As some of you know I built the rear brake caliper for Sean Collier's new bike.
I learned several things the first time around so while some of this is a rehash, some of it is new.
First things first you will need a KX450F rear brake caliper... Any year will do up to at least 2012
Next, strip it bare..
{TIP} Use a air nozzle to blow the seals out... Most of the time you can re-use them.
Or just buy new ones as they are cheap..
How to get nutty with a KX450F rear brake caliper
Re: How to get nutty with a KX450F rear brake caliper
Put it in there..
Use some of this on it..
Then some of that..
It starts looking like this..
Then some of that..
No fancy mills or lathes.
I haven't even measured anything... All eyeball
It's starting to take shape..
A little grinder work and..
Ready for weld...
I've left a message with my welder..
We will see how long it will take for him to get back to me...
Ready for weld...
I received it back from the welder and started the clean up..
It's real rough right now but give it some time
A little more progress..
