Sean Colliers KX500 Project "I was only going to inspect the top end"
Post by Sandblaster » Mon Oct 10, 2016 3:15 am
Very nice... Tell Tommy Roberts I appreciate his help....
So many have come together outside of our team to help it is really amazing.
I thank you all....
Post by Sandblaster » Mon Oct 10, 2016 3:25 am
Alex Ward has been a huge help on the suspension and the two piece clutch cover.
Here is a short vid of him dumping the oil from Sean's Enzo built shock
https://www.voxer.com/v/e142e72f2d
Post by Sandblaster » Tue Oct 11, 2016 2:34 am
After lapping we installed the alignment pins and mated the cases together.
KX GURU RACING SEAN COLLIER KX500 204.JPG (190.41 KiB) Viewed 3166 times
Jason is holding the cases up to some light so he can check the cases for any air gaps... NONE :ugeek:
KX GURU RACING SEAN COLLIER KX500 205.JPG (82.26 KiB) Viewed 3166 times
Since the deck was off from one case to another about .001" I went ahead and made sure they were the same height..
After cleaning these cases up again we will finally be ready for assembly.
KX GURU RACING SEAN COLLIER KX500 206.JPG (178.79 KiB) Viewed 3166 times
Post by Sandblaster » Wed Oct 12, 2016 3:00 am
Spent a bit of time cleaning and polishing..
Yeah, there's a bit of wear on these but they will work just fine for a while longer.
KX GURU RACING SEAN COLLIER KX500 207.JPG (153.16 KiB) Viewed 3162 times
Now that we got all the crud out of here I'm sure the Kips will rattle pretty good :lol:
KX GURU RACING SEAN COLLIER KX500 208.JPG (68.53 KiB) Viewed 3162 times
KX GURU RACING SEAN COLLIER KX500 209.JPG (146.21 KiB) Viewed 3162 times
Post by Sandblaster » Wed Oct 12, 2016 3:01 am
Into the oven... New bearings and seals installed..
KX GURU RACING SEAN COLLIER KX500 210.JPG (171.93 KiB) Viewed 3161 times
More polishing...
KX GURU RACING SEAN COLLIER KX500 211.JPG (496.13 KiB) Viewed 3161 times
Post by Sandblaster » Wed Oct 12, 2016 3:03 am
More and more polishing....
KX GURU RACING SEAN COLLIER KX500 212.JPG (77.33 KiB) Viewed 3160 times
I was going to give the reed a quick clean up but then decided to go all out and disassemble it.
It's a good thing I did because I found a crack in it.. :o
KX GURU RACING SEAN COLLIER KX500 213.JPG (83.12 KiB) Viewed 3160 times
Post by Sandblaster » Wed Oct 12, 2016 3:06 am
I had to run into town late this afternoon as the cases were heating up.
When I got back Jason was locking up.
I had to sneak in and see what he got finished..
KX GURU RACING SEAN COLLIER KX500 214.JPG (268.62 KiB) Viewed 3159 times
KX GURU RACING SEAN COLLIER KX500 215.JPG (233.53 KiB) Viewed 3159 times
Hopefully tomorrow we can get this thing buttoned up, boxed, and shipped back on Thursday..
Post by Sandblaster » Wed Oct 12, 2016 3:17 am
Nice work Oscar..
KX GURU RACING SEAN COLLIER KX500 216.JPG (43.92 KiB) Viewed 3157 times
Post by Sandblaster » Thu Oct 13, 2016 12:32 am
Remember... the only new parts on this is the bearings and seals.
Everything else is used...
KX GURU RACING SEAN COLLIER KX500 217.JPG (281.09 KiB) Viewed 3155 times
KX GURU RACING SEAN COLLIER KX500 218.JPG (223.75 KiB) Viewed 3155 times
KX GURU RACING SEAN COLLIER KX500 219.JPG (197.7 KiB) Viewed 3155 times
Post by Sandblaster » Thu Oct 13, 2016 12:33 am
KX GURU RACING SEAN COLLIER KX500 220.JPG (215.82 KiB) Viewed 3154 times
KX GURU RACING SEAN COLLIER KX500 221.JPG (184.96 KiB) Viewed 3154 times
KX GURU RACING SEAN COLLIER KX500 222.JPG (196.68 KiB) Viewed 3154 times
