I have 6 KX500 rear brake levers in inventory.
Every one of them has the same issue.
The attachment point for the master cylinder gets wallered out and make for a sloppy rear brake
I'm gonna fix mine once and for all...
Fixing a KX500 rear brake lever
- foxx4Beaver
Re: Fixing a KX500 rear brake lever
funny, my buddy that made my drain plug and I were just discussing this topic in his garage last weekend.
he works as a machinist, and plans on making a stainless steel press-in collar to try.
and if it doesn't work out like he thinks/hopes, he's got another plan.
Yep.... I also considered doing that as it would work just fine.
But, I'm going to try something a little different
Kinda goes along with my personality
To fix it I drilled out the existing hole to make it round again.
Then I cleaned it extremely good.
Next, my welder filled in the hole and added a bit of material around the outside edge where the bearing is as it would be a little too small for the bearing to fit.
Then I drilled a 16mm hole for the bearing.
Slipped the bearing in with a bit of bearing retainer.
DONE!
Oh! Bearing size:
16mm OD x 8mm ID x 5mm wide
Next I need to give it a good ride and see how it holds up.
DONE!
Oh! Bearing size:
