KX500 Crank Gear Spur for impeller/water pump. Question
Tearing my motor down and found the gear on the crankshaft is chipped and cracked. At first I thought they cut the gear on the crank! But apparently it seems to be a press/interference fit? Correct?
Re: KX500 Crank Gear Spur for impeller/water pump. Question
Yes, it is lightly pressed in.
59051-1128 is the part number.
I don't have the size of the shaft that goes into the crank.
So, if it breaks off while removing, just order a new one (If you haven't already) and when it comes in measure it.
Then get a drill that is a little smaller and go for it
Let us know the results..
I'm going to weld a nut on, heat the crank a little and try to slide hammer it out.
That will work as well...
There are always lots of ways to repair
Propane heat was not enough, had to fire up the oxy/acc torch.
Very nice.
You can certainly weld a lot better then me.
Most of the time guys break them off which is why they need to replace them
Great job!
Great job!
