OEM-CYCLE
OEM-CYCLE HOME
About Us
Contact Us
Site Map
Used Dirt Bike Parts
ATK Used Parts
Bultaco Used Parts
Honda Used Parts
Husaberg Used Parts
Husqvarna Used Parts
Kawasaki Used Parts
KTM Used Parts
Maico Used Parts
Suzuki Used Parts
Yamaha Used Parts
Misc Used Parts
Bike Identification
What year is my dirt bike
WORLD WIDE PICS CR125
WORLD WIDE PICS CR500
World Wide Pics Of KX500
WORLD WIDE PICS KX450F
WORLD WIDE PICS KX250
WORLD WIDE PICS RM250
WORLD WIDE PICS YZ250
Building our new shop
KX500 JETTING GUIDE
CRANK BEARING REMOVAL
SPLITTING YOUR CASES
BIKES IN DISASSEMBLY
Employees wasting time
Misc Parts
2006 Tundra rear brake re
Picture for 2005 Honda CRF230F
SPECS for 2005 Honda CRF230F:
ENGINE
Engine Type: 223cc air-cooled single-cylinder four-stroke
Bore and Stroke: 65.5mm x 66.2mm
Compression Ratio: 9.0:1
Valve Train: SOHC; two-valve
Carburetion: 26mm piston-valve
Ignition: CDI
DRIVE TRAIN
Transmission: Six-speed
Final Drive: #520 O-ring-sealed chain; 13T/50T
CHASSIS / SUSPENSION / BRAKES
Front Suspension: 37mm leading-axle Showa fork; 9.5-inch travel
Rear Suspension: Pro-Link Showa single-shock with spring-preload adjustability; 9.0-inch travel
Front Brake: Single 240mm disc
Rear Brake: Drum
Front Tire: 80/100-21
Rear Tire: 100/100-18
DIMENSIONS
Rake: 27.3 degrees
Trail: 112.0mm (4.4 inches)
Wheelbase: 54.1 inches
Seat Height: 34.1 inches
Ground Clearance: 11.7 inches
Dry Weight: 238.0 pounds
Fuel Capacity: 2.2 gallons, including 0.4-gallon reserve
