YZ125 ENGINE SERVICE SPECIFICATIONS
YZ125 PICTURES AND MEASUREMENTS
Post by Sandblaster » Mon Jan 06, 2014 9:20 pm
94-01 CLUTCH SERVICE SPECIFICATIONS
FRICTION DISC THICKNESS NEW 2.9-3.1MM OR .114"-.122" SERVICE LIMIT 2.7MM OR .106"
STEEL PLATE THICKNESS 1.5-1.7MM OR .059-.067"
CLUTCH SPRING FREE LENGTH 40.1MM OR 1.58" SERVICE LIMIT 38.1MM OR 1.5"
7 STEEL OR ALUMINUM PLATES
8 FRICTION DISCS
Re: YZ125 ENGINE SERVICE SPECIFICATIONS
Post by Sandblaster » Fri Aug 14, 2015 4:44 pm
94 YZ125 HEAD BOLT PATTERN MEASUREMENTS PICS
4JY FITS 94-95 YZ125 - 11111-00-00
1994 YZ125 HEAD BOLT PATTERN.JPG (38.32 KiB) Viewed 9524 times
Post by Sandblaster » Sat Jul 23, 2016 6:39 pm
ELECTRICAL SPECIFICATIONS SPECS
94-95 YZ125 Stator coil resistance ohm specs
Source Coil 1 Brown wire to Red wire 324-396 ohms
Source Coil 2 White wire to Green wire 16-19 ohms
Pick up Coil White/Green Wire to White/Red Wire 446-545 ohms
Post by Sandblaster » Thu Feb 03, 2022 2:51 am
82-84 YZ125 STATOR / MAGNETO OHM SPECS
OHM SPECS RED TO BROWN 1.470 +/- 10%
OHM SPECS RED TO WHITE RED 470 +/- 10%
82 YZ125 IGNITION COIL
PRIMARY (SMALL WIRE) .6 +/- 10%
SECONDARY (GOES TO THE SPARK PLUG) 6.2K +/- 20%
SPARK PLUG: CHAMPION N-59G
GAP .7MM OR .028"
Return to “YZ125 PICTURES AND MEASUREMENTS”
