CR500 CR500R CRANKSHAFT SERVICE SPECS CRANK SHAFT
Post by Sandblaster » Fri Aug 18, 2017 12:25 am
Rod to Crank half clearance: .016-.031" Wear limit .04"
.4-.8mm Wear limit .9mm
Radial play: .0003-.0008" Wear limit .001"
.008-.020mm Wear limit .03mm
FITS: Honda CR500 (1987-2001)
Eye to eye: : 144
SMALL END BORE: 25
BIG END WIDTH: 34
SMALL END WIDTH: 24
BIG END: 20
PIN DIAMETER: 26
PIN LENGTH: 68
SMALL END BEARING: 20X25X28
BIG END BEARING: 26X34X20
WASHER THICKNESS: 1.5
FITS: Honda CR500 (1984-1986)
Eye to eye: : 139
