Gear repair?
- 60something
Re: Gear repair?
Apparently long obsolete
2006 Kawasaki KDX200 qty-2
1987 Kawasaki KX500
1991 Honda CB750 Nighthawk
1973 Kawasaki H2 750 Triple - gone but not forgotten
1987 Kawasaki KX500
- 60something
Re: Gear repair?
I've had no luck on finding the power valve rod. Posted on the 3rd Gen KX500 Facebook page, but no luck yet.
1987 Kawasaki KX500
1987 Kawasaki KX500
- 60something
Re: Gear repair?
I think I have a solution to the power valve rod issue. I have found oak doweling that is quite hard. I have a friend who has a lathe who can whittle it down to the correct diameter for the rod, then we will make replacement power valves in the same manner. From there it will simply be a matter of notching the parts for the gear part. The only thing I have any real concern about is the rate of expansion of the oak vs the aluminum cylinder, but I'll never know unless I try...
1987 Kawasaki KX500
1987 Kawasaki KX500
Re: Gear repair?
Oak?
I wonder how oak will handle temps in the 175-225F range...
Then I wonder about how it will work being soaked in oil?
My guess is it might work for a bit but I doubt it's a viable long term solution.
But if you pull it off, be sure to post pics
- 60something
Re: Gear repair?
My post from APRIL 1
1987 Kawasaki KX500
1987 Kawasaki KX500
- 60something
Re: Gear repair?
Nevertheless, I still need that part...no luck
1987 Kawasaki KX500
1987 Kawasaki KX500
Re: Gear repair?
Ah... you got me good.
But one good turn deserves another
- 60something
Re: Gear repair?
uh-oh
1987 Kawasaki KX500
1987 Kawasaki KX500
Users browsing this forum: No registered users and 11 guests
