250 - 32160-1031 | FITS 89 KX125 KX250 KX500 – 33001-1324-CE | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 | 1989 | SHAFTS FIT 89-93 KX125, GEARS FIT 89-91 KX125 | 1989 | 1989 | 1989 | FITS 88-02 KX125 - 16142-1127 | FITS 88-89 KX125 KX250 - 52014-1063 | FITS 89-90 KX125 13234-1082 | 1989 | ||||||||||||||||||||||||||||||||||||||||||||||||
| 1990 | KX125 | KX125FE006501-ON | FITS 90 KX125 | 1990 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 90-91 KX125 KX250 11011-1336 | 1990 | 1430 - FITS 90-91 KX125 - 14073-1430 | FITS 88-93 KX125 - 54011-1262 | HYDRAULIC | KEIHIN PWK V56 – 35MM – NEEDLE N84C | 1990 | FITS 90-91 KX125 | 14DEG BTDC @ 11,000 RPM | 1990 | FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | 1990 | FITS 90 KX125 KX250 12053-1269 | FITS 90-91 KX125 - 13236-1214 | FITS 90 KX125 - 13095-1230 | N/A | 1990 | FITS 90-92 KX125 | N/A | FITS 89-91 KX125, 89-94 KDX200 - 14032-1266 | 1990 | FITS 89-90 KX125 - 14032-1268 | FITS 90-93 KX125 13087-1120 | FITS 90-93 KX125 - 13086-1067 | 1990 | F6T537 FITS 90-91 KX125 & KX250, 94 KX125 & KX250 - 21121-1181 - 21121-1234 | FITS 89-90 KX125 - 13031-1293 - 50.6MM STROKE | 8102 ROD ONLY - FITS 79-93 KX125 | 1602 FITS 90 KX125 11005-1602 | 1990 | FITS 90-91 KX125 KX250 - 32029-1714 | FITS 90-91 KX125 | 1990 | KIPS - FITS 88-91 KX125, 89-94 KDX200 - 14024-1565 | F3T81371 F3T81472 - FITS 89-90 KX125 - 21007-1175 | FITS 90 KX125 KX250, 90-91 KX500 - 34028-1318 - 34028-1319 | 1990 | FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 | 1990 | USD - 41MM CROME OD - C/L 37 3/8" - SILVER - UPPER 50MM - LOWER 55.7MM - BRAKE MOUNT C/L 60MM - AXLE CLAMPS 22MM ID | 41MM X 53MM X 8/9.5/10.5 | 1990 | FITS 89-92 KX125 KX250, 89-93 KX500, 93-96 KLX650C KLX650R, 44063-1056 | FITS 90-93 KX125 KX250 KX500 - 55020-1384 | FITS 90-93 KX125 KX250 KX500 - 13070-1204 | 1990 | FITS 91 KX125, KX250, 91-93 KX500 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1990 | 1990 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1990 | FITS 90-92 KX125 KX250, 90-93 KX500 41068-1310 | FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056 | 1990 | FITS 90 KX125 KX250 KX500 - 43041-1285 | FITS 90-91 KX125 KX250 KX500, 91 KDX250 - 14079-1072 | FITS 90-93 KX125 KX250 KX500 - 43059-1577 | FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 | FITS 89-90 KX125 KX250 KX500 KX80 - 43015-1395 | 1990 | ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200 | 1990 | F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - FITS 90-92 KX125 AND 250 - 1990-1993 KX500 - 41034-1204 | GREEN - FITS 90-91 KX125 KX250 51001-1320-6W 51001-1340-6W | 1990 | FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 | 19T - FITS 87-91 KX125 - 59051-1181 | 1990 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1990 | 1316 FITS 90 KX125 11001-1316 | 31T - FITS 88-93 KX125 -59051-1191 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | 1990 | FITS 90 KX125 KX250 KX500 58029-5027-6W GREEN | 700CC =.7L = 23.7 OZ | 1990 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | FITS 88-91 KX125 - 13097-1203 | FITS 90 KX125, 90-91 KX250 39061-1147 | FITS 90 KX125 39061-1149 | 1990 | GREEN 14037-1099-6W FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W | LEFT - GREEN FITS 90 KX125 - 49089-5089-6W | RIGHT - GREEN FITS 90 KX125 - 49089-5090-6W | 1990 | FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 | HYDRAULIC BRAKE | 1990 | FITS 89-93 KX125 KX250, 89-93 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 | FITS 90-93 KX125 KX250, 90-91 KX500 - 43044-1092 | 1990 | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | 1990 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | FITS 90-91 KX125 KX250 | 1990 | R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG | 1990 | FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM | FITS 90-92 KX125 - 12021-1085 | 1990 | FITS 90 KX125 KX250 - 53001-1592-MZ | FITS 88-91 KX125 - 13141-1145 | 1990 | SET FITS 85-91 KX125 - 13140-1070 - 13140-1123 - 13140-1124 - PIN .235-.236 SL .231, FINGER .154-.157 SL .150 | 8MM OD X 58MM LONG - FITS 82-91 KX125, 83-94 KDX200 - 49047-1017 - 8MM OD X 79.5MM LONG - FITS 82-91 KX125, 83-85 KDX200 - 49047-1018 | 1990 | FITS 88-93 KX125, KX250 & KX500 - 13156-1240 | FITS 88-93 KX125 - 13161-1149 | 1990 | KYB - SPRING THICKNESS 11.5MM - SPRING OD 88.5MM, LENGTH 270MM - BODY OD 53.4MM - CHROME OD 16MM - EYE TO EYE 450MM - UPPER MOUNT WIDTH 22.1MM, HOLE ID 10MM - LOWER MOUNT OUTSIDE WIDTH 41.5MM, INSIDE WIDTH 22MM, HOLE ID 10MM - FITS 90 KX125 - 45014-1450 | 1990 | FITS 90-91 KX125 KX250 | 1990 | FITS 88-91 KX125 - 14031-1217 | 1990 | FITS 90 KX125 KX250 - 32160-1096 | FITS 90 KX125 KX250 – 33001-1346-CE | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 1990 | SHAFTS FIT 89-93 KX125, GEARS FIT 89-91 KX125 | 1990 | 1990 | 1990 | FITS 88-02 KX125 - 16142-1127 | FITS 89-90 KX125 13234-1082 | 1990 | ||||||||||||||||||||||||||||||||||||||||||||||||||
| 1991 | KX125 | KX125HE000001-ON | FITS 91 KX125 set - 14001-5284 | 1991 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 90-91 KX125 KX250 11011-1336 | 1991 | 1430 - FITS 90-91 KX125 - 14073-1430 | FITS 88-93 KX125 - 54011-1262 | HYDRAULIC | KEIHIN PWK V675E 35MM | 1991 | FITS 90-91 KX125 | 15.8DEG BTDC @ 11,000 RPM | 1991 | FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | 1991 | FITS 91-93 KX125 KX250 12053-1278 | FITS 90-91 KX125 - 13236-1214 | FITS 91 KX125 - 13095-1234 | N/A | 1991 | FITS 90-92 KX125 | N/A | FITS 89-91 KX125, 89-94 KDX200 - 14032-1266 | 1991 | FITS 91 KX125 - 14032-1295 | FITS 90-93 KX125 13087-1120 | FITS 90-93 KX125 - 13086-1067 | 1991 | F6T537 FITS 90-91 KX125 & KX250, 94 KX125 & KX250 - 21121-1181 - 21121-1234 | 50.6MM STROKE | 8102 ROD ONLY - FITS 79-93 KX125 | 1645 FITS 91 KX125 11005-1645 | 1991 | FITS 90-91 KX125 KX250 - 32029-1714 | FITS 90-91 KX125 | 1991 | KIPS - FITS 88-91 KX125, 89-94 KDX200 - 14024-1565 | F3T81373 FITS 91 KX125 - 21007-1219 | FITS 91 KX125 KX250 KDX25, 92 KX500 - 34028-1332 - 34028-1333 | 1991 | FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 | 1991 | USD - X125-R X125-L - 43MM CHROME OD - C/L 37.25" - BLUE - UPPER 52MM - LOWER 56.6MM - BRAKE MOUNT C/L 60.5MM AXLE CLAMP 22MM ID | 43MM X 55MM X 9.5/10.5/11 | 1991 | FITS 89-92 KX125 KX250, 89-93 KX500, 93-96 KLX650C KLX650R, 44063-1056 | FITS 90-93 KX125 KX250 KX500 - 55020-1384 | FITS 90-93 KX125 KX250 KX500 - 13070-1204 | 1991 | FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 | 1991 | 1991 | FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 | 1991 | FITS 90-92 KX125 KX250, 90-93 KX500 41068-1310 | FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056 | 1991 | FITS 91 KX125 KX250. 91-92 KX500, 91-94 KDX250, 93-94 KDX200 - 43041-1427 | FITS 90-91 KX125 KX250 KX500, 91 KDX250 - 14079-1072 | FITS 90-93 KX125 KX250 KX500 - 43059-1577 | FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 | FITS 91-92 KX125 KX250, 91 KX500 - 43015-1443 | 1991 | ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200 | 1991 | F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - FITS 90-92 KX125 AND 250 - 1990-1993 KX500 - 41034-1204 | GREEN - FITS 90-91 KX125 KX250 51001-1320-6W 51001-1340-6W | 1991 | FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 | 19T - FITS 87-91 KX125 - 59051-1181 | 1991 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1991 | 1344 FITS 91 KX125 11001-1344 | 31T - FITS 88-93 KX125 -59051-1191 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | 1991 | FITS 91 KX125 KX250 KX500 58029-5028-6W GREEN | 700CC =.7L = 23.7 OZ | 1991 | FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 | FITS 88-91 KX125 - 13097-1203 | FITS 91-93 KX125, 92-93 KX 250 39061-1173 | FITS 91 KX125 39061-1174 | 1991 | GREEN 14037-1099-6W FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W | 1991 | FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 | HYDRAULIC BRAKE | 1991 | FITS 89-93 KX125 KX250, 89-93 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 | FITS 90-93 KX125 KX250, 90-91 KX500 - 43044-1092 | 1991 | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | FITS 91 KX125 KX250 43015-1440 | 1991 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | FITS 90-91 KX125 KX250 | 1991 | R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG | 1991 | FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM | FITS 90-92 KX125 - 12021-1085 | 1991 | FITS 90 KX125 KX250 - 53001-1592-MZ | FITS 88-91 KX125 - 13141-1145 | 1991 | SET FITS 85-91 KX125 - 13140-1070 - 13140-1123 - 13140-1124 - PIN .235-.236 SL .231, FINGER .154-.157 SL .150 | 8MM OD X 58MM LONG - FITS 82-91 KX125, 83-94 KDX200 - 49047-1017 - 8MM OD X 79.5MM LONG - FITS 82-91 KX125, 83-85 KDX200 - 49047-1018 | 1991 | FITS 88-93 KX125, KX250 & KX500 - 13156-1240 | FITS 88-93 KX125 - 13161-1149 | 1991 | 1991 | STAMPED 39007-1213A - FITS 91-92 KX125 KX250 - 39007-1197 | STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293 | FITS 90-91 KX125 KX250 | 1991 | FITS 88-91 KX125 - 14031-1217 | 1991 | FITS 91 KX125 KX250 - 32160-1151 | FITS 91 KX125 KX250 – 33001-1370-CE | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 1991 | SHAFTS FIT 89-93 KX125, GEARS FIT 89-91 KX125 | 1991 | 1991 | 1991 | FITS 88-02 KX125 - 16142-1127 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | 1991 | |||||||||||||||||||||||||||||||||||||||||||||||||||
| 1992 | KX125 | KX125JE00XXXX | FITS 92 KX125 | JKAKXRJ15NA00XXXX | 1992 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 92-93 KX125 & KX250 | 1992 | 1509 - FITS 92 KX125 - 14073-1509 | FITS 88-93 KX125 - 54011-1262 | HYDRAULIC | FITS 92-97 KX125 KX250 - 54012-1432 | KEIHIN PWK V756 | 1992 | FITS 92 KX125 - 21119-1337 | 1992 | FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | 1992 | FITS 91-93 KX125 KX250 12053-1278 | FITS 92 KX125 - 13095-1265 | N/A | 1992 | FITS 90-92 KX125 | N/A | FITS 92-93 KX125 - 14032-1315 | 1992 | FITS 92-93 KX125 - 14032-1345 | FITS 90-93 KX125 13087-1120 | FITS 90-93 KX125 - 13086-1067 | 1992 | F6T537 FITS 92-93 KX125 KX250 - 21121-1200 | FITS 92 KX125 - 13031-1356 | 8102 ROD ONLY - FITS 79-93 KX125 | 1672 FITS 92 KX125 11005-1672 | 1992 | FITS 92-93 KX125 KX250 - 32029-1791 | FITS 92 KX125 | 1992 | FITS 92-97 KX125 - 14090-1134 | F4T802 71 FITS 92-97 KX125 - 21007-1235 | FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE | 1992 | FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 | 1992 | USD - X125-R X125-L - 43MM CHROME OD - C/L 37.25" - BLUE - UPPER 52MM - LOWER 56.6MM - BRAKE MOUNT C/L 60.5MM AXLE CLAMP 22MM ID | 43MM X 55MM X 9.5/10.5/11 | 1992 | FITS 89-92 KX125 KX250, 89-93 KX500, 93-96 KLX650C KLX650R, 44063-1056 | FITS 90-93 KX125 KX250 KX500 - 55020-1384 | FITS 90-93 KX125 KX250 KX500 - 13070-1204 | 1992 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 1992 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | 1992 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 1992 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 90-92 KX125 KX250, 90-93 KX500 41068-1310 | FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056 | 1992 | FITS 92-93 KX125 KX250, 93 KX500 - 43041-1462 | FITS 92-93 KX125 KX250 KX500, 92-94 KDX250 - 14079-1088 | FITS 90-93 KX125 KX250 KX500 - 43059-1577 | FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 | FITS 91-92 KX125 KX250, 91 KX500 - 43015-1443 | 1992 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | 1992 | F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - FITS 90-92 KX125 AND 250 - 1990-1993 KX500 - 41034-1204 | BLACK - FITS 92-93 KX125 KX250 51001-1360 | 1992 | FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 | 1992 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1992 | 1369 FITS 92 KX125 11001-1369 | 31T - FITS 88-93 KX125 -59051-1191 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | 1992 | FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE | 700CC =.7L = 23.7 OZ | 1992 | FITS 92-93 KX125 - 13097-1302 | FITS 91-93 KX125, 92-93 KX 250 39061-1173 | FITS 92-93 KX125 KX250 39061-1175 | 1992 | GREEN 14037-1099-6W FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W | 1992 | FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 | HYDRAULIC BRAKE | 1992 | FITS 89-93 KX125 KX250, 89-93 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 | FITS 90-93 KX125 KX250, 90-91 KX500 - 43044-1092 | 1992 | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | FITS 92-93 KX125 KX250 - 43001-1303 | FITS 92-94 KDX250, 92-93 KX125 KX250, 93-95 KLX650R - 43015-1469 | 1992 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | 1992 | R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG | 1992 | FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM | FITS 90-92 KX125 - 12021-1085 | 1992 | FITS 92-93 KX125 KX250 - 53001-1697-LK | FITS 92-93 KX125 - 13141-1175 | 1992 | FITS 92-93 KX125 | 1992 | FITS 88-93 KX125, KX250 & KX500 - 13156-1240 | FITS 88-93 KX125 - 13161-1149 | 1992 | 1992 | STAMPED 39007-1213A - FITS 91-92 KX125 KX250 - 39007-1197 | STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293 | 1992 | F4T80271 - FITS 92-93 KX125 - 21003-1260 | FITS 92-99 KX125 - 14031-1262 | 1992 | FITS 92-93 KX125 KX250 - 32160-1219-CC | FITS 92 KX125 KX250 – 33001-1393-CE | FITS 92-93 KX125 KX250, 93-96 KLX650R - 33032-1167 | 1992 | SHAFTS FIT 89-93 KX125 GEARS FIT 92-93 KX125 | 1992 | 1992 | 1992 | FITS 88-02 KX125 - 16142-1127 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 92-93 KX125 - 13234-1097 | 1992 | |||||||||||||||||||||||||||||||||||||||||||||||||||
| 1993 | KX125 | KX125JE00XXXX | FITS 93 KX125 - 14001-5313 | JKAKXRJ17PA00XXXX | 1993 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 92-93 KX125 & KX250 | 1993 | 1569 - FITS 93 KX125 - 14073-1569 | FITS 88-93 KX125 - 54011-1262 | HYDRAULIC | FITS 92-97 KX125 KX250 - 54012-1432 | KEIHIN PWK V790 | 1993 | FITS 93 KX125 - 21119-1378 | 1993 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | 1993 | FITS 91-93 KX125 KX250 12053-1278 | FITS 93 KX125 - 13095-1258 | N/A | 1993 | N/A | FITS 92-93 KX125 - 14032-1315 | 1993 | FITS 92-93 KX125 - 14032-1345 | FITS 90-93 KX125 13087-1120 | FITS 90-93 KX125 - 13086-1067 | 1993 | F6T537 FITS 92-93 KX125 KX250 - 21121-1200 | FITS 93 KX125 | 8102 ROD ONLY - FITS 79-93 KX125 | 1687 FITS 93 KX125 11005-1687 | 1993 | FITS 92-93 KX125 KX250 - 32029-1791 | 20043 | FITS 93 KX125 | FITS 93-97 KX125 - 12005-1194 12005-1217 | FITS 93-97 KX125 - 12005-1195 12005-1218 | 1993 | FITS 92-97 KX125 - 14090-1134 | F4T802 71 FITS 92-97 KX125 - 21007-1235 | FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE | 1993 | FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 | 1993 | USD - X125-R X125-L - 43MM CHROME OD - C/L 37.25" - BLUE - UPPER 52MM - LOWER 56.6MM - BRAKE MOUNT C/L 60.5MM AXLE CLAMP 22MM ID | 43MM X 55MM X 9.5/10.5/11 | 1993 | FITS 89-92 KX125 KX250, 89-93 KX500, 93-96 KLX650C KLX650R, 44063-1056 | FITS 90-93 KX125 KX250 KX500 - 55020-1384 | FITS 90-93 KX125 KX250 KX500 - 13070-1204 | 1993 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 1993 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | 1993 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 1993 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 | 1993 | FITS 92-93 KX125 KX250, 93 KX500 - 43041-1462 | FITS 92-93 KX125 KX250 KX500, 92-94 KDX250 - 14079-1088 | FITS 90-93 KX125 KX250 KX500 - 43059-1577 | FITS 93 KX125 KX250 - 43015-1544 | 1993 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | 1993 | F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 | BLACK - FITS 92-93 KX125 KX250 51001-1360 | 1993 | FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 | 1993 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1993 | 1385 FITS 93 KX125 11001-1385 | 31T - FITS 88-93 KX125 -59051-1191 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | 1993 | FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE | 700CC =.7L = 23.7 OZ | 1993 | FITS 92-93 KX125 - 13097-1302 | FITS 91-93 KX125, 92-93 KX 250 39061-1173 | FITS 92-93 KX125 KX250 39061-1175 | 1993 | GREEN 14037-1099-6W FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W | 1993 | FITS 93-02 KX125 KX250 - 41068-1343 | HYDRAULIC BRAKE | 1993 | FITS 89-93 KX125 KX250, 89-93 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 | FITS 90-93 KX125 KX250, 90-91 KX500 - 43044-1092 | 1993 | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | FITS 92-93 KX125 KX250 - 43001-1303 | FITS 92-94 KDX250, 92-93 KX125 KX250, 93-95 KLX650R - 43015-1469 | 1993 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | 1993 | R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG | 1993 | FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM | 1993 | FITS 92-93 KX125 KX250 - 53001-1697-LK | FITS 92-93 KX125 - 13141-1175 | 1993 | FITS 92-93 KX125 | 1993 | FITS 88-93 KX125, KX250 & KX500 - 13156-1240 | FITS 88-93 KX125 - 13161-1149 | 1993 | 1993 | STAMPED 39007-1213 - FITS 93 KX125 & KX250 - 39007-1213 | STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293 | 1993 | F4T80271 - FITS 92-93 KX125 - 21003-1260 | FITS 92-99 KX125 - 14031-1262 | 1993 | FITS 92-93 KX125 KX250 - 32160-1219-CC | FITS 93 KX125 KX250 – 33001-1406-CE | FITS 92-93 KX125 KX250, 93-96 KLX650R - 33032-1167 | 1993 | SHAFTS FIT 89-93 KX125 GEARS FIT 92-93 KX125 | 1993 | 1993 | 1993 | FITS 88-02 KX125 - 16142-1127 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 92-93 KX125 - 13234-1097 | 1993 | |||||||||||||||||||||||||||||||||||||||||||||||||||||
| 1994 | KX125 | KX125KE00XXXX | FITS 94 KX125 | 1994 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 94 KX125 KX250 11011-1418-RG | 1994 | 1580 - FITS 94 KX125 - 14073-1580 | FITS 94 KX125 - 54011-1331 | HYDRAULIC | FITS 92-97 KX125 KX250 - 54012-1432 | KEIHIN PWK V885 - FITS 94 KX125 - 15001-1885 | 1994 | FITS 94-95 KX125 | FITS 94 KX125 - 21119-1406 | 1994 | FITS 94-96 KX125 KX250 - 33040-1136 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | 1994 | FITS 94-96 KX125 KX250 12053-1336 | FITS 94-02 KX125 | 1994 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-98 KX125 | 1994 | FITS 94-97 KX125 - 14032-1347 | 1994 | F6T537 FITS 90-91 KX125 & KX250, 94 KX125 & KX250 - 21121-1181 - 21121-1234 | FITS 94-02 KX125 - 12053-1325 | FITS 94-02 KX125 - 14026-1193 | FITS 94 KX125 - 13031-1366 (ROD FITS 94-97) 54.5MM STROKE | 8163 ROD ONLY - FITS 94-97 KX125 | 1720 FITS 94 KX125 11005-1720 | 1994 | FITS 94-02 KX125 - 32029-1896 | FITS 94-95 KX125 - 18120-1056 | FITS 94 KX125 | FITS 94 KX125 - 12005-1172 12005-1173 12023-1070 | FITS 93-97 KX125 - 12005-1194 12005-1217 | FITS 93-97 KX125 - 12005-1195 12005-1218 | 1994 | FITS 92-97 KX125 - 14090-1134 | F4T802 71 FITS 92-97 KX125 - 21007-1235 | FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE | 1994 | FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 | 1994 | USD - 43MM CHROME OD - C/L 37 - GOLD - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 25MM | 43MM X 55MM X 9.5/10.5/11 | 1994 | FITS 94-95 KX125 KX250 KX500 - 55020-1492-RZ | FITS 94-95 KX125 KX250 KX500 - LH 13070-1277 - RH 13070-1278 | 1994 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 1994 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | 1994 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 1994 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 | 1994 | ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94 KX125 KX250 KX500 - 43059-1760 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 94-95 KX125 KX250 KX500 KX80 - 43015-1556 | 1994 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W | 1994 | F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 | FITS 94-98 KX125 & KX250 | 1994 | FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 | FITS 94-98 KX125 - 59051-1297 | 1994 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1994 | 1399 FITS 94 KX125 11001-1399 | 31T - FITS 94-98 KX125 - 59051-1295 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | FITS 94-02 KX125 KX250 - 35019-1252-RZ | 1994 | FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE | 700CC =.7L = 23.7 OZ | 1994 | FITS 94-98 KX125 | FITS 94-96 KX125 KX250 39061-1197 | FITS 94-96 KX125 KX250 39061-1198 | 1994 | FITS 94-95 KX125, KX250 | 1994 | FITS 93-02 KX125 KX250 - 41068-1343 | HYDRAULIC BRAKE | 1994 | FITS 94 KX125 KX250, 94-95 KX500 - 43041-1532 | FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F | FITS 92-95 KX500, 94 KX125 KX250 - 43044-1111 | 1994 | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515 | FITS 94-98 KX125 KX250, 95-06 KDX200, 97-05 KDX220 - 55020-1487 | 1994 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | GREEN - FITS 94-98 KX125 KX250 - 35023-1362-6W | 1994 | R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG | 1994 | FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM | 1994 | FITS 94-98 KX125 & KX250 WILL FIT BUT THEY HAVE DIFFERENT SEAT COVERS | FITS 94-02 KX125 - 13141-1188 | 1994 | FITS 94 | 1994 | FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 | 1994 | 1994 | FITS 94 & 96 KX125 KX250 39007-1228 | STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293 | 1994 | F4T80272 FITS 94 KX125 | FITS 92-99 KX125 - 14031-1262 | 1994 | FITS 94 KX125 KX250 - 32160-1308-CC | FITS 94 KX125 KX250 – 33001-1442-TX | FITS 94-97 KX125 KX250 - 33032-1172 | 1994 | FITS 92-05 KX125, 92-07 KX250 - ASY | SHAFTS FIT-94-98 KX125 GEARS FIT 94 KX125 | 13T - FITS 94-02 KX125 - 13127-1229 | 1994 | 1994 | 1994 | FITS 88-02 KX125 - 16142-1127 | FITS 94-02 KX125 - 52014-1072 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 94-98 KX125 | 1994 | |||||||||||||||||||||||||||||||||||||||||||
| 1995 | KX125 | KX125KE00XXXX | FITS 95-96 KX125 SET 14001-5334 | JKAKXRK13SA00XXXX | 1995 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 95 KX125 KX250 11011-1446-RG | 1995 | 1612 - FITS 95-97 KX125 - 14073-1612 | FITS 95-96 KX125 - 54011-1344 | HYDRAULIC | FITS 92-97 KX125 KX250 - 54012-1432 | KEIHIN PWK GO95 FITS 95 KX125 - 15003-1095 - 35MM | 1995 | FITS 94-95 KX125 | FITS 95 KX125 - 21119-1430 | 1995 | FITS 94-96 KX125 KX250 - 33040-1136 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | 1995 | FITS 94-96 KX125 KX250 12053-1336 | FITS 95-96 KX125 | FITS 94-02 KX125 | 1995 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-98 KX125 | 1995 | FITS 94-97 KX125 - 14032-1347 | 1995 | FITS 95-98 KX125 - 21121-1247 | FITS 94-02 KX125 - 12053-1325 | FITS 94-02 KX125 - 14026-1193 | FITS 95 KX125 - 13031-1366 (ROD FITS 94-97) 54.5MM STROKE | 8163 ROD ONLY - FITS 94-97 KX125 | 1752 FITS 95 KX125 11005-1752 | 1995 | FITS 94-02 KX125 - 32029-1896 | FITS 94-95 KX125 - 18120-1056 | 20048 | FITS 95 | FITS 93-97 KX125 - 12005-1194 12005-1217 | FITS 93-97 KX125 - 12005-1195 12005-1218 | 1995 | FITS 92-97 KX125 - 14090-1134 | F4T802 71 FITS 92-97 KX125 - 21007-1235 | FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE | 1995 | FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 | 1995 | USD - KYB - KX94 L KX94 R - CHROME OD - 43MM - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 25MM | 43MM X 55MM X 9.5/10.5/11 | 1995 | FITS 94-95 KX125 KX250 KX500 - 55020-1492-RZ | FITS 94-95 KX125 KX250 KX500 - LH 13070-1277 - RH 13070-1278 | 1995 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 1995 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | 1995 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 1995 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 | 1995 | ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 95 KX125 KX250 KX500 - 43059-1881 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 94-95 KX125 KX250 KX500 KX80 - 43015-1556 | 1995 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W | 1995 | F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 | FITS 95 KX125 KX250 – 51001-1468-6Z | 1995 | FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 | FITS 94-98 KX125 - 59051-1297 | 1995 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 95 KX125 - 49111-1057 | 1995 | 1415 FITS 95 KX125 11001-1415 | 31T - FITS 94-98 KX125 - 59051-1295 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | FITS 94-02 KX125 KX250 - 35019-1252-RZ | 1995 | FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE | 700CC =.7L = 23.7 OZ | 1995 | FITS 94-98 KX125 | FITS 94-96 KX125 KX250 39061-1197 | FITS 94-96 KX125 KX250 39061-1198 | 1995 | FITS 94-95 KX125, KX250 | GREEN – FITS 95 KX125 KX250 – 49089-5232-6W | GREEN – FITS 95 KX125 KX250 – 49089-5233-6W | 1995 | FITS 93-02 KX125 KX250 - 41068-1343 | HYDRAULIC BRAKE | 1995 | FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 | FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F | FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105 | 1995 | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | FITS 95 KX125 KX250 - 43001-1351 | FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515 | FITS 94-98 KX125 KX250, 95-06 KDX200, 97-05 KDX220 - 55020-1487 | 1995 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | GREEN - FITS 94-98 KX125 KX250 - 35023-1362-6W | 1995 | R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG | 1995 | FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM | 1995 | FITS 94-98 KX125 & KX250 WILL FIT BUT THEY HAVE DIFFERENT SEAT COVERS | FITS 94-02 KX125 - 13141-1188 | 1995 | 1995 | FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 | 1995 | 1995 | 1231 - FITS 95 KX125 & KX250 - 39007-1231 | STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293 | FITS 95-98 KX125 KX250 | 1995 | F4T80273 FITS 95-97 KX125 | FITS 92-99 KX125 - 14031-1262 | 1995 | FITS 95-97 KX125 KX250 32160-1397-CC | FITS 95 KX125 KX250 – 33001-1464-TX | FITS 94-97 KX125 KX250 - 33032-1172 | 1995 | FITS 92-05 KX125, 92-07 KX250 - ASY | SHAFTS FIT-94-98 KX125 GEARS FIT 95-98 KX125 | 13T - FITS 94-02 KX125 - 13127-1229 | 1995 | 1995 | 1995 | FITS 88-02 KX125 - 16142-1127 | FITS 94-02 KX125 - 52014-1072 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 94-98 KX125 | 1995 | ||||||||||||||||||||||||||||||||||||||
| 1996 | KX125 | KX125KE00XXXX | FITS 95-96 KX125 SET 14001-5334 | 1996 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 96-97 KX125 KX250 11011-1472-RG | 1996 | 1612 - FITS 95-97 KX125 - 14073-1612 | FITS 95-96 KX125 - 54011-1344 | HYDRAULIC | FITS 92-97 KX125 KX250 - 54012-1432 | KEIHIN PWK G252 (NOT VERIFIED) - FITS 96 KX125 - 15003-1203 | 1996 | FITS 96 KX125 - 21119-1453 | 1996 | FITS 94-96 KX125 KX250 - 33040-1136 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | 1996 | FITS 94-96 KX125 KX250 12053-1336 | FITS 95-96 KX125 | FITS 94-02 KX125 | 1996 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-98 KX125 | 1996 | FITS 94-97 KX125 - 14032-1347 | 1996 | FITS 95-98 KX125 - 21121-1247 | FITS 94-02 KX125 - 12053-1325 | FITS 94-02 KX125 - 14026-1193 | FITS 96 KX125 - 13031-1407 (ROD FITS 94-97) 54.5MM STROKE | 8163 ROD ONLY - FITS 94-97 KX125 | 1794 FITS 96 KX125 11005-1794 | 1996 | FITS 94-02 KX125 - 32029-1896 | 20048 | FITS 96-97 KX125 | FITS 96-97 KX125 - 12023-1073 12005-1221 12005-1222 | FITS 93-97 KX125 - 12005-1194 12005-1217 | FITS 93-97 KX125 - 12005-1195 12005-1218 | 1996 | FITS 92-97 KX125 - 14090-1134 | F4T802 71 FITS 92-97 KX125 - 21007-1235 | FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE | 1996 | FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 | 1996 | USD - KYB - CHROME OD - 46MM - C/L 37 1/4" - UPPER 53.9MM - LOWER 58.8MM - BRAKE MOUNT 102MM - AXLE CLAMPS 25MM | 46MM X 58MM X 10.5 | 1996 | 1996 | FITS 96-97 KX125, KX250 * 44037-1338 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 1996 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | FITS 96-98 KX125 - 44039-1263 | 1996 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 1996 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 | 1996 | ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 96 KX125 KX250 KX500 - 43015-1574 | 1996 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W | 1996 | F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 | FITS 96-98 KX125 KX250 - 51001-1489-6Z | 1996 | FITS 94-98 KX125 - 59051-1297 | 1996 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 1996 | 1435 FITS 96-98 KX125 11001-1435 | 31T - FITS 94-98 KX125 - 59051-1295 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | FITS 94-02 KX125 KX250 - 35019-1252-RZ | 1996 | FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE | 700CC =.7L = 23.7 OZ | FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 | 1996 | FITS 94-98 KX125 | FITS 94-96 KX125 KX250 39061-1197 | FITS 94-96 KX125 KX250 39061-1198 | 1996 | FITS 96 KX125 KX250 | 1996 | FITS 93-02 KX125 KX250 - 41068-1343 | HYDRAULIC BRAKE | 1996 | FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 | FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F | FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105 | 1996 | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515 | FITS 94-98 KX125 KX250, 95-06 KDX200, 97-05 KDX220 - 55020-1487 | 1996 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | GREEN - FITS 94-98 KX125 KX250 - 35023-1362-6W | 1996 | R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG | 1996 | FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM | 1996 | FITS 94-98 KX125 & KX250 WILL FIT BUT THEY HAVE DIFFERENT SEAT COVERS | FITS 94-02 KX125 - 13141-1188 | 1996 | FITS 96-02 KX125 - 13140-1251 - 13140-1252 - 13140-1253 | 1996 | FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 | FITS 96-97 KX125 - 13161-1221 | 1996 | 1996 | FITS 94 & 96 KX125 KX250 39007-1228 | STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293 | FITS 95-98 KX125 KX250 | 1996 | FITS 92-99 KX125 - 14031-1262 | 1996 | FITS 95-97 KX125 KX250 32160-1397-CC | FITS 96 KX125 KX250 – 33001-1487-TX | FITS 94-97 KX125 KX250 - 33032-1172 | 1996 | FITS 92-05 KX125, 92-07 KX250 - ASY | SHAFTS FIT-94-98 KX125 GEARS FIT 95-98 KX125 | 13T - FITS 94-02 KX125 - 13127-1229 | 1996 | 1996 | 1996 | FITS 88-02 KX125 - 16142-1127 | FITS 94-02 KX125 - 52014-1072 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 94-98 KX125 | 1996 | ||||||||||||||||||||||||||||||||||||||||||
| 1997 | KX125 | KX125KE00XXXX | FITS 97 KX125 | 1997 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 96-97 KX125 KX250 11011-1472-RG | 1997 | 1612 - FITS 95-97 KX125 - 14073-1612 | FITS 97-98 KX125 - 54011-1366 | HYDRAULIC | FITS 92-97 KX125 KX250 - 54012-1432 | KEIHIN PWK G275 - FITS 97 KX125 - 15003-1275 - 36MM | 1997 | FITS 97 KX125 - 21119-1475 ACCORDING TO EGORE IT CAN USE A 96 KX125 CDI FOR A BETTER CURVE | 1997 | FITS 97-02 KX125 KX250 - 33040-1156 | 1997 | FITS 97-02 KX125 KX250 - 12053-1376 | FITS 97-98 KX125 KX250 12053-1375 | FITS 94-02 KX125 | 1997 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-98 KX125 | 1997 | FITS 94-97 KX125 - 14032-1347 | FITS 97-02 KX125 - 13087-1167 | FITS 97-02 KX125 - 13087-1167 | 1997 | FITS 95-98 KX125 - 21121-1247 | FITS 94-02 KX125 - 12053-1325 | FITS 94-02 KX125 - 14026-1193 | FITS 97 KX125 - 13031-1414 (ROD FITS 94-97) 54.5MM STROKE | 8163 ROD ONLY - FITS 94-97 KX125 | 1840 FITS 97 KX125 11005-1840 | 1997 | FITS 94-02 KX125 - 32029-1896 | 20048 | FITS 96-97 KX125 | FITS 96-97 KX125 - 12023-1073 12005-1221 12005-1222 | FITS 93-97 KX125 - 12005-1194 12005-1217 | FITS 93-97 KX125 - 12005-1195 12005-1218 | 1997 | FITS 92-97 KX125 - 14090-1134 | F4T802 71 FITS 92-97 KX125 - 21007-1235 | 1997 | FITS 97-00 KX125 KX250 - 92144-1951 | 1997 | USD - 46MM CHROME OD - UPPER 53.9MM - LOWER 58.8MM - BRAKE MOUNT 102MM - AXLE CLAMPS 25MM | 46MM X 58MM X 10.5 | 1997 | WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ | FITS 97-04 KX500, 97-03 KX125 KX250 | 1997 | FITS 96-97 KX125, KX250 * 44037-1338 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 1997 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | FITS 96-98 KX125 - 44039-1263 | 1997 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 1997 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 | 1997 | FITS 97-98 KX125 KX250 - 43041-1605 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 97-98 KX125 KX250 - 43059-1950 | FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 | 304 - FITS 97-99 KX125 KX250 - 43015-1582 | 1997 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W | 1997 | F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 | FITS 96-98 KX125 KX250 - 51001-1489-6Z | 1997 | FITS 94-98 KX125 - 59051-1297 | 1997 | FITS 97-98 KX125 - 13070-1305 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 97-98 KX125 - 49111-1058 | 1997 | 1435 FITS 96-98 KX125 11001-1435 | 31T - FITS 94-98 KX125 - 59051-1295 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | FITS 94-02 KX125 KX250 - 35019-1252-RZ | 1997 | FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE | 700CC =.7L = 23.7 OZ | FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 | 1997 | FITS 94-98 KX125 | FITS 97 KX125 KX250 39061-1229 | FITS 97 KX125 KX250 39061-1230 | 1997 | 1997 | FITS 93-02 KX125 KX250 - 41068-1343 | HYDRAULIC BRAKE | 1997 | FITS 97-98 KX125 KX250 - 43041-1606 | FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F | 1118 - FITS 97-02 KX125 KX250 - 14079-1111 | 1997 | FITS 97-98 KX125 & KX250 | FITS 97-01 KX125 KX250, 43015-1597 | FITS 94-98 KX125 KX250, 95-06 KDX200, 97-05 KDX220 - 55020-1487 | 1997 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | GREEN - FITS 94-98 KX125 KX250 - 35023-1362-6W | 1997 | R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 | 1997 | FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM | 1997 | FITS 97 KX125 KX250 - 53001-1815-LW - 94-98 WILL FIT BUT THEY HAVE DIFFERENT SEAT COVERS | FITS 94-02 KX125 - 13141-1188 | 1997 | FITS 96-02 KX125 - 13140-1251 - 13140-1252 - 13140-1253 | 1997 | FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 | FITS 96-97 KX125 - 13161-1221 | 1997 | 1997 | FITS 97-01 KX125 KX250 - 46102-1404 - EYE TO EYE 123.5MM, 15MM ID - STAMPED 04 - 46102-1404 | FITS 95-98 KX125 KX250 | 1997 | FITS 92-99 KX125 - 14031-1262 | 1997 | FITS 95-97 KX125 KX250 32160-1397-CC | FITS 97-98 KX125 – 33001-1525-TX | FITS 94-97 KX125 KX250 - 33032-1172 | 1997 | FITS 92-05 KX125, 92-07 KX250 - ASY | SHAFTS FIT-94-98 KX125 GEARS FIT 95-98 KX125 | 13T - FITS 94-02 KX125 - 13127-1229 | 1997 | 1997 | 1997 | FITS 88-02 KX125 - 16142-1127 | FITS 94-02 KX125 - 52014-1072 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 94-98 KX125 | 1997 | ||||||||||||||||||||||||||||||||||||||||||
| 1998 | KX125 | KX125KE02XXXX | FITS 98 KX125 | JKAKXRKC0WA02XXXX | 1998 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 98 KX125 KX250 11011-1534-RG | 1998 | 1697 - FITS 98 KX125 - 14073-1697 | FITS 97-98 KX125 - 54011-1366 | HYDRAULIC | FITS 98 KX125 KX250 - 54012-1561 | KEIHIN PWK G345 - FITS 98 KX 125 - 15003-1345 | 1998 | DENSO 071000-1250 21119-1502 - FITS 98 KX125 | 1998 | FITS 97-02 KX125 KX250 - 33040-1156 | 1998 | FITS 97-02 KX125 KX250 - 12053-1376 | FITS 97-98 KX125 KX250 12053-1375 | FITS 94-02 KX125 | 1998 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-98 KX125 | 1998 | FITS 98 KX125 - 14032-1474 | FITS 97-02 KX125 - 13087-1167 | FITS 97-02 KX125 - 13087-1167 | 1998 | FITS 95-98 KX125 - 21121-1247 | FITS 94-02 KX125 - 12053-1325 | FITS 94-02 KX125 - 14026-1193 | FITS 98 KX125 - 13031-1428 - 54.5MM STROKE | 8140 ROD ONLY - FITS 98-02 KX125 | 1852 FITS 98 KX125 11005-1852 | 1998 | FITS 94-02 KX125 - 32029-1896 | FITS 98-01 KX125 - 18069-1140 | 22003 | FITS 98 KX125 - 49116-1156 | 1998 | FITS 98 KX125 - 14090-1828 | FITS 98-02 KX125 - 14090-1829 | DENSO | 1998 | FITS 97-00 KX125 KX250 - 92144-1951 | 1998 | USD - 46MM CHROME OD - C/L 37 1/4" UPPER 53.9MM - LOWER 58.8MM - BRAKE MOUNT 102MM - AXLE CLAMPS 25MM | 46MM X 58MM X 10.5 | 1998 | WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ | FITS 97-04 KX500, 97-03 KX125 KX250 | 1998 | FITS 98-00 KX125 KX250 44037-1371 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 1998 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | FITS 96-98 KX125 - 44039-1263 | 1998 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 1998 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 | 1998 | FITS 97-98 KX125 KX250 - 43041-1605 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 97-98 KX125 KX250 - 43059-1950 | FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 | 304 - FITS 97-99 KX125 KX250 - 43015-1582 | 1998 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W | 1998 | F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 | FITS 96-98 KX125 KX250 - 51001-1489-6Z | 1998 | FITS 94-98 KX125 - 59051-1297 | 1998 | FITS 97-98 KX125 - 13070-1305 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 97-98 KX125 - 49111-1058 | 1998 | 1435 FITS 96-98 KX125 11001-1435 | 31T - FITS 94-98 KX125 - 59051-1295 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | FITS 94-02 KX125 KX250 - 35019-1252-RZ | 1998 | FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE | 700CC =.7L = 23.7 OZ | FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 | 1998 | FITS 94-98 KX125 | FITS 98 KX125 KX250 39061-1257 | FITS 98 KX125 KX250 39061-1258 | 1998 | 1998 | FITS 93-02 KX125 KX250 - 41068-1343 | HYDRAULIC BRAKE | 1998 | FITS 97-98 KX125 KX250 - 43041-1606 | FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F | 1118 - FITS 97-02 KX125 KX250 - 14079-1111 | 1998 | FITS 97-98 KX125 & KX250 | FITS 97-01 KX125 KX250, 43015-1597 | FITS 94-98 KX125 KX250, 95-06 KDX200, 97-05 KDX220 - 55020-1487 | 1998 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | GREEN - FITS 94-98 KX125 KX250 - 35023-1362-6W | 1998 | R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 | 1998 | FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM | 1998 | FITS 94-98 KX125 & KX250 WILL FIT BUT THEY HAVE DIFFERENT SEAT COVERS | FITS 94-02 KX125 - 13141-1188 | 1998 | FITS 96-02 KX125 - 13140-1251 - 13140-1252 - 13140-1253 | 1998 | FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 | FITS 98 KX125 - 13161-1244 | 1998 | 1998 | FITS 98 KX125 & KX250 | FITS 97-01 KX125 KX250 - 46102-1404 - EYE TO EYE 123.5MM, 15MM ID - STAMPED 04 - 46102-1404 | FITS 95-98 KX125 KX250 | 1998 | 175A – fits 98 kx125 – 21003-1321 - | FITS 92-99 KX125 - 14031-1262 | 1998 | FITS 98 KX125 KX250 - 32160-1512-CC | FITS 97-98 KX125 – 33001-1525-TX | FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 | 1998 | FITS 92-05 KX125, 92-07 KX250 - ASY | SHAFTS FIT-94-98 KX125 GEARS FIT 95-98 KX125 | 13T - FITS 94-02 KX125 - 13127-1229 | 1998 | 1998 | 1998 | FITS 88-02 KX125 - 16142-1127 | FITS 94-02 KX125 - 52014-1072 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 94-98 KX125 | 1998 | ||||||||||||||||||||||||||||||||||||||||
| 1999 | KX125 | KX125LE00XXXX | FITS 99 KX125 - 14001-1248 | JKAKXRLC4XA00XXXX | 1999 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 99-02 KX125 KX250 11011-1557-6D | 1999 | 1742 - FITS 99 KX125 - 14073-1742 | FITS 99 KX125 - 54011-1388 | HYDRAULIC | FITS 99-03 KX125 KX250 - 54012-1598 | FITS 99 KX125 - KEIHIN PWK G489 - 36MM - 15003-1489 | 1999 | FITS 99 KX125 - 16065-1362 | FITS 99 KX125 - DENSO 071000-1430 - 21119-1524 | FITS 99-00 KX125, 99-00 AND 02 KX250 - 92160-1945 | 1999 | FITS 97-02 KX125 KX250 - 33040-1156 | FITS 99-02 KX125 KX250 - 13070-1333 | 1999 | FITS 97-02 KX125 KX250 - 12053-1376 | FITS 99-03 KX125 KX250 12053-1422 | FITS 99 KX125 - 13102-1144 | FITS 99-02 KX125 - 13095-1367 | FITS 94-02 KX125 | 1999 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 99-02 KX125 - 14032-1481 | 1999 | FITS 99 KX125 - 14032-1492 | FITS 97-02 KX125 - 13087-1167 | FITS 97-02 KX125 - 13087-1167 | 1999 | FITS 99-02 KX125 - 21121-1282 | FITS 99 KX125 KX250 - 21066-1116 | FITS 94-02 KX125 - 12053-1325 | FITS 94-02 KX125 - 14026-1193 | FITS 99 KX125 - 13031-1446 - 54.5MM STROKE | 8140 ROD ONLY - FITS 98-02 KX125 | 1881 FITS 99 KX125 11005-1881 | 1999 | FITS 94-02 KX125 - 32029-1896 | FITS 98-01 KX125 - 18069-1140 | 1999 | FITS 99-01 KX125 - 14091-1064 | FITS 98-02 KX125 - 14090-1829 | DENSO 032000-9320 - FITS 99 KX125 - 21007-1349 | FITS 99-01 KX125 KX250 - LH 34028-1475-CE - RH 34028-1476-CE | 1999 | FITS 97-00 KX125 KX250 - 92144-1951 | 1999 | USD - KYB - K312-L K312-R – 46MM CHROME OD - C/L 37 1/4" - GOLD - UPPER 54.8 - LOWER 58.3 - BRAKE MOUNT 102MM - AXLE 25MM & 20MM | 46MM X 58MM X 10.5 | 1999 | WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ | FITS 97-04 KX500, 97-03 KX125 KX250 | 1999 | FITS 98-00 KX125 KX250 44037-1371 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 1999 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | FITS 99-00 KX125 – 44039-1292 | 1999 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 1999 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 99-03 KX125 & 250 – 41068-1406 | 1999 | FITS 99 KX125 KX250 - 43041-1668 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 99-00 KX125 KX250 - 43095-1132 | FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 | 304 - FITS 97-99 KX125 KX250 - 43015-1582 | 1999 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W | 1999 | F-1249 - 20MM AXLE DIA - BRG TO BRG 90MM - ROTOR 4 BOLTS ON A 115MM BC- FITS 99-02 KX125 & 250 - 41034-1300 | BLACK - 51001-1547 - FITS 99-02 KX125 KX250 - 51001-1547-6Z | 1999 | FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124 | 19T - FITS 99-00 KX125 - 59051-1367 | 1999 | FITS 99-00 KX125 - 13070-1326 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 99-00 KX125 - 49111-1061 | 1999 | 1502 FITS 99 KX125 11001-1502 | 31T - FITS 99-02 KX125 - 59051-1365 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | FITS 94-02 KX125 KX250 - 35019-1252-RZ | 1999 | FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE | 700CC =.7L = 23.7 OZ | FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 | 1999 | FITS 99-00 KX125 - 13001-1524 | 20T - FITS 99-02 KX125 - 13097-1399 | FITS 99-02 KX125 KX250 39061-1262 | FITS 99-02 KX125 KX250 39061-1263 | 1999 | FITS 99-02 KX125 KX250, 14037-1257-RZ | FITS 99-02 KX125 KX250 - 49089-1140-6W | FITS 99-02 KX125 KX250 - 49089-1141-6W | 1999 | FITS 93-02 KX125 KX250 - 41068-1343 | HYDRAULIC BRAKE | 1999 | 86E - FITS 99 KX125 KX250 - 43041-1687 | FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F | 1118 - FITS 97-02 KX125 KX250 - 14079-1111 | 1999 | FITS 99-01 KX125 - 43095-1133 | FITS 99 KX125 KX250 - 43077-1085 | FITS 97-01 KX125 KX250, 43015-1597 | 1999 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | GREEN - FITS 99 KX125 KX250 - 35023-1505-6W | 1999 | R-1287 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - FITS 99-02 KX125, 250 - 3 BRG | 1999 | FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM | FITS 99-02 KX125 12021-1116 | 1999 | FITS 99 KX125 KX250 - LOW 53001-1879-MH - HIGH 53001-1880-MH | FITS 94-02 KX125 - 13141-1188 | 1999 | FITS 96-02 KX125 - 13140-1251 - 13140-1252 - 13140-1253 | 1999 | FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 | FITS 99-02 KX125 - 13161-1255 | 1999 | FITS 99 KX125 - 45014-1700-45 | 1999 | 1277 - FITS 99-01 KX125 & KX250 - 39007-1277 | FITS 97-01 KX125 KX250 - 46102-1404 - EYE TO EYE 123.5MM, 15MM ID - STAMPED 04 - 46102-1404 | WHITE - FITS 99-01 KX125 KX250, LH 36001-1627-6F | 1999 | WHITE - FITS 99-01 KX125 KX250, RH 36001-1628-6F | 175A - FITS 99-00 KX125 - 21003-1339 | FITS 92-99 KX125 - 14031-1262 | 1999 | FITS 99 KX125 KX250 - 32160-1547-CC | FITS 99 KX125 – 33001-1556-TX | FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 | 1999 | FITS 92-05 KX125, 92-07 KX250 - ASY | 13T - FITS 94-02 KX125 - 13127-1229 | 14T - FITS 99-04 KX125 - 13260-1748 | 1999 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 24T - FITS 99-02 KX125 - 13260-1750 | 1999 | FITS 99-02 KX125 - 13128-1231 | 31T - FITS 99-05 KX125 - 13260-1752 | 26T - FITS 99-02 KX125 - 13260-1753 | 1999 | 26T - FITS 99-05 KX125 - 13260-1754 | 22T - FITS 99-03 KX125 - 13260-1755 | 27T - FITS 99-02 KX125 - 13260-1756 | SH542-12 FITS 99 KX125 KX250 - 21066-1116 | FITS 88-02 KX125 - 16142-1127 | FITS 94-02 KX125 - 52014-1072 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 99-02 KX125 - 13234-1107 | 1999 | FITS 99 KX125 KX250 - 26030-1655 | ||||||||||||||||
| 2000 | KX125 | KX125LE00XXXX | FITS 2000 KX125 - 14001-1270 | JKAKXRLC4YA01XXXX | 2000 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 99-02 KX125 KX250 11011-1557-6D | 2000 | 1772 - FITS 00 KX125 - 14073 - 1772 | FITS 00-02 KX125 - 54011-1397 | HYDRAULIC | FITS 99-03 KX125 KX250 - 54012-1598 | KEIHIN PWK G523 - FITS 00 KX125 - 15003-1523 | 2000 | DENSO 071000-1600 - 21119-1547 | FITS 99-00 KX125, 99-00 AND 02 KX250 - 92160-1945 | 2000 | FITS 97-02 KX125 KX250 - 33040-1156 | FITS 99-02 KX125 KX250 - 13070-1333 | 2000 | FITS 97-02 KX125 KX250 - 12053-1376 | FITS 99-03 KX125 KX250 12053-1422 | FITS 99-02 KX125 - 13095-1367 | FITS 94-02 KX125 | 2000 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 99-02 KX125 - 14032-1481 | 2000 | FITS 00-02 KX125 - 14032-1506 | FITS 97-02 KX125 - 13087-1167 | FITS 97-02 KX125 - 13087-1167 | 2000 | FITS 99-02 KX125 - 21121-1282 | FITS 94-02 KX125 - 12053-1325 | FITS 94-02 KX125 - 14026-1193 | FITS 00-01 KX125 - 13031-1465 - 54.5MM STROKE | 8140 ROD ONLY - FITS 98-02 KX125 | 1921 FITS 00 KX125 11005-1921 | 2000 | FITS 94-02 KX125 - 32029-1896 | FITS 98-01 KX125 - 18069-1140 | 2000 | FITS 99-01 KX125 - 14091-1064 | FITS 98-02 KX125 - 14090-1829 | DENSO 032000-9 | FITS 99-01 KX125 KX250 - LH 34028-1475-CE - RH 34028-1476-CE | 2000 | FITS 97-00 KX125 KX250 - 92144-1951 | 2000 | KYB - USD - K312-L K312-R - 46MM CHROME OD - C/L 37 1/2" - UPPER 54.9MM - LOWER 58.4MM - C/L CALIPER MOUNT 102MM - AXLE 25MM & 20MM | 46MM X 58MM X 10.5 | 2000 | WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ | FITS 97-04 KX500, 97-03 KX125 KX250 | 2000 | FITS 98-00 KX125 KX250 44037-1371 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 2000 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | FITS 99-00 KX125 – 44039-1292 | 2000 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 2000 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 99-03 KX125 & 250 – 41068-1406 | 2000 | NISSIN ML3 3- FITS 00 KX125 KX250 - 43041-1721 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 99-00 KX125 KX250 - 43095-1132 | FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 | NISSIN 304 - FITS 00 KX125 KX250 KX65 - 43015-1654 | 2000 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W | 2000 | F-1249 - 20MM AXLE DIA - BRG TO BRG 90MM - ROTOR 4 BOLTS ON A 115MM BC- FITS 99-02 KX125 & 250 - 41034-1300 | BLACK - 51001-1547 - FITS 99-02 KX125 KX250 - 51001-1547-6Z | 2000 | FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124 | 19T - FITS 99-00 KX125 - 59051-1367 | 2000 | FITS 99-00 KX125 - 13070-1326 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 99-00 KX125 - 49111-1061 | 2000 | 1532 FITS 00 KX125 11001-1532 | 31T - FITS 99-02 KX125 - 59051-1365 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | FITS 94-02 KX125 KX250 - 35019-1252-RZ | 2000 | FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE | 700CC =.7L = 23.7 OZ | FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 | 2000 | FITS 99-00 KX125 - 13001-1524 | 20T - FITS 99-02 KX125 - 13097-1399 | FITS 99-02 KX125 KX250 39061-1262 | FITS 99-02 KX125 KX250 39061-1263 | 2000 | FITS 99-02 KX125 KX250, 14037-1257-RZ | FITS 99-02 KX125 KX250 - 49089-1140-6W | FITS 99-02 KX125 KX250 - 49089-1141-6W | 2000 | FITS 93-02 KX125 KX250 - 41068-1343 | HYDRAULIC BRAKE | 2000 | FITS 00 KX125 & KX250 43041-1722 | FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F | 1118 - FITS 97-02 KX125 KX250 - 14079-1111 | 2000 | FITS 99-01 KX125 - 43095-1133 | FITS 00-02 KX250 & KX125 - 13236-1339 | FITS 97-01 KX125 KX250, 43015-1597 | 2000 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | FITS 00-02 KX125 KX250, 35023-1511-6W | 2000 | R-1287 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - FITS 99-02 KX125, 250 - 3 BRG | 2000 | FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM | FITS 99-02 KX125 12021-1116 | 2000 | FITS 00 KX125 KX250, LOW SEAT 53001-1918-NL, HIGH SEAT 53001-1919-NL | FITS 94-02 KX125 - 13141-1188 | 2000 | FITS 96-02 KX125 - 13140-1251 - 13140-1252 - 13140-1253 | 2000 | FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 | FITS 99-02 KX125 - 13161-1255 | 2000 | SPRING THICKNESS: 11.5MM OD - SPRING DIAMETER: 88MM - EYE TO EYE 454MM (17 7/8") - CHROME OD 16MM - BODY OD 53.6MM - UPPER MOUNT TAB THICKNESS: 25MM - UPPER MOUNT TAB HOLE ID: 10MM - LOWER MOUNT MAJOR WIDTH: 40.0MM - LOWER MOUNT MINOR WIDTH: 37.36MM - LOWER MOUNT HOLE ID: 10MM | 2000 | 1277 - FITS 99-01 KX125 & KX250 - 39007-1277 | FITS 97-01 KX125 KX250 - 46102-1404 - EYE TO EYE 123.5MM, 15MM ID - STAMPED 04 - 46102-1404 | WHITE - FITS 99-01 KX125 KX250, LH 36001-1627-6F | 2000 | WHITE - FITS 99-01 KX125 KX250, RH 36001-1628-6F | 175A - FITS 99-00 KX125 - 21003-1339 | FITS 00-02 KX125 - 14031-1376 | 2000 | FITS 00-02 KX125, KX250 - 32160-1647-CC | FITS 00-02 KX125 – 33001-1575-TX | FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 | 2000 | FITS 92-05 KX125, 92-07 KX250 - ASY | 13T - FITS 94-02 KX125 - 13127-1229 | 14T - FITS 99-04 KX125 - 13260-1748 | 2000 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 24T - FITS 99-02 KX125 - 13260-1750 | 2000 | FITS 99-02 KX125 - 13128-1231 | 31T - FITS 99-05 KX125 - 13260-1752 | 26T - FITS 99-02 KX125 - 13260-1753 | 2000 | 26T - FITS 99-05 KX125 - 13260-1754 | 22T - FITS 99-03 KX125 - 13260-1755 | 27T - FITS 99-02 KX125 - 13260-1756 | FITS 88-02 KX125 - 16142-1127 | FITS 94-02 KX125 - 52014-1072 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 99-02 KX125 - 13234-1107 | 2000 | FITS 00 KX125 KX250 - 26030-1676 | ||||||||||||||||||||
| 2001 | KX125 | KX125LE00XXXX | FITS 01-02 KX125 - 14001-1278 | JKAKXRLC81A02XXXX | 2001 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 99-02 KX125 KX250 11011-1557-6D | 2001 | 1787 - FITS 01-02 KX125 - 14073-1787 | FITS 00-02 KX125 - 54011-1397 | HYDRAULIC | FITS 99-03 KX125 KX250 - 54012-1598 | MIKUNI TMX 36MM | 2001 | FITS 00 KX125 | DENSO 071000-1780 - 21119-1574 | 2001 | FITS 97-02 KX125 KX250 - 33040-1156 | FITS 99-02 KX125 KX250 - 13070-1333 | 2001 | FITS 97-02 KX125 KX250 - 12053-1376 | FITS 99-03 KX125 KX250 12053-1422 | FITS 99-02 KX125 - 13095-1367 | FITS 94-02 KX125 | 2001 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 99-02 KX125 - 14032-1481 | 2001 | FITS 00-02 KX125 - 14032-1506 | FITS 97-02 KX125 - 13087-1167 | FITS 97-02 KX125 - 13087-1167 | 2001 | FITS 99-02 KX125 - 21121-1282 | FITS 94-02 KX125 - 12053-1325 | FITS 94-02 KX125 - 14026-1193 | FITS 00-01 KX125 - 13031-1465 - 54.5MM STROKE | 8140 ROD ONLY - FITS 98-02 KX125 | 1939 FITS 01 KX125 11005-1939 | 2001 | FITS 94-02 KX125 - 32029-1896 | FITS 98-01 KX125 - 18069-1140 | 2001 | FITS 99-01 KX125 - 14091-1064 | FITS 98-02 KX125 - 14090-1829 | DENSO 032000-9620 | FITS 99-01 KX125 KX250 - LH 34028-1475-CE - RH 34028-1476-CE | 2001 | 2001 | KYB - USD - K312-L K312-R - 46MM CHROME OD - C/L 37 1/2" - UPPER 54.9MM - LOWER 58.4MM - C/L CALIPER MOUNT 102MM - AXLE 25MM & 20MM | 46MM X 58MM X 10.5 | 2001 | WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ | FITS 97-04 KX500, 97-03 KX125 KX250 | 2001 | FITS 01 KX125 KX250 – 44037-1415 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 2001 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | FITS 01 KX125 – 44039-1312 | 2001 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 2001 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 99-03 KX125 & 250 – 41068-1406 | 2001 | FITS 01 KX125 KX250 - 43041-1839 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 01-03 KX125 KX250 - 43095-1212 | FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 | NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674 | 2001 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W | 2001 | F-1249 - 20MM AXLE DIA - BRG TO BRG 90MM - ROTOR 4 BOLTS ON A 115MM BC- FITS 99-02 KX125 & 250 - 41034-1300 | BLACK - 51001-1547 - FITS 99-02 KX125 KX250 - 51001-1547-6Z | 2001 | FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124 | 2001 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | 2001 | 1554 FITS 01 KX125 11001-1554 | 31T - FITS 99-02 KX125 - 59051-1365 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | FITS 94-02 KX125 KX250 - 35019-1252-RZ | 2001 | FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE | 700CC =.7L = 23.7 OZ | FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 | 2001 | 20T - FITS 99-02 KX125 - 13097-1399 | FITS 99-02 KX125 KX250 39061-1262 | FITS 99-02 KX125 KX250 39061-1263 | 2001 | FITS 99-02 KX125 KX250, 14037-1257-RZ | FITS 99-02 KX125 KX250 - 49089-1140-6W | FITS 99-02 KX125 KX250 - 49089-1141-6W | 2001 | FITS 93-02 KX125 KX250 - 41068-1343 | HYDRAULIC BRAKE | 2001 | FITS 01-02 KX125 KX250 43041-1826 | FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F | 1118 - FITS 97-02 KX125 KX250 - 14079-1111 | 2001 | FITS 99-01 KX125 - 43095-1133 | FITS 00-02 KX250 & KX125 - 13236-1339 | FITS 97-01 KX125 KX250, 43015-1597 | 2001 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | FITS 00-02 KX125 KX250, 35023-1511-6W | 2001 | R-1287 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - FITS 99-02 KX125, 250 - 3 BRG | 2001 | FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM | FITS 99-02 KX125 12021-1116 | 2001 | FITS 94-02 KX125 - 13141-1188 | 2001 | FITS 96-02 KX125 - 13140-1251 - 13140-1252 - 13140-1253 | 2001 | FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 | FITS 99-02 KX125 - 13161-1255 | 2001 | SPRING THICKNESS: 11.5MM OD - SPRING DIAMETER: 88MM - UPPER MOUNT TAB THICKNESS: 22MM - UPPER MOUNT TAB HOLE ID: 10MM - LOWER MOUNT MAJOR WIDTH: 37.2MM - LOWER MOUNT MINOR WIDTH: 22.5MM - LOWER MOUNT HOLE ID: 10MM - EYE TO EYE: 455MM | 2001 | 1277 - FITS 99-01 KX125 & KX250 - 39007-1277 | FITS 97-01 KX125 KX250 - 46102-1404 - EYE TO EYE 123.5MM, 15MM ID - STAMPED 04 - 46102-1404 | WHITE - FITS 99-01 KX125 KX250, LH 36001-1627-6F | 2001 | WHITE - FITS 99-01 KX125 KX250, RH 36001-1628-6F | 175A | FITS 00-02 KX125 - 14031-1376 | 2001 | FITS 00-02 KX125, KX250 - 32160-1647-CC | FITS 00-02 KX125 – 33001-1575-TX | FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 | 2001 | FITS 92-05 KX125, 92-07 KX250 - ASY | 13T - FITS 94-02 KX125 - 13127-1229 | 14T - FITS 99-04 KX125 - 13260-1748 | 2001 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 24T - FITS 99-02 KX125 - 13260-1750 | 2001 | FITS 99-02 KX125 - 13128-1231 | 31T - FITS 99-05 KX125 - 13260-1752 | 26T - FITS 99-02 KX125 - 13260-1753 | 2001 | 26T - FITS 99-05 KX125 - 13260-1754 | 22T - FITS 99-03 KX125 - 13260-1755 | 27T - FITS 99-02 KX125 - 13260-1756 | FITS 88-02 KX125 - 16142-1127 | FITS 94-02 KX125 - 52014-1072 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 99-02 KX125 - 13234-1107 | 2001 | FITS 01-02 KX125 - 26030-1790 | ||||||||||||||||||||||||||
| 2002 | KX125 | KX125LE00XXXX | FITS 01-02 KX125 - 14001-1278 | JKAKXRLC72A03XXXX | 2002 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 99-02 KX125 KX250 11011-1557-6D | 2002 | 1787 - FITS 01-02 KX125 - 14073-1787 | FITS 00-02 KX125 - 54011-1397 | HYDRAULIC | FITS 99-03 KX125 KX250 - 54012-1598 | MIKUNI TMX - 38MM | 2002 | FITS 01 KX125 | DENSO 071000-2026 - 21119-1597 | 2002 | FITS 97-02 KX125 KX250 - 33040-1156 | FITS 99-02 KX125 KX250 - 13070-1333 | 2002 | FITS 97-02 KX125 KX250 - 12053-1376 | FITS 99-03 KX125 KX250 12053-1422 | FITS 99-02 KX125 - 13095-1367 | FITS 94-02 KX125 | 2002 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 94-02 KX125 | FITS 99-02 KX125 - 14032-1481 | 2002 | FITS 00-02 KX125 - 14032-1506 | FITS 97-02 KX125 - 13087-1167 | FITS 97-02 KX125 - 13087-1167 | 2002 | FITS 99-02 KX125 - 21121-1282 | FITS 94-02 KX125 - 12053-1325 | FITS 94-02 KX125 - 14026-1193 | FITS 02 KX125 - 13031-1494 - 54.5MM STROKE | 8140 ROD ONLY - FITS 98-02 KX125 | 1960 FITS 02 KX125 11005-1960 | 2002 | FITS 94-02 KX125 - 32029-1896 | 2002 | FITS 02 KX125 - 14091-1498 | FITS 98-02 KX125 - 14090-1829 | DENSO 032000-9620 | 2002 | 2002 | KYB - USD - K312-R2 K312-L2 - 48MM CHROME OD - C/L 37 1/2" - UPPER 55.9MM - LOWER 59.2MM - BRAKE MOUNT C/L 102MM - AXLE 25MM & 20MM | 48MM X 58MM X 8.5/10 | 2002 | WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ | FITS 97-04 KX500, 97-03 KX125 KX250 | 2002 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 2002 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | 2002 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 2002 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 99-03 KX125 & 250 – 41068-1406 | 2002 | FITS 02 KX125 KX250 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 01-03 KX125 KX250 - 43095-1212 | FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 | NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674 | 2002 | ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W | 2002 | F-1249 - 20MM AXLE DIA - BRG TO BRG 90MM - ROTOR 4 BOLTS ON A 115MM BC- FITS 99-02 KX125 & 250 - 41034-1300 | BLACK - 51001-1547 - FITS 99-02 KX125 KX250 - 51001-1547-6Z | 2002 | FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124 | 2002 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | 2002 | 1564 FITS 02 KX125 11001-1564 | 31T - FITS 99-02 KX125 - 59051-1365 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | FITS 94-02 KX125 KX250 - 35019-1252-RZ | 2002 | FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE | 700CC =.7L = 23.7 OZ | FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 | 2002 | 20T - FITS 99-02 KX125 - 13097-1399 | FITS 99-02 KX125 KX250 39061-1262 | FITS 99-02 KX125 KX250 39061-1263 | 2002 | FITS 99-02 KX125 KX250, 14037-1257-RZ | FITS 99-02 KX125 KX250 - 49089-1140-6W | FITS 99-02 KX125 KX250 - 49089-1141-6W | 2002 | FITS 93-02 KX125 KX250 - 41068-1343 | HYDRAULIC BRAKE | 2002 | FITS 01-02 KX125 KX250 43041-1826 | FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F | 1118 - FITS 97-02 KX125 KX250 - 14079-1111 | 2002 | FITS 00-02 KX250 & KX125 - 13236-1339 | 2002 | ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 | FITS 00-02 KX125 KX250, 35023-1511-6W | 2002 | R-1287 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - FITS 99-02 KX125, 250 - 3 BRG | 2002 | FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM | FITS 99-02 KX125 12021-1116 | 2002 | FITS 02 KX125 KX250 | FITS 94-02 KX125 - 13141-1188 | 2002 | FITS 96-02 KX125 - 13140-1251 - 13140-1252 - 13140-1253 | 2002 | FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 | FITS 99-02 KX125 - 13161-1255 | 2002 | KYB - SPRING THICKNESS: 11.5MM OD - SPRING DIAMETER: 88MM - UPPER MOUNT TAB THICKNESS: 22MM - UPPER MOUNT TAB HOLE ID: 10MM - LOWER MOUNT MAJOR WIDTH: 37.2MM - LOWER MOUNT MINOR WIDTH: 22.5MM - LOWER MOUNT HOLE ID: 10MM - 454MM (17 7/8") | 2002 | FITS 02 KX125 KX250 - 39007-1301 | FITS 02 KX125 KX250 - 46102-1289 | 2002 | 175A FITS 2002 KX125 | FITS 00-02 KX125 - 14031-1376 | 2002 | FITS 00-02 KX125, KX250 - 32160-1647-CC | FITS 00-02 KX125 – 33001-1575-TX | FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 | 2002 | FITS 92-05 KX125, 92-07 KX250 - ASY | 13T - FITS 94-02 KX125 - 13127-1229 | 14T - FITS 99-04 KX125 - 13260-1748 | 2002 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 24T - FITS 99-02 KX125 - 13260-1750 | 2002 | FITS 99-02 KX125 - 13128-1231 | 31T - FITS 99-05 KX125 - 13260-1752 | 26T - FITS 99-02 KX125 - 13260-1753 | 2002 | 26T - FITS 99-05 KX125 - 13260-1754 | 22T - FITS 99-03 KX125 - 13260-1755 | 27T - FITS 99-02 KX125 - 13260-1756 | FITS 88-02 KX125 - 16142-1127 | FITS 94-02 KX125 - 52014-1072 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | FITS 99-02 KX125 - 13234-1107 | 2002 | FITS 01-02 KX125 - 26030-1790 | |||||||||||||||||||||||||||||||||
| 2003 | KX125 | KX125ME00XXXX | FITS 2003 KX125 - 14001-5403 | JKAKXRMC73A00XXXX | 2003 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 03 KX125 KX250 11011-1656 | 2003 | 0003 - FITS 03 KX125 - 14073-0003 | FITS 03 KX125 - 54011-1418 | HYDRAULIC | FITS 99-03 KX125 KX250 - 54012-1598 | MIKUNI 38MM | 2003 | FITS 02 KX125 | DENSO 071000-2150 - 21119-1618 | 2003 | FITS 03-05 KX125, 03-08 KX250, 04-05 KX250F 12053-1468 | 2003 | FITS 99-03 KX125 KX250 12053-1422 | FITS 03-05 KX125 | 2003 | FITS 03-05 KX125 | FITS 03-05 KX125 | FITS 03-05 KX125 | 2003 | FITS 03-05 KX125 - 14032-1532 | FITS 03-05 KX125, 04-14 KX250F - 13187-1089 | 2003 | 1312 3905 FITS 03-04 KX125 | FITS 03 KX125 - 13031-1499 - 54.5MM STROKE | 4055 FITS 03-05 KX125 | 1978 FITS 03 KX125 11005-1978 | 2003 | 2003 | Fits 03 KX125 - 14091-1481 | DENSO | 2003 | 2003 | USD - 48MM CHROME OD - C/L 37 1/2" LOWER 59.2MM UPPER 55.9 | 48MM X 58MM X 8.5/10 | 2003 | WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ | FITS 97-04 KX500, 97-03 KX125 KX250 | 2003 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 2003 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | 2003 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 2003 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 99-03 KX125 & 250 – 41068-1406 | 2003 | FITS 03 KX125 KX250 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 01-03 KX125 KX250 - 43095-1212 | FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 | NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674 | 2003 | 2003 | 20MM AXLE DIA - BRG TO BRG 90MM - FITS 03 KX125, KX250 - 41034-1346 | 2003 | FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124 | 2003 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 2003 | 1573 FITS 03 KX125 11001-1573 | 31T - FITS 03-05 KX125 - 59051-1406 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | 2003 | FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 | 2003 | FITS 03 KX125 KX250 39061-1309 | FITS 03 KX125 KX250 39061-1311 | 2003 | 2003 | FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 | HYDRAULIC BRAKE | 2003 | 2003 | FITS 03 KX125 | 2003 | FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514 | 2003 | 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 | 2003 | FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM | 2003 | FITS 03-05 KX125 | 2003 | 2003 | 2003 | 2003 | FITS 03 KX125 KX250 - 39007-1306 | FITS 03 KX125 - 46102-1467 | 2003 | 2003 | FITS 03 KX125 KX250 - 32160-1787 | FITS 03 KX125 – 33001-1628-CE | FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 | 2003 | FITS 92-05 KX125, 92-07 KX250 - ASY | SHAFTS FIT 03-04 KX125, GEARS FIT 03-04 KX125 | 14T - FITS 99-04 KX125 - 13260-1748 | 2003 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 2003 | 31T - FITS 99-05 KX125 - 13260-1752 | 2003 | 26T - FITS 99-05 KX125 - 13260-1754 | 22T - FITS 99-03 KX125 - 13260-1755 | FITS 88-02 KX125 - 16142-1127 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | 2003 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 2004 | KX125 | KX125ME00XXXX | FITS 2004 KX125 - 14001-0006 | JKAKXRNC84A01XXXX | 2004 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 04-05 KX125, 04 KX250 11011-0012 | 2004 | 0034 - FITS 04-05 KX125 - 14073-0034 | FITS 04-05 KX125 - 54011-0021 | HYDRAULIC | FITS 04 KX125 KX250 - 54012-0101 | MIKUNI | 2004 | DENSO 0710000-2480 - 21119-0006 | 2004 | FITS 03-05 KX125, 03-08 KX250, 04-05 KX250F 12053-1468 | 2004 | FITS 04-05 KX125, 04-07 KX250 - 12053-0020 | FITS 03-05 KX125 | 2004 | FITS 03-05 KX125 | FITS 03-05 KX125 | FITS 03-05 KX125 | 2004 | FITS 03-05 KX125 - 14032-1532 | FITS 03-05 KX125, 04-14 KX250F - 13187-1089 | 2004 | 1312 3905 FITS 03-04 KX125 | FITS 04-05 KX125 - 13031-0017 - 54.5MM STROKE | 4055 FITS 03-05 KX125 | 0013 FITS 04 KX125 11005-0013 | 2004 | 2004 | FITS 04-05 KX125 - 14091-0173 | DENSO 032000-9880 9EY | 2004 | 2004 | USD - 48MM CHROME OD | 48MM X 58MM X 8.5/10 | 2004 | FITS 04-05 KX125 04-06 KX250 - 13070-0025 - 13070-0027 | 2004 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 2004 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | 2004 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 2004 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004 | 2004 | 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 04 KX125 KX250 KX250F - 43095-0054 | FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 | NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674 | 2004 | 2004 | F-0012 - BRG ID 20MM - BRG TO BRG 90MM - 36 SPOKES - ROTOR BC 4X AT 116MM - FITS 04-05 KX125 KX250 KX250F - 41034-0018 | 2004 | FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124 | 2004 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 2004 | 0013 FITS 04-05 KX1250 11001-0013 | 31T - FITS 03-05 KX125 - 59051-1406 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | 2004 | FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 | 2004 | FITS 04-05 KX125, 04 KX250 39061-0012 | FITS 04-05 KX125, 04 KX250 39061-0013 | 2004 | 2004 | FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 | HYDRAULIC BRAKE | 2004 | FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514 | 2004 | FITS 04-05 KX125 | FITS 04-05 KX125, 04 KX250 - 43015-0009 | 2004 | FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514 | 2004 | 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 | 2004 | FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM | 72MM X 58.5MM | 2004 | FITS 03-05 KX125 | 2004 | 2004 | 2004 | 2004 | FITS 04-05 KX125 3907-0002 | 2004 | 175A 9EY | 14031-1397A | 2004 | FITS 04 KX125 KX250 - 32160-0015 | FITS 04 KX125 – 33001-0024-CE | FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 | 2004 | FITS 92-05 KX125, 92-07 KX250 - ASY | SHAFTS FIT 03-04 KX125, GEARS FIT 03-04 KX125 | 14T - FITS 99-04 KX125 - 13260-1748 | 2004 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 3RD AND 4TH 17T 17T - FITS 99-04 KX125 - 13260-1749 | 2004 | 31T - FITS 99-05 KX125 - 13260-1752 | 2004 | 26T - FITS 99-05 KX125 - 13260-1754 | FITS 88-02 KX125 - 16142-1127 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | 2004 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 2005 | KX125 | KX125ME00XXXX | FITS 2005 KX125 - 14001-5402 | 2005 | FITS 90-05 KX125, 90-07 KX250 - 13091-1664 | FITS 04-05 KX125, 04 KX250 11011-0012 | 2005 | 0034 - FITS 04-05 KX125 - 14073-0034 | FITS 04-05 KX125 - 54011-0021 | HYDRAULIC | MIKUNI TMX38X | 2005 | 2005 | FITS 03-05 KX125, 03-08 KX250, 04-05 KX250F 12053-1468 | 2005 | FITS 04-05 KX125, 04-07 KX250 - 12053-0020 | FITS 03-05 KX125 | 2005 | FITS 03-05 KX125 | FITS 03-05 KX125 | FITS 03-05 KX125 | 2005 | FITS 03-05 KX125 - 14032-1532 | FITS 03-05 KX125, 04-14 KX250F - 13187-1089 | 2005 | FITS 04-05 KX125 - 13031-0017 - 54.5MM STROKE | 4055 FITS 03-05 KX125 | 0026 FITS 05 KX125 11005-0026 | 2005 | 2005 | FITS 04-05 KX125 - 14091-0173 | 2005 | 2005 | USD - 48MM CHROME OD | 48MM X 58MM X 8.5/10 | 2005 | FITS 04-05 KX125 04-06 KX250 - 13070-0025 - 13070-0027 | 2005 | FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S | 2005 | LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM | 2005 | FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F | 2005 | UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM | FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004 | 2005 | 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 | NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 05 KX125 KX250, 05-06 KX250F - 43095-0060 | FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 | 2005 | 2005 | F-0012 - BRG ID 20MM - BRG TO BRG 90MM - 36 SPOKES - ROTOR BC 4X AT 116MM - FITS 04-05 KX125 KX250 KX250F - 41034-0018 | 2005 | FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124 | 2005 | FITS 85-96 03-05 KX125, 87-92 KX250, 86-04 KX500 - 13070-1122 | FITS 88-05 KX125, 87-92 KX250, 86-04 KX500, 88-06 KDX200, 91-94 KDX250, 97-05 KDX220 - 49114-1058 | FITS 85-94 96 03-05, 85-93 KX250, 86 KX500 - 49111-1051 | 2005 | 0013 FITS 04-05 KX1250 11001-0013 | 31T - FITS 03-05 KX125 - 59051-1406 | FITS 90-05 KX125 - 13064-0001 | FITS 82-05 KX125 - 13066-1101 | 2005 | FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 | 2005 | FITS 04-05 KX125, 04 KX250 39061-0012 | FITS 04-05 KX125, 04 KX250 39061-0013 | 2005 | 2005 | FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 | HYDRAULIC BRAKE | 2005 | FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514 | 2005 | FITS 04-05 KX125 | FITS 04-05 KX125, 04 KX250 - 43015-0009 | 2005 | FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514 | 2005 | 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 | 2005 | FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM | 2005 | FITS 03-05 KX125 | 2005 | 2005 | 2005 | 2005 | FITS 04-05 KX125 3907-0002 | 2005 | 2005 | FITS 05 KX125 KX250 - 32160-0068 | FITS 05 KX125 – 33001-0052-458 | FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 | 2005 | FITS 92-05 KX125, 92-07 KX250 - ASY | 2005 | 2005 | 31T - FITS 99-05 KX125 - 13260-1752 | 2005 | 26T - FITS 99-05 KX125 - 13260-1754 | FITS 88-02 KX125 - 16142-1127 | FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 | 2005 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| YEAR | TYPE | ENGINE ID | ENGINE CASES | VIN FRAME USA | YEAR | AIR BOX CAGE ELEMENT HOLDER | AIR BOX - NO BOOT | YEAR | AIR BOX TO CARBURETOR BOOT | CABLE CLUTCH | CABLE FRONT BRAKE | CABLE THROTTLE | CARBURETOR | YEAR | CARBURETOR BOOT | CDI | CDI HOLDER DAMPENER | YEAR | CHAIN ADJUSTER BLOCKS | CHAIN GUIDE (ALUMINUM HOUSING) | YEAR | CHAIN GUIDE (PLASTIC BLOCK) | CHAIN SLIDE | CLUTCH ARM | CLUTCH BASKET | CLUTCH BASKET HINSON | YEAR | CLUTCH BASKET MITAKA | CLUTCH BASKET TALON | CLUTCH BASKET WISECO | CLUTCH COVER | YEAR | CLUTCH COVER INNER | CLUTCH HUB (INNER) | CLUTCH PRESSURE PLATE (OUTER) | YEAR | COIL | CONDENSOR | COUNTER SPROCKET GUARD (ALUMINUM) | COUNTER SPROCKET GUARD (PLASTIC) | CRANK SHAFT | CRANK SHAFT HOT RODS | CYLINDER | YEAR | ENGINE MOUNTS UPPER | EXHAUST FLANGE | EXHAUST PIPE | EXHAUST PIPE (FMF FATTY) | EXHAUST MUFFLER | EXHAUST VALVE SET | EXHAUST VALVE MAIN | EXHAUST VALVE LEFT | EXHAUST VALVE RIGHT | YEAR | EXHAUST VALVE COVER FRONT | EXHAUST VALVE COVER LEFT (RESONATOR) | EXHAUST VALVE COVER RIGHT | FLY WHEEL ROTOR | FOOT PEGS | YEAR | FOOT PEG SPRINGS | YEAR | FORK INFO | FORK SEAL SIZE | YEAR | FORK AXLE CLAMP | FORK GUARDS | FORK GUARD MOUNTS | YEAR | FORK UNDER HOLDER (STEERING STEM) | FORK UNDER HOLDER BEARING (STEERING STEM) | YEAR | FORK UNDER HOLDER BEARING MEASUREMENTS (STEERING STEM) | FORK UPPER HOLDER (TOP CLAMP) | YEAR | FORK UPPER HOLDER BEARING(TOP CLAMP) | YEAR | FORK UPPER HOLDER BEARING MEASUREMENTS(TOP CLAMP) | FRONT AXLE | FRONT AXLE HOLDER | YEAR | FRONT BRAKE CALIPER | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE HOSE | FRONT BRAKE LEVER | FRONT BRAKE MASTER CYLINDER | YEAR | FRONT BRAKE ROTOR | FRONT FENDER | YEAR | FRONT HUB | GAS TANK | YEAR | GAS TANK CAP | GOVERNOR SPUR GEAR | YEAR | GOVERNOR GUIDE | GOVERNOR ROD | GOVERNOR SHAFT | GOVERNOR WEIGHT HOLDER | YEAR | HEAD | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | MUD FLAP | YEAR | NUMBER PLATE | OIL CAPACITY | OIL DRAIN PLUG | YEAR | PETCOCK FUEL VALVE TAP | PISTON (STOCK) | PRIMARY CRANK GEAR | RADIATOR LEFT | RADIATOR RIGHT | YEAR | RADIATOR SCREENS | RADIATOR SHROUD LEFT | RADIATOR SHROUD RIGHT | YEAR | REAR AXLE | REAR BRAKE BACKING PLATE | YEAR | REAR BRAKE CALIPER | REAR BRAKE CALIPER GUARD | REAR BRAKE CALIPER MOUNT | YEAR | REAR BRAKE HOSE | REAR BRAKE LEVER | REAR BRAKE MASTER CYLINDER | REAR BRAKE MASTER CYLINDER GUARD | YEAR | REAR BRAKE ROD | REAR BRAKE ROTOR | REAR FENDER | YEAR | REAR HUB | YEAR | REAR WHEEL SPACERS | REED BOLT PATTERN | YEAR | SEAT | SHIFT DRUM | YEAR | SHIFT FORKS | SHIFT FORK ALIGNMENT RODS PINS SHAFTS | YEAR | SHIFT LEVER | SHIFT SHAFT | YEAR | SHOCK - SOME OF THESE MEASUREMENTS CAN VARY DEPENDING IF THE SPRING HAS BEEN REPLACED OR ADJUSTED | YEAR | SHOCK ARM (UNI-TRAK ARM) | SHOCK ARM LINKAGE (SUSPENSION RODS) | SIDE COVER LEFT | YEAR | SIDE COVER RIGHT | STATOR | STATOR COVER | YEAR | SUB FRAME | SWING ARM | SWING ARM PIVOT PIN / AXLE | YEAR | THROTTLE HOUSING | TRANSMISSION | TRANSMISSION INPUT SHAFT | TRANSMISSION INPUT 2ND GEAR | YEAR | TRANSMISSION INPUT 3RD GEAR | TRANSMISSION INPUT 4TH GEAR | TRANSMISSION INPUT 5TH GEAR | YEAR | TRANSMISSION OUTPUT SHAFT | TRANSMISSION OUTPUT SHAFT 1ST GEAR | TRANSMISSION OUTPUT SHAFT 2ND GEAR | YEAR | TRANSMISSION OUTPUT SHAFT 3RD GEAR | TRANSMISSION OUTPUT SHAFT 4TH GEAR | TRANSMISSION OUTPUT SHAFT 5TH GEAR | VOLTAGE REGULATOR | WATER PUMP COVER | WATER PUMP ELBOW | WATER PUMP IMPELLER | WATER PUMP SHAFT | YEAR | WIRE HARNESS |
